Improve coverage analysis toolset
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Thu Mar 15 10:53:07 UTC 2018
I have attached the output of the ls of that directory
-- vijay
On 15 March 2018 at 15:52, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> On 15 March 2018 at 03:58, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> hello ,
>> as told by Joel , I started this thread to further discuss the coverage
>> analysis toolset .
>> Current status is , I'm trying to builld and run rtems-test from the
>> coverage-merge branch of the previous GSoC student Cillian .
>> https://github.com/cillianodonnell/rtems-tools/tree/coverage-merge
>> I'm getting an error that says .
>>  "Covoar not found !"
> It's supposed to find it in rtems-tools/build/tester/covoar/ If it's in
> there it should be fine. Can you show me the contents of that directory?
> cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar $ ls
>> the Covoar appeared in rtems-tools/tester/covoar .
>> Vijay
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180315/ad92b477/attachment-0002.html>
app_common.cc.1.o
CoverageFactory.cc.1.o
CoverageMapBase.cc.1.o
CoverageMap.cc.1.o
CoverageRanges.cc.1.o
CoverageReaderBase.cc.1.o
CoverageReaderQEMU.cc.1.o
CoverageReaderRTEMS.cc.1.o
CoverageReaderSkyeye.cc.1.o
CoverageReaderTSIM.cc.1.o
CoverageWriterBase.cc.1.o
CoverageWriterRTEMS.cc.1.o
CoverageWriterSkyeye.cc.1.o
CoverageWriterTSIM.cc.1.o
covoar
covoar.cc.3.o
covoar-config.h
DesiredSymbols.cc.1.o
ExecutableInfo.cc.1.o
Explanations.cc.1.o
GcovData.cc.1.o
GcovFunctionData.cc.1.o
libccovoar.a
ObjdumpProcessor.cc.1.o
ReportsBase.cc.1.o
ReportsHtml.cc.1.o
ReportsText.cc.1.o
SymbolTable.cc.1.o
Target_arm.cc.1.o
TargetBase.cc.1.o
TargetFactory.cc.1.o
Target_i386.cc.1.o
Target_lm32.cc.1.o
Target_m68k.cc.1.o
Target_powerpc.cc.1.o
Target_sparc.cc.1.o
trace-converter
TraceConverter.cc.2.o
TraceList.cc.2.o
TraceReaderBase.cc.2.o
TraceReaderLogQEMU.cc.2.o
TraceWriterBase.cc.2.o
TraceWriterQEMU.cc.2.o
