Improve coverage analysis toolset
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Sun Mar 18 10:35:17 UTC 2018
Thanks Cillian :)
It's great to see it running ,  I'll do some background reading about RSB,
and RTEMS-Tools along with the covoar code . And also work on my python
skills.
to try rtems-test on a bsp that runs gdb , I tried it on erc32 and that
also worked.
I'm also waiting for Joel and other mentors' review on my draft proposal,
so that I can also work on it and make any changes if needed.
Thanks .
-- vijay
On 18 March 2018 at 14:17, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> On 18 March 2018 at 06:47, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> It worked !
> That's great!  That's the good news then. I was using an old leon3 build
> and maybe some older Qemu too and I think that's why I didn't see any
> issues initially. I was hoping you could see the coverage running and the
> reports generated from that but it looks like the full update to the
> current master will be necessary to have a look. So until the parsing for
> the INI files is added to the coverage.py we won't see the coverage
> running. Unfortunately, I'm in the middle of exams until the following
> Monday so I won't be able to sink any more time into it until then. You can
> still figure out the RSB problem you're having and do some background
> reading, brush up on your Python skills, have a read of the covoar code
> https://github.com/RTEMS/rtems-tools/blob/master/tester/covoar/covoar.cc
> just skim through, read the comments, get a sense of the what it's doing
> and in what order.
>> It's great to see it running ! I have attached the result .
>> -- vijay
>> On 18 March 2018 at 02:31, Cillian O'Donnell <cpodonnell8 at gmail.com>
>> wrote:
>>> On 17 March 2018 at 20:08, Vijay Kumar Banerjee <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> yes it prints hello world
>>> Alright I've added an .ini for leon3-qemu to the current rtems-tools.
>>> Pull this branch
>>> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>> and try
>>> $HOME/development/rtems/test/rtems-tools/tester/rtems-test
>>> --rtems-tools=$HOME/development/rtems/5 --log=coverage-analysis.log
>>> --rtems-bsp=leon3_qemu $HOME/development/rtems/leon3/
>>> sparc-rtems5/c/leon3/testsuites/samples
>>>> -- vijay
>>>> On 18 March 2018 at 01:31, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> If you run just one test by itself without rtems-test
>>>>> qemu-system-sparc -no-reboot -monitor null -serial stdio -nographic -M
>>>>> leon3_generic -kernel $HOME/development/rtems/leon3/
>>>>> sparc-rtems5/c/leon3/testsuites/samples/hello/hello.exe
>>>>> Does the hello world print out?
>>>>> On 17 March 2018 at 14:46, Vijay Kumar Banerjee <
>>>>>> I built it manually
>>>>>> the environment variable PATH looks like this
>>>>>> /home/lunatic/qemu/install/bin:/home/lunatic/development/rte
>>>>>> ms/5/bin:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/
>>>>>> home/lunatic/.local/bin:/home/lunatic/bin
>>>>>> I tried to run rtems-test again without --coverage , it gives the
>>>>>> same result
>>>>>> I have attached the log.
>>>>>> -- vijay
>>>>>> On 17 March 2018 at 00:55, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>> wrote:
>>>>>>> Yes this is something more than my build, I'll need someone a bit
>>>>>>> more expert in the RSB to step in there. In the meantime, lets just build
>>>>>>> couverture-qemu manually so we can see is everything else working.
>>>>>>> git clone https://github.com/AdaCore/qemu
>>>>>>> cd qemu
>>>>>>> ./configure --target-list=sparc-softmmu --prefix=$HOME/qemu/install
>>>>>>> --disable-docs --disable-virtfs --disable-werror
>>>>>>> make
>>>>>>> make install
>>>>>>> then add the prefix to $PATH in .bashrc as well like before.
>>>>>>> export PATH=$HOME/qemu/install/bin:$PATH
>>>>>>> Then run rtem-test and see what happens
>>>>>>> On 16 March 2018 at 19:13, Vijay Kumar Banerjee <
>>>>>>>> the same error comes when I try to build qemu from the
>>>>>>>> RTEMS/rtems-source-builder as well
>>>>>>>> is the issue coming from my system ? I'm using fedora 27 64bit
>>>>>>>> On 17 Mar 2018 12:39 a.m., "Vijay Kumar Banerjee" <
>>>>>>>>> yes , the same thing happens
>>>>>>>>> On 17 Mar 2018 12:13 a.m., "Cillian O'Donnell" <
>>>>>>>>>> If you build regular qemu with the RSB, does the same thing
>>>>>>>>>> happen?
>>>>>>>>>> Try
>>>>>>>>>> ../source-builder/sb-set-builder --log=qemu_log.txt
>>>>>>>>>> --prefix=$HOME/development/5 devel/qemu
>>>>>>>>>> On 16 March 2018 at 16:48, Vijay Kumar Banerjee <
>>>>>>>>>>> still the same error
>>>>>>>>>>> -- vijay
>>>>>>>>>>> On 16 March 2018 at 21:39, Cillian O'Donnell <
>>>>>>>>>>>> Just checked and the build was failing because one of the
>>>>>>>>>>>> patches needed its hash to be updated to sha256. Just pushed that change.
>>>>>>>>>>>> The build finishes successfully on my end. Pull that change into
>>>>>>>>>>>> couverture-build branch and try it again. I'm not seeing any automake stuff
>>>>>>>>>>>> here, so just check that and let me know.
>>>>>>>>>>>> On 16 March 2018 at 14:59, Vijay Kumar Banerjee <
>>>>>>>>>>>>> building couverture-qemu from rtems-source-builder (
>>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-source-builder/tr
>>>>>>>>>>>>> ee/couverture-build )
>>>>>>>>>>>>> gives error building auromake-1.12.6-x86_64-linux-gnu-1 .
>>>>>>>>>>>>> I have attached the error report .
>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>> On 15 March 2018 at 19:17, Cillian O'Donnell <
>>>>>>>>>>>>>> On 15 March 2018 at 12:26, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>> It runs with a bunch of errors . I have attached the log
>>>>>>>>>>>>>>> file
>>>>>>>>>>>>>> Ok, I'm guessing you didn't set up Couverture-Qemu (special
>>>>>>>>>>>>>> version of qemu designed for generating extra trace data for coverage
>>>>>>>>>>>>>> analysis). That's what those errors are about. I have an RSB build for that.
>>>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-source-builder/tree
>>>>>>>>>>>>>> /couverture-build
>>>>>>>>>>>>>> and the instructions for building it are
>>>>>>>>>>>>>> https://devel.rtems.org/wiki/GSoC/2017/coveragetools#Buildin
>>>>>>>>>>>>>> gCouverture-QemuwiththeRSB
>>>>>>>>>>>>>> I know what the other problem is too. I have a specific
>>>>>>>>>>>>>> environment variable defined for the path, sorry I can't even remember
>>>>>>>>>>>>>> putting it there, I thought that was automatically generated (probably
>>>>>>>>>>>>>> should be, another thing to add to the list :)... ). So wherever you stuck
>>>>>>>>>>>>>> the export path for where the rsb built the tools, in .bashrc or whatever
>>>>>>>>>>>>>> you're using. Also put something like:
>>>>>>>>>>>>>> export PATH=$HOME/development/rtems/5
>>>>>>>>>>>>>> /bin:$PATH
>>>>>>>>>>>>>> export PATH=$HOME/development/rtems/t
>>>>>>>>>>>>>> est/rtems-tools/build/tester/covoar:$PATH
>>>>>>>>>>>>>> or you could just copy covoar into the /bin directory with
>>>>>>>>>>>>>> all the other rsb tools gcc and all that, it'll find it either way.
>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>> On 15 March 2018 at 16:58, Cillian O'Donnell <
>>>>>>>>>>>>>>>> Looks good. If you run the samples without coverage is
>>>>>>>>>>>>>>>> everything ok?
>>>>>>>>>>>>>>>> So removing --coverage and tacking on /samples
>>>>>>>>>>>>>>>> $HOME/development/rtems-tools/tester/rtems-test
>>>>>>>>>>>>>>>> --rtems-bsp=leon3-qemu --log=log-leon3.log --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>>>>>>>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>>>>>>>>>>>>>> Do the tests run?
>>>>>>>>>>>>>>>> On 15 March 2018 at 10:53, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>> I have attached the output of the ls of that directory
>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>> On 15 March 2018 at 15:52, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>> On 15 March 2018 at 03:58, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>> hello ,
>>>>>>>>>>>>>>>>>>> as told by Joel , I started this thread to further
>>>>>>>>>>>>>>>>>>> discuss the coverage analysis toolset .
>>>>>>>>>>>>>>>>>>> Current status is , I'm trying to builld and run
>>>>>>>>>>>>>>>>>>> rtems-test from the coverage-merge branch of the previous GSoC student
>>>>>>>>>>>>>>>>>>> Cillian .
>>>>>>>>>>>>>>>>>>> nell/rtems-tools/tree/coverage-merge
>>>>>>>>>>>>>>>>>>> I'm getting an error that says .
>>>>>>>>>>>>>>>>>>>  "Covoar not found !"
>>>>>>>>>>>>>>>>>> It's supposed to find it in rtems-tools/build/tester/covoar/
>>>>>>>>>>>>>>>>>> If it's in there it should be fine. Can you show me the contents of that
>>>>>>>>>>>>>>>>>> directory?
>>>>>>>>>>>>>>>>>> cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar
>>>>>>>>>>>>>>>>>> $ ls
>>>>>>>>>>>>>>>>>>> the Covoar appeared in rtems-tools/tester/covoar .
>>>>>>>>>>>>>>>>>>> Vijay
>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180318/436f7426/attachment-0002.html>
