want to contribute to project
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Wed Mar 14 18:26:58 UTC 2018
I'm still getting the Covoar not found error
I'm not able to understand what am I missing, if it needs a fix, please
help me understand the code.
Thanks
On 9 March 2018 at 22:20, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On 9 Mar 2018 10:15 p.m., "Vijay Kumar Banerjee" <vijaykumar9597 at gmail.com>
> wrote:
> On 9 Mar 2018 3:34 a.m., "Joel Sherrill" <joel.sherrill at gmail.com> wrote:
> On Sun, Mar 4, 2018 at 4:52 AM, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> On 3 March 2018 at 22:18, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>> wrote:
>>> Hello sir,
>>> I need some guidance to proceed to apply for #2920 as my GSoC project.
>>> I wanted to know the following points :
>>>  1. What are the prerequisites (do I have to produce something ? like
>>> the hello world )
>> Other than the hello world, there's no official prerequisites. Usually
>> the next thing is to fix a small bug, have a look at the tickets here:
>> https://devel.rtems.org/query
>>>  2. reference materials (like specific doc), to familiarise with the
>>> rtems-tester and rsb .
>> Relevant to you would be RTEMS Tester section of the main user manual.
>> The rest of the manual should be useful for setting up rtems in general.
>> https://docs.rtems.org/branches/master/user/tools/tester.html
> Running this and submitting some results for a BSP on a simulator would be
> a good step.
> This project requires doing that a lot.  You can do one BSP that runs on a
> gdb based simulator
> and another on a qemu based simulator.
> I'll surely do that . currently I'm trying to run cillian's project ,
> facing some issues with the test.py , which I'll try to fix , probably it's
> related to the path . I'll be at the other part of the country for a  few
> days (4 days ), after that I'll try to submit results for a BSP on a
> simulator
> There is a project based on qemu that includes coverage trace ability.
>> The links to the previous projects which you already found and the other
>> links I've mentioned.
>>>  3. how to properly plan the project into phase wise tasks and weekly
>>> sub-tasks.
>> Essentially it would be:
>> 1. Get coverage analysis running again (converting the config files to
>> .ini and a couple of fixes to some of the parsing in the sections that
>> haven't been integrated, might be all that it takes).
>> 2. Then get the coverage tools integrated with RTEMS Tester. Which is fix
>> the outstanding issues that are mentioned in:
>> https://devel.rtems.org/ticket/2920
>> Chris Johns might have things to add to this, ultimately the integration
>> to RTEMS Tester will be up to him.
> I would add finishing getting the Couverture qemu into the RSB.
> Okay sir.
> Once the setup is running, there are a couple of meaty projects.
> Chris and I have talked about reworking the report generation in covoar.
> Currently, the C++ code writes HTML and txt files.  It would be nice to
> have covoar generate something which is subsequently processed
> with a report generator. We don't have a complete solution in mind but
> writing Sphinx like the RTEMS documentation is an option. One challenge
> is that the current HTML output has filtering capability and that wouldn't
> be possible (I think) using Sphinx.
> The other desirable capability is to ensure the gcov output is correct and
> can be processed by the GNU gcov tool to produce reports with the same
> results as covoar. I think Cillian got a start on this but only as far as
> noting
> it wasn't always the same. We have a mentor from the GCC community
> to help with this.
> Once the gcov output is trustworthy, we can try other tools like lcov to
> see what other reports we can get.
> Thank you for describing the object in detail , I'll read more about
> covoar and try to understand how it generates the output and how it can be
> modified .
>> The order in which the problems are listed in that ticket are probably
>> the order in which you would complete them, the stuff about generating the
>> xml reports and gcov and all of that is probably a 2nd or 3rd phase task
>> for you depending on how it goes. The plan can change as you go along, its
>> just important that you make a plan to begin with.
>> Good luck,
>> Cillian.
>>> Thank you,
>>> Vijay k.
>>> On 1 March 2018 at 15:38, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> On 1 March 2018 at 09:10, Vijay Kumar Banerjee <
>>>> vijaykumar9597 at gmail.com> wrote:
>>>>> hello,
>>>>> while trying to figure out the starting point, I came across this
>>>>> project form GSoC 2017 by C.P. O'Donell
>>>>> https://summerofcode.withgoogle.com/archive/2017/projects/49
>>>>> 25375616385024/
>>>>> Is this the project that has previous works on the project I'm wanting
>>>>> to take (#2920) ? If not , please help me find the right one.
>>>> Hi Vijay,
>>>> Yes that's the one, let me know if you have any questions about it.
>>>> When I checked last month coverage is not working with the RTEMS Tester
>>>> because the configuration files for the bsps in rtems-tools/tester/rtems
>>>> have been converted from .mc to .ini So the old .mc files I mention need to
>>>> be converted before it will work again.
>>>> This is what I wrote as the final documentation, it should help you
>>>> reproduce what I had working last summer.
>>>> https://devel.rtems.org/wiki/GSoC/2017/coveragetools
>>>> Try this branch in github for the starting point:
>>>> https://github.com/cillianodonnell/rtems-tools/tree/coverage-merge
>>>> Good luck with the project,
>>>> Cillian.
>>>>> Also, please guide me with reading references and some small tickets
>>>>> related to the project .
>>>>> Thank you ,
>>>>> Vijay k.
>>>>> On 26 February 2018 at 21:54, Vijay Kumar Banerjee <
>>>>>> Thank you for giving me a detailed introduction to the project
>>>>>> objectives and mentors.
>>>>>>  I am interested in # 2920: "Improve Coverage analysis toolkit".
>>>>>> Please guide me with the resources to get started with the project
>>>>>> and get a deep understanding.
>>>>>> Thank you
>>>>>> Vijay
>>>>>> On 26 February 2018 at 15:36, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>> On Feb 26, 2018 2:22 AM, "Christian Mauderer" <
>>>>>>> christian.mauderer at embedded-brains.de> wrote:
>>>>>>> Am 24.02.2018 um 16:21 schrieb Vijay Kumar Banerjee:
>>>>>>> > Hello,
>>>>>>> > As told by Joel, I sent the screenshots of my working hello world
>>>>>>> to his
>>>>>>> > personal email and have also included my name in the GSoC tracking
>>>>>>> page .
>>>>>>> > + Make Eclipse Target Interaction work with RTEMS
>>>>>>> > (https://www.eclipse.org/tcf/)
>>>>>>> > + Improvements to our coverage reporting. GCOV validation and
>>>>>>> covoar
>>>>>>> > reporting improvements
>>>>>>> > + wifi integration improvements
>>>>>>> > + aarch64 port
>>>>>>> > + x86_64 port / non-legacy PC BSP
>>>>>>> >    - This project is large so we would need to work with whoever
>>>>>>> wants
>>>>>>> > to tackle it
>>>>>>> >      to find the best subset for GSoC.
>>>>>>> > Based on this list I went through the OpenProjects page
>>>>>>> > and came across the following Tickets .,
>>>>>>> > #2920 ,#3222,#2927 and the link to eclipse tcf .
>>>>>>> > out of them , I find these interesting
>>>>>>> > 1.  "Improve coverage Analysis Toolset " (#2920);
>>>>>>> This area is mine. The ticket mat or may not be a great description
>>>>>>> of the goals. There are probably three things that need to be done.
>>>>>>> + Integrate ran recipes for Couverture variant of qemu. This might
>>>>>>> be a very small task. Last year's student just didn't get this integrated
>>>>>>> and was waiting for some patches to be merged on their side.
>>>>>>> + Verify the gcov output from covoar is correct and the gcov (and
>>>>>>> similar tools) matches the coverage reports it generates. We have someone
>>>>>>> from the GCC community to help mentor here.
>>>>>>> + Covoar generates HTML and text output directly. There is a desire
>>>>>>> for it to generate something equally useful that is processed by existing
>>>>>>> tools to generate reports. One possible option for this output could be
>>>>>>> Sphinx like our regular documentation. Or it could be a data-centric format
>>>>>>> processed by other tools. The current HTML allows filtering and sorting so
>>>>>>> not losing information and ease of use is important. This probably will end
>>>>>>> up simplifying C++ and adding Python.
>>>>>>> > 2.  "libbsd:WiFi support needs rc.conf integration " (#3222)
>>>>>>> Christian's project to mentor.
>>>>>>> > also I came across # 3302 :" Build system conversion of BSP
>>>>>>> Config(.cfg)
>>>>>>> > files to pkg-config(.pc) files"
>>>>>>> > (I have some knowledge of Python, but not proficient in it, I can
>>>>>>> learn
>>>>>>> > it better if it's required )
>>>>>>> > which I find interesting
>>>>>>> This one is Chris Johns project to mentor. It is an important and
>>>>>>> logically the next step in replacing our build system with the Python based
>>>>>>> waf. If you get through this one before the summer is out, then working on
>>>>>>> waf would probably make sense.
>>>>>>> Did I miss one?
>>>>>>> Hello Vijay,
>>>>>>> all of the projects would be good ones.
>>>>>>> The #2920 and #3302 are more connected to the host tools. They
>>>>>>> should be
>>>>>>> doable with few or no real hardware. But you should ask the two
>>>>>>> potential mentors about that.
>>>>>>> For the #3222 you would need some board supported by the libbsd (like
>>>>>>> Beagle Bone Black) and I would suggest a JTAG debugger (some OpenOCD
>>>>>>> based or similar).
>>>>>>> > Am I following the right tickets? If not please help me find the
>>>>>>> right ones.
>>>>>>> The tickets are the right ones.
>>>>>>> > Out of these , which one do you recommend me to take ?
>>>>>>> I would recommend to take a more detailed look at the tickets and
>>>>>>> start
>>>>>>> to ask some questions about it on the mailing list with CC to the
>>>>>>> (potential) mentors.
>>>>>>> Maybe you could also try to find some small tickets related to
>>>>>>> similar
>>>>>>> topics and just try to work on these. That could help you find out
>>>>>>> what
>>>>>>> you want to do.
>>>>>>> > My experience with C/C++ : I am proficient in C++11 with STL . Also
>>>>>>> > proficient in C language .
>>>>>>> > My experience with opensource : This is the first open source
>>>>>>> project
>>>>>>> > I'm taking up .
>>>>>>> It's no problem if it's your first Open Source project. That's the
>>>>>>> point
>>>>>>> of GSoC: To collect first Open Source experience.
>>>>>>> Best regards
>>>>>>> Christian Mauderer
>>>>>>> > Thank you ,
>>>>>>> > Vijay K.
>>>>>>> embedded brains GmbH
>>>>>>> Herr Christian Mauderer
>>>>>>> Dornierstr. 4
>>>>>>> <https://maps.google.com/?q=Dornierstr.+4+%0D+D-82178+Puchheim+%0D+Germany&entry=gmail&source=g>
>>>>>>> D-82178 Puchheim
>>>>>>> Germany
>>>>>>> email: christian.mauderer at embedded-brains.de
>>>>>>> Phone: +49-89-18 94 741 - 18
>>>>>>> Fax:   +49-89-18 94 741 - 08
>>>>>>> PGP: Public key available on request.
>>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>>>>> _______________________________________________
>>>>>>> devel mailing list
>>>>>>> devel at rtems.org
>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>> devel mailing list
>>>>> devel at rtems.org
>>> devel mailing list
>>> devel at rtems.org
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180314/cd41d757/attachment-0002.html>
Name: Screenshot from 2018-03-14 23-52-56.png
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180314/cd41d757/attachment-0002.png>
