[PATCH] Added Getentropy() support to beagle BSP
Tue Mar 13 20:45:10 UTC 2018
On Mar 13, 2018 1:31 AM, "Sebastian Huber" <
On 12/03/18 20:02, Udit agarwal wrote:
> So, It looks like here's the final patch, do let me know if its ready to
> be pushed. Also, it would be really helpful if someone else also tests this
> patch before pushing(Although i have done that once).
> Thanks,
> Udit agarwal
> From 454a8ff3e0ea3393818859874705a54b098c6081 Mon Sep 17 00:00:00 2001
> From: Udit agarwal <dev.madaari at gmail.com <mailto:dev.madaari at gmail.com>>
> Date: Tue, 13 Mar 2018 00:20:28 +0530
> Subject: [PATCH] Added Getentropy() support to beagle BSP
>  bsps/arm/include/libcpu/am335x.h                   |  37 ++++++-
>  c/src/lib/libbsp/arm/beagle/Makefile.am            |   4 +-
>  .../libbsp/arm/beagle/getentropy/bbb_getentropy.c  | 116
>  3 files changed, 155 insertions(+), 2 deletions(-)
>  create mode 100644 c/src/lib/libbsp/arm/beagle/ge
> diff --git a/bsps/arm/include/libcpu/am335x.h
> b/bsps/arm/include/libcpu/am335x.h
> index 367e97c..cedd637 100644
> --- a/bsps/arm/include/libcpu/am335x.h
> +++ b/bsps/arm/include/libcpu/am335x.h
> @@ -14,11 +14,17 @@
>   * Modified by Ben Gras <beng at shrike-systems.com <mailto:
> beng at shrike-systems.com>> to add lots
>   * of beagleboard/beaglebone definitions, delete lpc32xx specific
>   * ones, and merge with some other header files.
> + * Modified by Udit agarwal <dev.madaari at gmail.com <mailto:
> dev.madaari at gmail.com>> to add random
> + * number generating module definitions and TRNG register structure.
>  #if !defined(_AM335X_H_)
>  #define _AM335X_H_
> +/* For TRNG register definition */
> +#include <stdint.h>
>  /* Interrupt controller memory map */
>  #define OMAP3_DM37XX_INTR_BASE 0x48200000 /* INTCPS physical address */
> @@ -701,4 +707,33 @@
>  #define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK
> (0x00000020u)
>  #define AM335X_I2C_INT_STOP_CONDITION AM335X_I2C_IRQSTATUS_BF
> -#endif
> +/* TRNG Register */
> +/* RNG base address */
> +#define RNG_BASE 0x48310000
> +/* RNG clock control */
> +#define CM_PER_RNG_CLKCTRL (AM335X_CM_PER_ADDR | (9 << 4))
> +/* rng module clock status bits */
> +#define AM335X_CLK_RNG_BIT_MASK (0x30000)
> +/* Offset from RNG base for output ready flag */
> +#define RNG_STATUS_RDY (1u <<  0)
> +/* Offset from RNG base for FRO related error */
> +#define RNG_STATUS_ERR (1u <<  1)
> +/* Offset from RNG base for clock status */
> +#define RNG_STATUS_CLK (1u << 31)
> +/* enable module */
> +#define AM335X_RNG_ENABLE (1 << 10)
> +/* TRNG register structure */
> +struct bbb_trng_register
> +    uint64_t output;     /* 00 */
> +    uint32_t status;     /* 08 */
> +    uint32_t irq_en;     /* 0c */
> +    uint32_t status_clr; /* 10 */
> +    uint32_t control;    /* 14 */
> +    uint32_t config;     /* 18 */
> +typedef struct bbb_trng_register bbb_trng_register;
The bbb (Beagle Bone Black) is a particular board and the AM335X is a SoC
family. This should be something like this
typedef struct {
} am335x_trng;
> +#endif
> \ No newline at end of file
Git thinks that files should have a newline at the end of the file.
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am
> b/c/src/lib/libbsp/arm/beagle/Makefile.am
> index 8251660..5d5ade3 100644
> --- a/c/src/lib/libbsp/arm/beagle/Makefile.am
> +++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
> @@ -40,7 +40,6 @@ libbsp_a_LIBADD =
>  # Shared
>  libbsp_a_SOURCES += ../../shared/bootcard.c
> -libbsp_a_SOURCES += ../../shared/getentropy-cpucounter.c
>  libbsp_a_SOURCES += ../../shared/src/bsp-fdt.c
>  libbsp_a_SOURCES += ../../shared/bspclean.c
>  libbsp_a_SOURCES += ../../shared/bspgetworkarea.c
> @@ -88,6 +87,9 @@ libbsp_a_SOURCES += gpio/bbb-gpio.c
>  #pwm
>  libbsp_a_SOURCES += pwm/pwm.c
> +#getentropy
> +libbsp_a_SOURCES += getentropy/bbb_getentropy.c
With the new BSP source structure
https://devel.rtems.org/ticket/3285
this new file could be also placed at
bsps/arm/beagle/dev/getentropy.c
Is this specific to the Beagle or the SoC? Or a combination? Earlier you
said the structure was SoC specific?
> +int getentropy(void *ptr, size_t n)
> +    volatile bbb_trng_register  *rng = (bbb_trng_register*) RNG_BASE;
> +    am335x_rng_enable(rng);
> +    while (n > 0)
> +        uint64_t random;
> +        size_t copy;
> +        /* wait untill RNG becomes ready with next set of random data */
> +        while( ( rng->status & RNG_STATUS_RDY ) == 0 )
> +            /* wait */
What happens if you call this function in parallel on different processors?
> +        random = trng_getranddata(rng);
> +        /* Checking for error by masking all bits other then error bit in
> +           status register */
> +        if( ((rng->status & RNG_STATUS_ERR)>>1) == 1)
> +            /* clear the status flag after reading to generate new random
> +               value */
> +            rng->status_clr = RNG_STATUS_RDY;
> +            copy = sizeof(random);
> +            if ( n < copy )
> +                copy = n;
> +            memcpy(ptr, &random, copy);
> +            n -= copy;
> +            ptr = (char*)ptr + copy;
> +    return 0;
> +RTEMS_SYSINIT_ITEM(
> +    am335x_rng_clock_enable,
> +    RTEMS_SYSINIT_DEVICE_DRIVERS,
> +    RTEMS_SYSINIT_ORDER_LAST
> 1.9.1
> devel mailing list
> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
devel mailing list
devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180313/3f21df33/attachment-0002.html>
