want to contribute to project
Wed Mar 14 21:33:27 UTC 2018
On Wed, Mar 14, 2018 at 4:13 PM, Cillian O'Donnell <cpodonnell8 at gmail.com>
wrote:
> On 14 March 2018 at 19:51, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> On 14 March 2018 at 18:26, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>> > wrote:
>>> I'm still getting the Covoar not found error
>>> I'm not able to understand what am I missing, if it needs a fix, please
>>> help me understand the code.
>> Have a look where all the rsb tools were built. Does covoar appear in
>> there?
>> The directory is something like:
>> cd  ~/development/rtems/4.12/bin
> Sorry, nevermind that, just remenbered I had  put covoar there for
> something else.
> You mentioned before that waf built covoar properly and it appeared in:
> "covoar is in /rtems-tools/build/covoar"
> is it this or is it rtems-tools/build/tester/covoar
> and you're definitely using the coverage-merge branch of my github
> https://github.com/cillianodonnell/rtems-tools/tree/coverage-merge
It shouldn't matter much but I think we merged all your changes. If not, we
want to
fix that. Hopefully he can use the main rtems-tools.
--joel
>>> Thanks
>>> On 9 March 2018 at 22:20, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>>> > wrote:
>>>> On 9 Mar 2018 10:15 p.m., "Vijay Kumar Banerjee" <
>>>> vijaykumar9597 at gmail.com> wrote:
>>>> On 9 Mar 2018 3:34 a.m., "Joel Sherrill" <joel.sherrill at gmail.com>
>>>> wrote:
>>>> On Sun, Mar 4, 2018 at 4:52 AM, Cillian O'Donnell <
>>>> cpodonnell8 at gmail.com> wrote:
>>>>> On 3 March 2018 at 22:18, Vijay Kumar Banerjee <
>>>>>> Hello sir,
>>>>>> I need some guidance to proceed to apply for #2920 as my GSoC project.
>>>>>> I wanted to know the following points :
>>>>>>  1. What are the prerequisites (do I have to produce something ? like
>>>>>> the hello world )
>>>>> Other than the hello world, there's no official prerequisites. Usually
>>>>> the next thing is to fix a small bug, have a look at the tickets here:
>>>>> https://devel.rtems.org/query
>>>>>>  2. reference materials (like specific doc), to familiarise with the
>>>>>> rtems-tester and rsb .
>>>>> Relevant to you would be RTEMS Tester section of the main user manual.
>>>>> The rest of the manual should be useful for setting up rtems in general.
>>>>> https://docs.rtems.org/branches/master/user/tools/tester.html
>>>> Running this and submitting some results for a BSP on a simulator would
>>>> be a good step.
>>>> This project requires doing that a lot.  You can do one BSP that runs
>>>> on a gdb based simulator
>>>> and another on a qemu based simulator.
>>>> I'll surely do that . currently I'm trying to run cillian's project ,
>>>> facing some issues with the test.py , which I'll try to fix , probably it's
>>>> related to the path . I'll be at the other part of the country for a  few
>>>> days (4 days ), after that I'll try to submit results for a BSP on a
>>>> simulator
>>>> There is a project based on qemu that includes coverage trace ability.
>>>>> The links to the previous projects which you already found and the
>>>>> other links I've mentioned.
>>>>>>  3. how to properly plan the project into phase wise tasks and weekly
>>>>>> sub-tasks.
>>>>> Essentially it would be:
>>>>> 1. Get coverage analysis running again (converting the config files to
>>>>> .ini and a couple of fixes to some of the parsing in the sections that
>>>>> haven't been integrated, might be all that it takes).
>>>>> 2. Then get the coverage tools integrated with RTEMS Tester. Which is
>>>>> fix the outstanding issues that are mentioned in:
>>>>> https://devel.rtems.org/ticket/2920
>>>>> Chris Johns might have things to add to this, ultimately the
>>>>> integration to RTEMS Tester will be up to him.
>>>> I would add finishing getting the Couverture qemu into the RSB.
>>>> Okay sir.
>>>> Once the setup is running, there are a couple of meaty projects.
>>>> Chris and I have talked about reworking the report generation in
>>>> covoar.
>>>> Currently, the C++ code writes HTML and txt files.  It would be nice to
>>>> have covoar generate something which is subsequently processed
>>>> with a report generator. We don't have a complete solution in mind but
>>>> writing Sphinx like the RTEMS documentation is an option. One challenge
>>>> is that the current HTML output has filtering capability and that
>>>> wouldn't
>>>> be possible (I think) using Sphinx.
>>>> The other desirable capability is to ensure the gcov output is correct
>>>> and
>>>> can be processed by the GNU gcov tool to produce reports with the same
>>>> results as covoar. I think Cillian got a start on this but only as far
>>>> as noting
>>>> it wasn't always the same. We have a mentor from the GCC community
>>>> to help with this.
>>>> Once the gcov output is trustworthy, we can try other tools like lcov to
>>>> see what other reports we can get.
>>>> Thank you for describing the object in detail , I'll read more about
>>>> covoar and try to understand how it generates the output and how it can be
>>>> modified .
>>>>> The order in which the problems are listed in that ticket are probably
>>>>> the order in which you would complete them, the stuff about generating the
>>>>> xml reports and gcov and all of that is probably a 2nd or 3rd phase task
>>>>> for you depending on how it goes. The plan can change as you go along, its
>>>>> just important that you make a plan to begin with.
>>>>> Good luck,
>>>>> Cillian.
>>>>>> Thank you,
>>>>>> Vijay k.
>>>>>> On 1 March 2018 at 15:38, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>> wrote:
>>>>>>> On 1 March 2018 at 09:10, Vijay Kumar Banerjee <
>>>>>>>> hello,
>>>>>>>> while trying to figure out the starting point, I came across this
>>>>>>>> project form GSoC 2017 by C.P. O'Donell
>>>>>>>> https://summerofcode.withgoogle.com/archive/2017/projects/49
>>>>>>>> 25375616385024/
>>>>>>>> Is this the project that has previous works on the project I'm
>>>>>>>> wanting to take (#2920) ? If not , please help me find the right one.
>>>>>>> Hi Vijay,
>>>>>>> Yes that's the one, let me know if you have any questions about it.
>>>>>>> When I checked last month coverage is not working with the RTEMS Tester
>>>>>>> because the configuration files for the bsps in rtems-tools/tester/rtems
>>>>>>> have been converted from .mc to .ini So the old .mc files I mention need to
>>>>>>> be converted before it will work again.
>>>>>>> This is what I wrote as the final documentation, it should help you
>>>>>>> reproduce what I had working last summer.
>>>>>>> https://devel.rtems.org/wiki/GSoC/2017/coveragetools
>>>>>>> Try this branch in github for the starting point:
>>>>>>> Good luck with the project,
>>>>>>> Cillian.
>>>>>>>> Also, please guide me with reading references and some small
>>>>>>>> tickets related to the project .
>>>>>>>> Thank you ,
>>>>>>>> Vijay k.
>>>>>>>> On 26 February 2018 at 21:54, Vijay Kumar Banerjee <
>>>>>>>>> Thank you for giving me a detailed introduction to the project
>>>>>>>>> objectives and mentors.
>>>>>>>>>  I am interested in # 2920: "Improve Coverage analysis toolkit".
>>>>>>>>> Please guide me with the resources to get started with the project
>>>>>>>>> and get a deep understanding.
>>>>>>>>> Thank you
>>>>>>>>> Vijay
>>>>>>>>> On 26 February 2018 at 15:36, Joel Sherrill <joel at rtems.org>
>>>>>>>>> wrote:
>>>>>>>>>> On Feb 26, 2018 2:22 AM, "Christian Mauderer" <
>>>>>>>>>> christian.mauderer at embedded-brains.de> wrote:
>>>>>>>>>> Am 24.02.2018 um 16:21 schrieb Vijay Kumar Banerjee:
>>>>>>>>>> > Hello,
>>>>>>>>>> > As told by Joel, I sent the screenshots of my working hello
>>>>>>>>>> world to his
>>>>>>>>>> > personal email and have also included my name in the GSoC
>>>>>>>>>> tracking page .
>>>>>>>>>> > + Make Eclipse Target Interaction work with RTEMS
>>>>>>>>>> > (https://www.eclipse.org/tcf/)
>>>>>>>>>> > + Improvements to our coverage reporting. GCOV validation and
>>>>>>>>>> covoar
>>>>>>>>>> > reporting improvements
>>>>>>>>>> > + wifi integration improvements
>>>>>>>>>> > + aarch64 port
>>>>>>>>>> > + x86_64 port / non-legacy PC BSP
>>>>>>>>>> >    - This project is large so we would need to work with
>>>>>>>>>> whoever wants
>>>>>>>>>> > to tackle it
>>>>>>>>>> >      to find the best subset for GSoC.
>>>>>>>>>> > Based on this list I went through the OpenProjects page
>>>>>>>>>> > and came across the following Tickets .,
>>>>>>>>>> > #2920 ,#3222,#2927 and the link to eclipse tcf .
>>>>>>>>>> > out of them , I find these interesting
>>>>>>>>>> > 1.  "Improve coverage Analysis Toolset " (#2920);
>>>>>>>>>> This area is mine. The ticket mat or may not be a great
>>>>>>>>>> description of the goals. There are probably three things that need to be
>>>>>>>>>> done.
>>>>>>>>>> + Integrate ran recipes for Couverture variant of qemu. This
>>>>>>>>>> might be a very small task. Last year's student just didn't get this
>>>>>>>>>> integrated and was waiting for some patches to be merged on their side.
>>>>>>>>>> + Verify the gcov output from covoar is correct and the gcov (and
>>>>>>>>>> similar tools) matches the coverage reports it generates. We have someone
>>>>>>>>>> from the GCC community to help mentor here.
>>>>>>>>>> + Covoar generates HTML and text output directly. There is a
>>>>>>>>>> desire for it to generate something equally useful that is processed by
>>>>>>>>>> existing tools to generate reports. One possible option for this output
>>>>>>>>>> could be Sphinx like our regular documentation. Or it could be a
>>>>>>>>>> data-centric format processed by other tools. The current HTML allows
>>>>>>>>>> filtering and sorting so not losing information and ease of use is
>>>>>>>>>> important. This probably will end up simplifying C++ and adding Python.
>>>>>>>>>> > 2.  "libbsd:WiFi support needs rc.conf integration " (#3222)
>>>>>>>>>> Christian's project to mentor.
>>>>>>>>>> > also I came across # 3302 :" Build system conversion of BSP
>>>>>>>>>> Config(.cfg)
>>>>>>>>>> > files to pkg-config(.pc) files"
>>>>>>>>>> > (I have some knowledge of Python, but not proficient in it, I
>>>>>>>>>> can learn
>>>>>>>>>> > it better if it's required )
>>>>>>>>>> > which I find interesting
>>>>>>>>>> This one is Chris Johns project to mentor. It is an important and
>>>>>>>>>> logically the next step in replacing our build system with the Python based
>>>>>>>>>> waf. If you get through this one before the summer is out, then working on
>>>>>>>>>> waf would probably make sense.
>>>>>>>>>> Did I miss one?
>>>>>>>>>> Hello Vijay,
>>>>>>>>>> all of the projects would be good ones.
>>>>>>>>>> The #2920 and #3302 are more connected to the host tools. They
>>>>>>>>>> should be
>>>>>>>>>> doable with few or no real hardware. But you should ask the two
>>>>>>>>>> potential mentors about that.
>>>>>>>>>> For the #3222 you would need some board supported by the libbsd
>>>>>>>>>> (like
>>>>>>>>>> Beagle Bone Black) and I would suggest a JTAG debugger (some
>>>>>>>>>> OpenOCD
>>>>>>>>>> based or similar).
>>>>>>>>>> > Am I following the right tickets? If not please help me find
>>>>>>>>>> the right ones.
>>>>>>>>>> The tickets are the right ones.
>>>>>>>>>> > Out of these , which one do you recommend me to take ?
>>>>>>>>>> I would recommend to take a more detailed look at the tickets and
>>>>>>>>>> start
>>>>>>>>>> to ask some questions about it on the mailing list with CC to the
>>>>>>>>>> (potential) mentors.
>>>>>>>>>> Maybe you could also try to find some small tickets related to
>>>>>>>>>> similar
>>>>>>>>>> topics and just try to work on these. That could help you find
>>>>>>>>>> out what
>>>>>>>>>> you want to do.
>>>>>>>>>> > My experience with C/C++ : I am proficient in C++11 with STL .
>>>>>>>>>> Also
>>>>>>>>>> > proficient in C language .
>>>>>>>>>> > My experience with opensource : This is the first open source
>>>>>>>>>> project
>>>>>>>>>> > I'm taking up .
>>>>>>>>>> It's no problem if it's your first Open Source project. That's
>>>>>>>>>> the point
>>>>>>>>>> of GSoC: To collect first Open Source experience.
>>>>>>>>>> Best regards
>>>>>>>>>> Christian Mauderer
>>>>>>>>>> > Thank you ,
>>>>>>>>>> > Vijay K.
>>>>>>>>>> embedded brains GmbH
>>>>>>>>>> Herr Christian Mauderer
>>>>>>>>>> Dornierstr. 4
>>>>>>>>>> <https://maps.google.com/?q=Dornierstr.+4+%0D+D-82178+Puchheim+%0D+Germany&entry=gmail&source=g>
>>>>>>>>>> D-82178 Puchheim
>>>>>>>>>> Germany
>>>>>>>>>> email: christian.mauderer at embedded-brains.de
>>>>>>>>>> Phone: +49-89-18 94 741 - 18
>>>>>>>>>> Fax:   +49-89-18 94 741 - 08
>>>>>>>>>> PGP: Public key available on request.
>>>>>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des
>>>>>>>>>> EHUG.
>>>>>>>>>> _______________________________________________
>>>>>>>>>> devel mailing list
>>>>>>>>>> devel at rtems.org
>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>>>> devel mailing list
>>>>>>>> devel at rtems.org
>>>>>> devel mailing list
>>>>>> devel at rtems.org
>>>>> devel mailing list
>>>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180314/e2874457/attachment-0002.html>
