autotools build fail from rsb
Sun Mar 18 10:43:30 UTC 2018
On Sun, Mar 18, 2018 at 6:41 AM, Gedare Bloom <gedare at rtems.org> wrote:
> Vijay,
> On Sun, Mar 18, 2018 at 6:36 AM, Vijay Kumar Banerjee
> <vijaykumar9597 at gmail.com> wrote:
>> I have set the PATH like this
>> /usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/home/lunatic/.local/bin:/home/lunatic/bin
>> I'm still getting the same error
>> -- vijay
>> On 18 March 2018 at 16:01, Gedare Bloom <gedare at rtems.org> wrote:
>>> On Sat, Mar 17, 2018 at 12:37 PM, Joel Sherrill <joel at rtems.org> wrote:
>>> > I answered what I think the cause is on another thread.
>>> > Take the ancient RTEMS autotools out of your PATH while building qemu.
>>> > Use a
>>> > PATH without RTEMS tools in it. I think the ancient automake version we
>>> > use
>>> > must have --help which help2man can't parse.
>>> I don't think this is the solution, because the failure happens while
>>> trying to build the autotools.
> What happens when you run on the command line:
> $> automake-1.12 --help
I suspect it is related to:
https://lists.gnu.org/archive/html/bug-automake/2017-06/msg00003.html
The problem is how perl is handling regex escaping where a newer perl
causes an error when an older perl caused a warning. Since we are kind
of stuck with an older automake, you should install an older perl.
Apparently, something before 5.26.0 should work I guess.
-Gedare
>>> > On Mar 17, 2018 11:34 AM, "Vijay Kumar Banerjee"
>>> > wrote:
>>> >> hello ,
>>> >> As suggested by Gedare , I have started this thread on the build error
>>> >> that I'm getting .
>>> >> I'm getting automake-1.12.6-x86_64-linux-gnu-1 building error while
>>> >> trying
>>> >> to build autotools from rsb
>>> >> I'm using fedora 27 64bit .
>>> >> P.S: the error report is attached
>>> >> -- vijay
