[PATCH] Added Getentropy() support to beagle BSP
Udit agarwal
dev.madaari at gmail.com
Thu Mar 15 07:13:57 UTC 2018
On Thu, Mar 15, 2018 at 11:29 AM, Sebastian Huber <
> On 15/03/18 05:56, Udit agarwal wrote:
>> c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c | 6 ++++++
>> 1 file changed, 6 insertions(+)
>> diff --git a/c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c
>> b/c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c
>> index 11e24dc..b26b6a8 100644
>> --- a/c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c
>> +++ b/c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c
>> @@ -17,6 +17,8 @@
>> #include <string.h>
>> #include <rtems/sysinit.h>
>> +static rtems_mutex atsam_trng_reg = RTEMS_MUTEX_INITIALIZER("atsam
>> _trng_reg");
> Is this a register or a mutex?
>> static void atsam_trng_enable(void)
>> PMC_EnablePeripheral(ID_TRNG);
>> @@ -29,9 +31,12 @@ int getentropy(void *ptr, size_t n)
>> uint32_t random;
>> size_t copy;
>> + rtems_mutex_lock(&atsam_trng_reg);
>> while ((TRNG_GetStatus() & TRNG_ISR_DATRDY) == 0) {
>> /* wait */
>> + rtems_mutex_unlock(&atsam_trng_reg);
> Now the status register read is protected by a mutex.
> random = TRNG_GetRandData();
> Can you ensure that this read is correct in a multi-threaded application
> (the status register has the right value during the read)?
> Oh yes, i think i misinterpreted your previous suggestion of surrounding
the while loop by mutex, it should be the outer while loop. some thing like
this?:
while (n > 0) {
uint32_t random;
size_t copy;
rtems_mutex_lock(&atsam_trng_mutex);
/* wait */
* Read TRNG status one more time to avoid race condition.
* Otherwise we can read (and clear) an old ready status but get
* a new value. The ready status for this value wouldn't be
* reset.
TRNG_GetStatus();
copy = sizeof(random);
if (n < copy ) {
copy = n;
memcpy(ptr, &random, copy);
n -= copy;
ptr += copy;
rtems_mutex_unlock(&atsam_trng_mutex);
>> @@ -51,6 +56,7 @@ int getentropy(void *ptr, size_t n)
>> ptr += copy;
>> + rtems_mutex_destroy(&atsam_trng_reg);
> Here you destroy the mutex. What happens if you call getentropy() a
> second time?
> return 0;
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180315/cf489251/attachment-0002.html>
