Improve coverage analysis toolset
Cillian O'Donnell
cpodonnell8 at gmail.com
Fri Mar 16 16:09:08 UTC 2018
Just checked and the build was failing because one of the patches needed
its hash to be updated to sha256. Just pushed that change. The build
finishes successfully on my end. Pull that change into couverture-build
branch and try it again. I'm not seeing any automake stuff here, so just
check that and let me know.
On 16 March 2018 at 14:59, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> building couverture-qemu from rtems-source-builder ( https://github.com/
> cillianodonnell/rtems-source-builder/tree/couverture-build )
> gives error building auromake-1.12.6-x86_64-linux-gnu-1 .
> I have attached the error report .
> -- vijay
> On 15 March 2018 at 19:17, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> On 15 March 2018 at 12:26, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>> > wrote:
>>> It runs with a bunch of errors . I have attached the log file
>> Ok, I'm guessing you didn't set up Couverture-Qemu (special version of
>> qemu designed for generating extra trace data for coverage analysis).
>> That's what those errors are about. I have an RSB build for that.
>> https://github.com/cillianodonnell/rtems-source-builder/
>> and the instructions for building it are
>> https://devel.rtems.org/wiki/GSoC/2017/coveragetools#Buildin
>> gCouverture-QemuwiththeRSB
>> I know what the other problem is too. I have a specific environment
>> variable defined for the path, sorry I can't even remember putting it
>> there, I thought that was automatically generated (probably should be,
>> another thing to add to the list :)... ). So wherever you stuck the export
>> path for where the rsb built the tools, in .bashrc or whatever you're
>> using. Also put something like:
>> export PATH=$HOME/development/rtems/5/bin:$PATH
>> export PATH=$HOME/development/rtems/test/rtems-tools/build/tester/covoar:$PATH
>> or you could just copy covoar into the /bin directory with all the other
>> rsb tools gcc and all that, it'll find it either way.
>>> -- vijay
>>> On 15 March 2018 at 16:58, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> Looks good. If you run the samples without coverage is everything ok?
>>>> So removing --coverage and tacking on /samples
>>>> $HOME/development/rtems-tools/tester/rtems-test --rtems-bsp=leon3-qemu
>>>> --log=log-leon3.log --rtems-tools=$HOME/development/rtems/5
>>>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>> sparc-rtems5/c/leon3/testsuites/samples
>>>> Do the tests run?
>>>> On 15 March 2018 at 10:53, Vijay Kumar Banerjee <
>>>> vijaykumar9597 at gmail.com> wrote:
>>>>> I have attached the output of the ls of that directory
>>>>> -- vijay
>>>>> On 15 March 2018 at 15:52, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> On 15 March 2018 at 03:58, Vijay Kumar Banerjee <
>>>>>>> hello ,
>>>>>>> as told by Joel , I started this thread to further discuss the
>>>>>>> coverage analysis toolset .
>>>>>>> Current status is , I'm trying to builld and run rtems-test from the
>>>>>>> coverage-merge branch of the previous GSoC student Cillian .
>>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/coverage-merge
>>>>>>> I'm getting an error that says .
>>>>>>> "Covoar not found !"
>>>>>> It's supposed to find it in rtems-tools/build/tester/covoar/ If it's
>>>>>> in there it should be fine. Can you show me the contents of that directory?
>>>>>> cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar $
>>>>>> ls
>>>>>>> the Covoar appeared in rtems-tools/tester/covoar .
>>>>>>> Vijay
>>>>>>> _______________________________________________
>>>>>>> devel mailing list
>>>>>>> devel at rtems.org
>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180316/689929da/attachment-0002.html>
