Improve coverage analysis toolset
Cillian O'Donnell
cpodonnell8 at gmail.com
Fri Mar 16 18:43:16 UTC 2018
If you build regular qemu with the RSB, does the same thing happen?
Try
../source-builder/sb-set-builder --log=qemu_log.txt
--prefix=$HOME/development/5 devel/qemu
On 16 March 2018 at 16:48, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> still the same error
> -- vijay
> On 16 March 2018 at 21:39, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> Just checked and the build was failing because one of the patches needed
>> its hash to be updated to sha256. Just pushed that change. The build
>> finishes successfully on my end. Pull that change into couverture-build
>> branch and try it again. I'm not seeing any automake stuff here, so just
>> check that and let me know.
>> On 16 March 2018 at 14:59, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>> > wrote:
>>> building couverture-qemu from rtems-source-builder (
>>> https://github.com/cillianodonnell/rtems-source-builder/tr
>>> ee/couverture-build )
>>> gives error building auromake-1.12.6-x86_64-linux-gnu-1 .
>>> I have attached the error report .
>>> -- vijay
>>> On 15 March 2018 at 19:17, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> On 15 March 2018 at 12:26, Vijay Kumar Banerjee <
>>>> vijaykumar9597 at gmail.com> wrote:
>>>>> It runs with a bunch of errors . I have attached the log file
>>>> Ok, I'm guessing you didn't set up Couverture-Qemu (special version of
>>>> qemu designed for generating extra trace data for coverage analysis).
>>>> That's what those errors are about. I have an RSB build for that.
>>>> https://github.com/cillianodonnell/rtems-source-builder/tree
>>>> /couverture-build
>>>> and the instructions for building it are
>>>> https://devel.rtems.org/wiki/GSoC/2017/coveragetools#Buildin
>>>> gCouverture-QemuwiththeRSB
>>>> I know what the other problem is too. I have a specific environment
>>>> variable defined for the path, sorry I can't even remember putting it
>>>> there, I thought that was automatically generated (probably should be,
>>>> another thing to add to the list :)... ). So wherever you stuck the export
>>>> path for where the rsb built the tools, in .bashrc or whatever you're
>>>> using. Also put something like:
>>>> export PATH=$HOME/development/rtems/5/bin:$PATH
>>>> export PATH=$HOME/development/rtems/test/rtems-tools/build/tester/covoar:$PATH
>>>> or you could just copy covoar into the /bin directory with all the
>>>> other rsb tools gcc and all that, it'll find it either way.
>>>>> -- vijay
>>>>> On 15 March 2018 at 16:58, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> Looks good. If you run the samples without coverage is everything ok?
>>>>>> So removing --coverage and tacking on /samples
>>>>>> $HOME/development/rtems-tools/tester/rtems-test
>>>>>> --rtems-bsp=leon3-qemu --log=log-leon3.log --rtems-tools=$HOME/development/rtems/5
>>>>>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>>>> sparc-rtems5/c/leon3/testsuites/samples
>>>>>> Do the tests run?
>>>>>> On 15 March 2018 at 10:53, Vijay Kumar Banerjee <
>>>>>>> I have attached the output of the ls of that directory
>>>>>>> -- vijay
>>>>>>> On 15 March 2018 at 15:52, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>> wrote:
>>>>>>>> On 15 March 2018 at 03:58, Vijay Kumar Banerjee <
>>>>>>>>> hello ,
>>>>>>>>> as told by Joel , I started this thread to further discuss the
>>>>>>>>> coverage analysis toolset .
>>>>>>>>> Current status is , I'm trying to builld and run rtems-test from
>>>>>>>>> the coverage-merge branch of the previous GSoC student Cillian .
>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/coverage-merge
>>>>>>>>> I'm getting an error that says .
>>>>>>>>> "Covoar not found !"
>>>>>>>> It's supposed to find it in rtems-tools/build/tester/covoar/ If
>>>>>>>> it's in there it should be fine. Can you show me the contents of that
>>>>>>>> directory?
>>>>>>>> cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar
>>>>>>>> $ ls
>>>>>>>>> the Covoar appeared in rtems-tools/tester/covoar .
>>>>>>>>> Vijay
>>>>>>>>> _______________________________________________
>>>>>>>>> devel mailing list
>>>>>>>>> devel at rtems.org
>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180316/566ae83a/attachment-0002.html>
