RSB build failure
Aditya Upadhyay
aadit0402 at gmail.com
Sat Mar 17 10:03:35 UTC 2018
install python-dev... Will solve the issue. If you are using ubuntu..
sudo apt-get install python-dev.
On Sat, Mar 17, 2018, 3:30 PM Amaan Cheval <amaan.cheval at gmail.com> wrote:
> Hi!
> > checking for python...
> /Library/Frameworks/Python.framework/Versions/2.7/bin/python
> > checking for python2.7... no
> > configure: error: python is missing or unusable
> That looks like the problem (at least on the surface). macOS does come with
> Python built-in, but I don't believe that's good enough for development
> (vague memories only of issues) - have you installed Python separately too?
> If so, could you confirm that you have the python2.7 binary in your PATH
> variable too?
> On Sat, Mar 17, 2018 at 3:24 PM Vidushi Vashishth <reachvidu at gmail.com>
> wrote:
> > Hello!
> > I was trying to set up the sparc/erc32 bsp on a new system and was
> following the quickstart on the user manual. Though I have successfully
> done this before, this time its throwing an error. PFA the rsb log file
> with the error report. I was doing this to run the trace buffering
> examples.
> > Why is the shell command /bin/sh -ex failing?
> > Regards,
> > Vidushi
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180317/06d3a335/attachment-0002.html>
