Gsoc 2018
Fri Mar 16 19:08:15 UTC 2018
Check out the csv file in rtems-docs/posix-compliance. Chris and I put
together a new POSIX Compliance Guide. It is on docs.rtems.org.
Check out the guide and the new csv. Up to date and lots of POSIX profiles.
Even has guidance on finding methods to implement. Between that and the
ticket, should be a good start.
On Mar 16, 2018 1:58 PM, "Aditya Upadhyay" <aadit0402 at gmail.com> wrote:
> Hi Joel,
> I am sharing one spreadsheet to Salil what you had shared with me last
> year. It will also help him to identify the works that need to be included
> as a
> part of GSoC-2018.
> On Sat, Mar 17, 2018 at 12:08 AM, Joel Sherrill <joel at rtems.org> wrote:
> > Are you interested in the POSIX Compliance project?
> > If so, you really need to get your proposal together and submitted. Then
> we
> > can worry about doing the work proposed. With no proposal, you can't
> > get accepted.
> > https://devel.rtems.org/ticket/2966 is the POSIX Compliance ticket. It
> > has sub-tickets for individual tasks that has been identified so far.
> Can you please see the ticket: https://devel.rtems.org/ticket/2968
> It was a part of GSoC-2017. I have already ported Inttypes methods to
> newlib.
> Could you please close this sub-ticket?
> Thanks & Regards,
> Aditya Upadhyay
> > --joel
> > On Fri, Mar 16, 2018 at 1:25 PM, Salil Sirotia <salil.sirotia at gmail.com>
> > wrote:
> >> Hello Developers,
> >> At this point of time, I have built the newlib for SPARC BSP and
> >> subscribed myself for newlib mailing list.Could you please suggest me
> any
> >> library or some of the functions that is needed to port to newlib? Any
> >> response from your side would be
> >> greatly appreciated.
> >> That would be great and easy start for me towards GSoC-2018.
> >> Thanks & regards,
> >> Salil Sirotia,
> >> Mtech,CSE-IS(Final Year),
> >> IIT(ISM),Dhanbad
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180316/a2c7c15d/attachment-0002.html>
