autotools build fail from rsb
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Sun Mar 18 16:23:55 UTC 2018
I have tried
perl-5.24.3
perl-5.22.4
perl-5.20.3
still getting the same error, it be coming from something else
-- vijay
On 18 March 2018 at 16:15, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> -- vijay
> On 18 March 2018 at 16:13, Gedare Bloom <gedare at rtems.org> wrote:
>> On Sun, Mar 18, 2018 at 6:41 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> > Vijay,
>> > On Sun, Mar 18, 2018 at 6:36 AM, Vijay Kumar Banerjee
>> > <vijaykumar9597 at gmail.com> wrote:
>> >> I have set the PATH like this
>> >> /usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/home/luna
>> tic/.local/bin:/home/lunatic/bin
>> >> I'm still getting the same error
>> >> -- vijay
>> >> On 18 March 2018 at 16:01, Gedare Bloom <gedare at rtems.org> wrote:
>> >>> On Sat, Mar 17, 2018 at 12:37 PM, Joel Sherrill <joel at rtems.org>
>> wrote:
>> >>> > I answered what I think the cause is on another thread.
>> >>> > Take the ancient RTEMS autotools out of your PATH while building
>> qemu.
>> >>> > Use a
>> >>> > PATH without RTEMS tools in it. I think the ancient automake
>> version we
>> >>> > use
>> >>> > must have --help which help2man can't parse.
>> >>> I don't think this is the solution, because the failure happens while
>> >>> trying to build the autotools.
>> > What happens when you run on the command line:
>> > $> automake-1.12 --help
>> I get the help(along with options and usage) printed on the screen .
>> I suspect it is related to:
>> https://lists.gnu.org/archive/html/bug-automake/2017-06/msg00003.html
>> The problem is how perl is handling regex escaping where a newer perl
>> causes an error when an older perl caused a warning. Since we are kind
>> of stuck with an older automake, you should install an older perl.
>> Apparently, something before 5.26.0 should work I guess.
>> -Gedare
>> >>> > On Mar 17, 2018 11:34 AM, "Vijay Kumar Banerjee"
>> >>> > wrote:
>> >>> >> hello ,
>> >>> >> As suggested by Gedare , I have started this thread on the build
>> error
>> >>> >> that I'm getting .
>> >>> >> I'm getting automake-1.12.6-x86_64-linux-gnu-1 building error
>> while
>> >>> >> trying
>> >>> >> to build autotools from rsb
>> >>> >> I'm using fedora 27 64bit .
>> >>> >> P.S: the error report is attached
>> >>> >> -- vijay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180318/2da4508f/attachment-0002.html>
RTEMS Tools Project - Source Builder Error Report
 Build: error: building automake-1.12.6-x86_64-linux-gnu-1
 Command Line: ../source-builder/sb-set-builder --prefix=/home/lunatic/development/rtems/5 devel/autotools
 Python: 2.7.14 (default, Feb 27 2018, 20:43:24) [GCC 7.3.1 20180130 (Red Hat 7.3.1-2)]
 git://git.rtems.org/rtems-source-builder.git/origin/4b3e0f8e3d6998b84a2503dd2e11578989b1672b
 Linux lunatic 4.15.8-300.fc27.x86_64 #1 SMP Fri Mar 9 18:11:36 UTC 2018 x86_64
Tail of the build log:
-rwxr-xr-x 1000/1000      1033 2012-12-14 22:28 automake-1.12.6/t/canon2.sh
-rwxr-xr-x 1000/1000       958 2012-12-14 22:28 automake-1.12.6/t/upc2.sh
-rwxr-xr-x 1000/1000      2043 2012-12-14 22:28 automake-1.12.6/t/exeext4.sh
-rwxr-xr-x 1000/1000      1632 2012-12-14 22:28 automake-1.12.6/t/doc-parsing-buglets-tabs.sh
-rwxr-xr-x 1000/1000      1377 2012-12-14 22:28 automake-1.12.6/t/gettext3.sh
-rwxr-xr-x 1000/1000      1684 2012-12-14 22:28 automake-1.12.6/t/distcheck-configure-flags.sh
-rwxr-xr-x 1000/1000      1058 2012-12-14 22:28 automake-1.12.6/t/subobj2.sh
-rwxr-xr-x 1000/1000      1905 2012-12-14 22:28 automake-1.12.6/t/silent.sh
-rwxr-xr-x 1000/1000      2223 2012-12-14 22:28 automake-1.12.6/t/yacc-subdir.sh
-rwxr-xr-x 1000/1000      3406 2012-12-14 22:28 automake-1.12.6/t/dist-auxdir-many-subdirs.sh
-r-xr-xr-x 1000/1000       448 2012-12-15 15:04 automake-1.12.6/t/compile3-w.sh
-rwxr-xr-x 1000/1000      2013 2012-12-14 22:28 automake-1.12.6/t/aclocal-install-mkdir.sh
-rwxr-xr-x 1000/1000       966 2012-12-14 22:28 automake-1.12.6/t/order.sh
-rwxr-xr-x 1000/1000      1946 2012-12-14 22:28 automake-1.12.6/t/remake-maintainer-mode.sh
-rwxr-xr-x 1000/1000      2152 2012-12-14 22:28 automake-1.12.6/t/silent7.sh
-rwxr-xr-x 1000/1000      2233 2012-12-14 22:28 automake-1.12.6/t/instdir-prog.sh
-rwxr-xr-x 1000/1000      1234 2012-12-14 22:28 automake-1.12.6/t/man7.sh
-rwxr-xr-x 1000/1000      1001 2012-12-14 22:28 automake-1.12.6/t/subdir-cond-err.sh
-rwxr-xr-x 1000/1000      2973 2012-12-14 22:28 automake-1.12.6/t/cxx-lt-demo.sh
-rwxr-xr-x 1000/1000       989 2012-12-14 22:28 automake-1.12.6/t/extra5.sh
-r-xr-xr-x 1000/1000       443 2012-12-15 15:04 automake-1.12.6/t/tap-more-w.sh
-rwxr-xr-x 1000/1000      3150 2012-12-14 01:27 automake-1.12.6/t/testsuite-summary-count.sh
-rwxr-xr-x 1000/1000      1509 2012-12-14 22:28 automake-1.12.6/t/aclocal-path.sh
-rwxr-xr-x 1000/1000      1043 2012-12-14 22:28 automake-1.12.6/t/version6.sh
-rwxr-xr-x 1000/1000      2050 2012-12-14 22:28 automake-1.12.6/t/distcheck-configure-flags-am.sh
-rwxr-xr-x 1000/1000      1577 2012-12-14 22:28 automake-1.12.6/t/tests-environment-backcompat.sh
-rwxr-xr-x 1000/1000      2966 2012-12-14 22:28 automake-1.12.6/t/backcompat5.sh
-rwxr-xr-x 1000/1000       970 2012-12-14 22:28 automake-1.12.6/t/gcj2.sh
-rwxr-xr-x 1000/1000      1561 2012-12-14 22:28 automake-1.12.6/t/ccnoco3.sh
-r-xr-xr-x 1000/1000       218 2012-12-15 15:04 automake-1.12.6/t/depcomp-lt-makedepend.tap
-rwxr-xr-x 1000/1000      1323 2012-12-14 22:28 automake-1.12.6/t/pr279.sh
-r-xr-xr-x 1000/1000       201 2012-12-15 15:04 automake-1.12.6/t/depcomp-lt-cpp.tap
-rwxr-xr-x 1000/1000      1436 2012-12-14 22:28 automake-1.12.6/t/cond21.sh
-rwxr-xr-x 1000/1000      1651 2012-12-14 22:28 automake-1.12.6/t/alpha.sh
-rwxr-xr-x 1000/1000      1577 2012-12-14 22:28 automake-1.12.6/t/parallel-tests-concurrency-2.sh
-rwxr-xr-x 1000/1000      1135 2012-12-14 22:28 automake-1.12.6/t/cond20.sh
-rwxr-xr-x 1000/1000      1050 2012-12-14 22:28 automake-1.12.6/t/tar2.sh
-rwxr-xr-x 1000/1000       997 2012-12-14 22:28 automake-1.12.6/t/cond28.sh
-rwxr-xr-x 1000/1000      2369 2012-12-14 22:28 automake-1.12.6/t/libtool7.sh
-rwxr-xr-x 1000/1000      1376 2012-12-14 22:28 automake-1.12.6/t/cond18.sh
-rwxr-xr-x 1000/1000      1818 2012-12-14 15:13 automake-1.12.6/t/vala-headers.sh
-rwxr-xr-x 1000/1000      1676 2012-12-14 22:28 automake-1.12.6/t/java-clean.sh
-rwxr-xr-x 1000/1000      1290 2012-12-14 22:28 automake-1.12.6/t/specflg6.sh
-rwxr-xr-x 1000/1000      1856 2012-12-14 22:28 automake-1.12.6/t/output7.sh
-rwxr-xr-x 1000/1000      1604 2012-12-14 22:28 automake-1.12.6/t/py-compile-basedir.sh
-rwxr-xr-x 1000/1000      1724 2012-12-14 22:28 automake-1.12.6/t/txinfo24.sh
-rwxr-xr-x 1000/1000      1928 2012-12-14 22:28 automake-1.12.6/t/txinfo28.sh
-rwxr-xr-x 1000/1000      2310 2012-12-14 22:28 automake-1.12.6/t/suffix10.tap
-rwxr-xr-x 1000/1000      1090 2012-12-14 22:28 automake-1.12.6/t/tap-planskip-later-errors.sh
-rwxr-xr-x 1000/1000       945 2012-12-14 22:28 automake-1.12.6/t/ar-lib7.sh
-rwxr-xr-x 1000/1000      1481 2012-12-14 22:28 automake-1.12.6/t/dist-auxfile-2.sh
-rwxr-xr-x 1000/1000      1399 2012-12-14 22:28 automake-1.12.6/t/tap-empty.sh
-rwxr-xr-x 1000/1000      1427 2012-12-14 22:28 automake-1.12.6/t/suffix9.sh
-rwxr-xr-x 1000/1000      1523 2012-12-14 22:28 automake-1.12.6/t/license.sh
-rwxr-xr-x 1000/1000      1372 2012-12-14 22:28 automake-1.12.6/t/tap-negative-numbers.sh
-rwxr-xr-x 1000/1000      1411 2012-12-14 22:28 automake-1.12.6/t/colon7.sh
-rwxr-xr-x 1000/1000      2192 2012-12-14 22:28 automake-1.12.6/t/primary-prefix-couples-documented-valid.sh
-rwxr-xr-x 1000/1000      4034 2012-12-14 22:28 automake-1.12.6/t/txinfo21.sh
-rwxr-xr-x 1000/1000      1942 2012-12-14 15:13 automake-1.12.6/t/vala-per-target-flags.sh
-rwxr-xr-x 1000/1000      1639 2012-12-14 22:28 automake-1.12.6/t/suffix-custom-subobj-and-specflg.sh
-rwxr-xr-x 1000/1000       909 2012-12-14 22:28 automake-1.12.6/t/prefix.sh
-rwxr-xr-x 1000/1000      1150 2012-12-14 22:28 automake-1.12.6/t/cond10.sh
-r-xr-xr-x 1000/1000       499 2012-12-15 15:04 automake-1.12.6/t/tap-planskip-unplanned-w.sh
-rwxr-xr-x 1000/1000      1765 2012-12-14 22:28 automake-1.12.6/t/aclocal-install-fail.sh
-r-xr-xr-x 1000/1000       496 2012-12-15 15:04 automake-1.12.6/t/check-tests-in-builddir-w.sh
-rwxr-xr-x 1000/1000       928 2012-12-14 22:28 automake-1.12.6/t/backsl3.sh
-rwxr-xr-x 1000/1000       872 2012-12-14 22:28 automake-1.12.6/t/comment.sh
-rwxr-xr-x 1000/1000      2501 2012-12-14 22:28 automake-1.12.6/t/dejagnu4.sh
-rwxr-xr-x 1000/1000      2387 2012-12-14 22:28 automake-1.12.6/t/yacc-nodist.sh
-rwxr-xr-x 1000/1000      1355 2012-12-14 22:28 automake-1.12.6/t/link_dist.sh
-rwxr-xr-x 1000/1000      2284 2012-12-14 22:28 automake-1.12.6/t/cond39.sh
-rwxr-xr-x 1000/1000      2539 2012-12-14 22:28 automake-1.12.6/t/vartypo2.sh
-rwxr-xr-x 1000/1000       928 2012-12-14 22:28 automake-1.12.6/t/exdir.sh
-rwxr-xr-x 1000/1000      1040 2012-12-14 22:28 automake-1.12.6/t/nodep.sh
-rwxr-xr-x 1000/1000      1695 2012-12-14 22:28 automake-1.12.6/t/suffix-chain.tap
-rwxr-xr-x 1000/1000      1039 2012-12-14 22:28 automake-1.12.6/t/comment3.sh
-rwxr-xr-x 1000/1000      1404 2012-12-14 22:28 automake-1.12.6/t/werror2.sh
-rwxr-xr-x 1000/1000      1096 2012-12-14 22:28 automake-1.12.6/t/cond44.sh
-r-xr-xr-x 1000/1000       471 2012-12-15 15:04 automake-1.12.6/t/tap-msg0-result-w.sh
-rwxr-xr-x 1000/1000      1600 2012-12-14 22:28 automake-1.12.6/t/acloca13.sh
-rwxr-xr-x 1000/1000      1647 2012-12-14 22:28 automake-1.12.6/t/suffix5.sh
-rwxr-xr-x 1000/1000      1854 2012-12-14 22:28 automake-1.12.6/t/am-tests-environment.sh
-rwxr-xr-x 1000/1000      1219 2012-12-14 22:28 automake-1.12.6/t/libobj15b.sh
-rwxr-xr-x 1000/1000       847 2012-12-14 22:28 automake-1.12.6/t/badopt.sh
-rwxr-xr-x 1000/1000      5751 2012-12-14 22:28 automake-1.12.6/t/silent-many-gcc.sh
-rwxr-xr-x 1000/1000      1193 2012-12-14 22:28 automake-1.12.6/t/ldadd.sh
-rwxr-xr-x 1000/1000      1253 2012-12-14 22:28 automake-1.12.6/t/hdr-vars-defined-once.sh
-rwxr-xr-x 1000/1000      1535 2012-12-14 22:28 automake-1.12.6/t/txinfo26.sh
-r-xr-xr-x 1000/1000       468 2012-12-15 15:04 automake-1.12.6/t/check-subst-prog-w.sh
-rwxr-xr-x 1000/1000      2579 2012-12-14 22:28 automake-1.12.6/t/stdlib2.sh
-rwxr-xr-x 1000/1000      1782 2012-12-14 22:28 automake-1.12.6/t/ansi2knr-no-more.sh
-rwxr-xr-x 1000/1000      1585 2012-12-14 22:28 automake-1.12.6/t/ltlibsrc.sh
-rwxr-xr-x 1000/1000      1193 2012-12-14 22:28 automake-1.12.6/t/subobj10.sh
-rwxr-xr-x 1000/1000      4573 2012-12-14 22:28 automake-1.12.6/t/maken3.sh
-r-xr-xr-x 1000/1000       471 2012-12-15 15:04 automake-1.12.6/t/tap-xfail-tests-w.sh
-rwxr-xr-x 1000/1000      1438 2012-12-14 22:28 automake-1.12.6/t/pr279-2.sh
-rwxr-xr-x 1000/1000      6757 2012-12-14 22:28 automake-1.12.6/t/silent-many-generic.sh
-rwxr-xr-x 1000/1000      3799 2012-12-14 22:28 automake-1.12.6/t/cscope.tap
-rwxr-xr-x 1000/1000      1618 2012-12-14 22:28 automake-1.12.6/t/self-check-explicit-skips.sh
-rwxr-xr-x 1000/1000      1348 2012-12-14 22:28 automake-1.12.6/t/posixsubst-extradist.sh
-rwxr-xr-x 1000/1000      1327 2012-12-14 22:28 automake-1.12.6/t/acloca19.sh
-rwxr-xr-x 1000/1000      2064 2012-12-14 01:32 automake-1.12.6/t/vala-vpath.sh
-rwxr-xr-x 1000/1000      2724 2012-12-14 01:32 automake-1.12.6/t/vala-mix2.sh
-r-xr-xr-x 1000/1000       432 2012-12-15 15:04 automake-1.12.6/t/check11-w.sh
-r-xr-xr-x 1000/1000       488 2012-12-15 15:04 automake-1.12.6/t/check-exported-srcdir-w.sh
-rwxr-xr-x 1000/1000      1400 2012-12-14 01:27 automake-1.12.6/t/self-check-shell-no-trail-bslash.sh
-rwxr-xr-x 1000/1000      1540 2012-12-14 22:28 automake-1.12.6/t/programs-primary-rewritten.sh
-rwxr-xr-x 1000/1000      1340 2012-12-14 22:28 automake-1.12.6/t/link_fccxx.sh
-rwxr-xr-x 1000/1000      3351 2012-12-14 22:28 automake-1.12.6/t/backcompat3.sh
-rwxr-xr-x 1000/1000      2503 2012-12-14 22:28 automake-1.12.6/t/aclocal-acdir.sh
-rwxr-xr-x 1000/1000      1359 2012-12-14 22:28 automake-1.12.6/t/init.sh
-rwxr-xr-x 1000/1000      1838 2012-12-14 22:28 automake-1.12.6/t/cond19.sh
-r-xr-xr-x 1000/1000       491 2012-12-15 15:04 automake-1.12.6/t/tap-planskip-bailout-w.sh
-rwxr-xr-x 1000/1000      1403 2012-12-14 22:28 automake-1.12.6/t/autodist-acconfig-no-subdir.sh
-rwxr-xr-x 1000/1000      2451 2012-12-14 22:28 automake-1.12.6/t/remake-gnulib-add-header.sh
-rwxr-xr-x 1000/1000      1541 2012-12-14 22:28 automake-1.12.6/t/yflags-var-expand.sh
-rwxr-xr-x 1000/1000      1321 2012-12-14 22:28 automake-1.12.6/t/link_fcxx.sh
-rwxr-xr-x 1000/1000      1688 2012-12-14 22:28 automake-1.12.6/t/dirlist.sh
-rwxr-xr-x 1000/1000      1835 2012-12-14 22:28 automake-1.12.6/t/tap-xfail-tests.sh
-r-xr-xr-x 1000/1000       455 2012-12-15 15:04 automake-1.12.6/t/tap-bailout-w.sh
-rwxr-xr-x 1000/1000      2912 2012-12-14 22:28 automake-1.12.6/t/acloca18.sh
-rwxr-xr-x 1000/1000      1419 2012-12-14 22:28 automake-1.12.6/t/nodep2.sh
-rwxr-xr-x 1000/1000      2976 2012-12-14 22:28 automake-1.12.6/t/instdir-no-empty.sh
-rwxr-xr-x 1000/1000      1302 2012-12-14 22:28 automake-1.12.6/t/aclocal3.sh
-rwxr-xr-x 1000/1000      1735 2012-12-14 22:28 automake-1.12.6/t/aclocal4.sh
-r-xr-xr-x 1000/1000       519 2012-12-15 15:04 automake-1.12.6/t/tap-with-and-without-number-w.sh
-rwxr-xr-x 1000/1000      2387 2012-12-14 22:28 automake-1.12.6/t/acloca10.sh
-rwxr-xr-x 1000/1000      2206 2012-12-14 22:28 automake-1.12.6/t/parallel-tests-driver-install.sh
-rwxr-xr-x 1000/1000      1017 2012-12-14 22:28 automake-1.12.6/t/javasubst.sh
-rwxr-xr-x 1000/1000      2054 2012-12-14 22:28 automake-1.12.6/t/yaccvpath.sh
-rwxr-xr-x 1000/1000      1501 2012-12-14 22:28 automake-1.12.6/t/test-missing2.sh
-rwxr-xr-x 1000/1000      1626 2012-12-14 22:28 automake-1.12.6/t/subobj11c.sh
-rwxr-xr-x 1000/1000      1225 2012-12-14 22:28 automake-1.12.6/t/compile_f90_c_cxx.sh
-rwxr-xr-x 1000/1000      1371 2012-12-14 22:28 automake-1.12.6/t/tap-ambiguous-directive.sh
-rwxr-xr-x 1000/1000      3956 2012-12-14 22:28 automake-1.12.6/t/test-driver-custom-xfail-tests.sh
-rwxr-xr-x 1000/1000      2065 2012-12-14 22:28 automake-1.12.6/t/dist-missing-included-m4.sh
-rwxr-xr-x 1000/1000      2054 2012-12-14 22:28 automake-1.12.6/t/check4.sh
-rwxr-xr-x 1000/1000      2664 2012-12-14 22:28 automake-1.12.6/t/remake-after-makefile-am.sh
-rwxr-xr-x 1000/1000      1158 2012-12-14 22:28 automake-1.12.6/t/libtool5.sh
-rwxr-xr-x 1000/1000      1035 2012-12-14 22:28 automake-1.12.6/t/libobj3.sh
-rwxr-xr-x 1000/1000      1043 2012-12-14 22:28 automake-1.12.6/t/cxxlibobj.sh
-rwxr-xr-x 1000/1000      3427 2012-12-14 22:28 automake-1.12.6/t/spy.sh
-rwxr-xr-x 1000/1000      2195 2012-12-14 22:28 automake-1.12.6/t/yacc-dist-nobuild-subdir.sh
-rwxr-xr-x 1000/1000      2080 2012-12-14 22:28 automake-1.12.6/t/yaccpp.sh
-rwxr-xr-x 1000/1000      1214 2012-12-14 22:28 automake-1.12.6/t/cond43.sh
-rwxr-xr-x 1000/1000      2149 2012-12-14 22:28 automake-1.12.6/t/txinfo16.sh
-rwxr-xr-x 1000/1000      2554 2012-12-14 01:32 automake-1.12.6/t/vala-mix.sh
-rwxr-xr-x 1000/1000      2613 2012-12-14 22:28 automake-1.12.6/t/subdir-add2-pr46.sh
-rwxr-xr-x 1000/1000      2182 2012-12-14 22:28 automake-1.12.6/t/python10.sh
-rwxr-xr-x 1000/1000      2106 2012-12-14 22:28 automake-1.12.6/t/fort4.sh
-rwxr-xr-x 1000/1000      1935 2012-12-14 22:28 automake-1.12.6/t/conffile-leading-dot.sh
-rwxr-xr-x 1000/1000      1605 2012-12-14 22:28 automake-1.12.6/t/aclocal.sh
-rwxr-xr-x 1000/1000      1682 2012-12-14 22:28 automake-1.12.6/t/mmode.sh
-rwxr-xr-x 1000/1000      1113 2012-12-14 22:28 automake-1.12.6/t/alloca2.sh
-r-xr-xr-x 1000/1000       479 2012-12-15 15:04 automake-1.12.6/t/tap-driver-stderr-w.sh
-rwxr-xr-x 1000/1000      1141 2012-12-14 22:28 automake-1.12.6/t/mdate4.sh
-r-xr-xr-x 1000/1000       471 2012-12-15 15:04 automake-1.12.6/t/tap-plan-middle-w.sh
-rwxr-xr-x 1000/1000      2580 2012-12-14 22:28 automake-1.12.6/t/subdir-add-pr46.sh
-rwxr-xr-x 1000/1000      1363 2012-12-14 22:28 automake-1.12.6/t/java-no-duplicate.sh
-rwxr-xr-x 1000/1000      3362 2012-12-14 22:28 automake-1.12.6/t/parallel-tests2.sh
-rwxr-xr-x 1000/1000      1703 2012-12-14 22:28 automake-1.12.6/t/nodef.sh
-rwxr-xr-x 1000/1000      1311 2012-12-14 22:28 automake-1.12.6/t/link_f_only.sh
-rwxr-xr-x 1000/1000      1848 2012-12-14 22:28 automake-1.12.6/t/deleted-am.sh
-rwxr-xr-x 1000/1000      1178 2012-12-14 22:28 automake-1.12.6/t/tap-msg0-bailout.sh
-rwxr-xr-x 1000/1000       926 2012-12-14 22:28 automake-1.12.6/t/txinfo6.sh
-r-xr-xr-x 1000/1000       515 2012-12-15 15:04 automake-1.12.6/t/tap-no-merge-stdout-stderr-w.sh
-rwxr-xr-x 1000/1000      1429 2012-12-14 22:28 automake-1.12.6/t/missing4.sh
-rwxr-xr-x 1000/1000      1445 2012-12-14 22:28 automake-1.12.6/t/gnuwarn.sh
-rwxr-xr-x 1000/1000      2082 2012-12-14 22:28 automake-1.12.6/t/aclocal-path-install-serial.sh
-rwxr-xr-x 1000/1000      1547 2012-12-14 22:28 automake-1.12.6/t/output12.sh
-rwxr-xr-x 1000/1000      2095 2012-12-14 22:28 automake-1.12.6/t/subobj11a.sh
-rwxr-xr-x 1000/1000      1143 2012-12-14 22:28 automake-1.12.6/t/depend6.sh
-rwxr-xr-x 1000/1000      1490 2012-12-14 22:28 automake-1.12.6/t/confsub.sh
-rwxr-xr-x 1000/1000       936 2012-12-14 22:28 automake-1.12.6/t/spell.sh
-rwxr-xr-x 1000/1000      1050 2012-12-14 22:28 automake-1.12.6/t/unused.sh
-rwxr-xr-x 1000/1000      1905 2012-12-14 22:28 automake-1.12.6/t/python-dist.sh
-rwxr-xr-x 1000/1000      1403 2012-12-14 22:28 automake-1.12.6/t/empty-sources-primary.tap
-rwxr-xr-x 1000/1000      1734 2012-12-14 22:28 automake-1.12.6/t/pluseq9.sh
-rwxr-xr-x 1000/1000       945 2012-12-14 22:28 automake-1.12.6/t/libobj4.sh
-r-xr-xr-x 1000/1000       428 2012-12-15 15:04 automake-1.12.6/t/check4-w.sh
-rwxr-xr-x 1000/1000      1466 2012-12-14 22:28 automake-1.12.6/t/libtoo10.sh
-rwxr-xr-x 1000/1000      1106 2012-12-14 22:28 automake-1.12.6/t/pr72.sh
-rwxr-xr-x 1000/1000      1349 2012-12-14 22:28 automake-1.12.6/t/dejagnu6.sh
-rwxr-xr-x 1000/1000       983 2012-12-14 22:28 automake-1.12.6/t/override-html.sh
-rwxr-xr-x 1000/1000      2449 2012-12-14 22:28 automake-1.12.6/t/check-tests-in-builddir.sh
-rwxr-xr-x 1000/1000      2890 2012-12-14 22:28 automake-1.12.6/t/am-missing-prog.sh
-rwxr-xr-x 1000/1000      2934 2012-12-14 22:28 automake-1.12.6/t/aclocal7.sh
-rwxr-xr-x 1000/1000      1452 2012-12-14 22:28 automake-1.12.6/t/cygnus-no-installinfo.sh
-rwxr-xr-x 1000/1000      1247 2012-12-14 22:28 automake-1.12.6/t/pr266.sh
-rwxr-xr-x 1000/1000      1355 2012-12-14 22:28 automake-1.12.6/t/auxdir8.sh
-rwxr-xr-x 1000/1000      2080 2012-12-14 22:28 automake-1.12.6/t/self-check-is_newest.tap
-rwxr-xr-x 1000/1000      1660 2012-12-14 22:28 automake-1.12.6/t/cygnus-dependency-tracking.sh
-rwxr-xr-x 1000/1000      3854 2012-12-14 22:28 automake-1.12.6/t/parallel-tests-interrupt.tap
-rwxr-xr-x 1000/1000      1035 2012-12-14 22:28 automake-1.12.6/t/badline.sh
-rwxr-xr-x 1000/1000      1052 2012-12-14 22:28 automake-1.12.6/t/ar3.sh
-rwxr-xr-x 1000/1000      2926 2012-12-14 22:28 automake-1.12.6/t/location.sh
-rwxr-xr-x 1000/1000      1392 2012-12-14 22:28 automake-1.12.6/t/substtarg.sh
-rwxr-xr-x 1000/1000      1289 2012-12-14 22:28 automake-1.12.6/t/instsh3.sh
-rw-r--r-- 1000/1000    256772 2012-12-14 22:28 automake-1.12.6/automake.in
drwxr-xr-x 1000/1000         0 2012-12-15 22:26 automake-1.12.6/doc/
drwxr-xr-x 1000/1000         0 2012-12-15 22:25 automake-1.12.6/doc/amhello/
-rw-r--r-- 1000/1000       225 2012-12-14 01:27 automake-1.12.6/doc/amhello/Makefile.am
-rw-r--r-- 1000/1000       100 2012-12-14 01:17 automake-1.12.6/doc/amhello/README
drwxr-xr-x 1000/1000         0 2012-12-15 22:25 automake-1.12.6/doc/amhello/src/
-rw-r--r-- 1000/1000       232 2012-12-14 01:27 automake-1.12.6/doc/amhello/src/Makefile.am
-rw-r--r-- 1000/1000       328 2012-12-14 01:27 automake-1.12.6/doc/amhello/src/main.c
-rw-r--r-- 1000/1000       384 2012-12-14 01:27 automake-1.12.6/doc/amhello/configure.ac
-rw-r--r-- 1000/1000    233720 2012-12-15 15:04 automake-1.12.6/doc/automake.info-2
-rw-r--r-- 1000/1000      7679 2012-12-15 15:04 automake-1.12.6/doc/automake.info
-rw-r--r-- 1000/1000     75807 2012-12-15 15:05 automake-1.12.6/doc/amhello-1.0.tar.gz
-rw-r--r-- 1000/1000     75111 2012-12-15 15:04 automake-1.12.6/doc/automake.info-3
-rw-r--r-- 1000/1000     78473 2012-12-15 15:05 automake-1.12.6/doc/automake-history.info
-rw-r--r-- 1000/1000     23549 2012-12-14 01:27 automake-1.12.6/doc/fdl.texi
-rw-r--r-- 1000/1000    299158 2012-12-15 15:04 automake-1.12.6/doc/automake.info-1
-rw-r--r-- 1000/1000    515710 2012-12-14 22:28 automake-1.12.6/doc/automake.texi
-rw-r--r-- 1000/1000     52598 2012-12-14 01:27 automake-1.12.6/doc/automake-history.texi
-rw-r--r-- 1000/1000       103 2012-12-15 15:04 automake-1.12.6/doc/version.texi
-rw-r--r-- 1000/1000       103 2012-12-15 15:04 automake-1.12.6/doc/stamp-vti
-rwxr-xr-x 1000/1000     16688 2012-12-14 01:27 automake-1.12.6/doc/help2man
-rw-r--r-- 1000/1000      1348 2012-12-15 15:04 automake-1.12.6/aclocal.m4
-rw-r--r-- 1000/1000     96774 2012-12-14 22:28 automake-1.12.6/NEWS
+ cd automake-1.12.6
+ /bin/chmod -R a+rX,g-w,o-w .
+ cd /home/lunatic/development/rtems/rsb/rtems/build/automake-1.12.6-x86_64-linux-gnu-1
+ SB_CXC=no
+ echo '==> clean %{buildroot}: /home/lunatic/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-linux-gnu-1-root-root'
+ /bin/rm -rf /home/lunatic/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-linux-gnu-1-root-root
+ /bin/mkdir -p /home/lunatic/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-linux-gnu-1-root-root
+ echo '==> %build:'
==> %build:
++ pwd
+ build_top=/home/lunatic/development/rtems/rsb/rtems/build/automake-1.12.6-x86_64-linux-gnu-1
+ export PATH=/home/lunatic/development/rtems/rsb/rtems/build/tmp/sb-root/home/lunatic/development/rtems/5/bin:/home/lunatic/development/rtems/rsb/source-builder:/home/lunatic/development/rtems/rsb/rtems/build/tmp/sb-root-cxc/devel/autotools-internal.bset/home/lunatic/development/rtems/5/bin:/home/lunatic/development/rtems/rsb/rtems/build/tmp/sb-root/devel/autotools-internal.bset/home/lunatic/development/rtems/5/bin:/sbin:/bin:/usr/sbin:/usr/bin
+ PATH=/home/lunatic/development/rtems/rsb/rtems/build/tmp/sb-root/home/lunatic/development/rtems/5/bin:/home/lunatic/development/rtems/rsb/source-builder:/home/lunatic/development/rtems/rsb/rtems/build/tmp/sb-root-cxc/devel/autotools-internal.bset/home/lunatic/development/rtems/5/bin:/home/lunatic/development/rtems/rsb/rtems/build/tmp/sb-root/devel/autotools-internal.bset/home/lunatic/development/rtems/5/bin:/sbin:/bin:/usr/sbin:/usr/bin
+ test yes = yes
+ am_prefix=/home/lunatic/development/rtems/rsb/rtems/build/tmp/sb-root/home/lunatic/development/rtems/5
+ test x86_64-linux-gnu '!=' x86_64-linux-gnu
+ export CFLAGS CFLAGS_FOR_BUILD CC
+ CFLAGS='-O2 -pipe -I/home/lunatic/development/rtems/rsb/rtems/build/tmp/sb-root/devel/autotools-internal.bset/home/lunatic/development/rtems/5/include '
+ ./configure --build=x86_64-linux-gnu --host=x86_64-linux-gnu --verbose --prefix=/home/lunatic/development/rtems/rsb/rtems/build/tmp/sb-root/home/lunatic/development/rtems/5
checking whether make supports nested variables... yes
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking for a BSD-compatible install... /bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether ln -s works... yes
checking for perl... /bin/perl
checking whether /bin/perl supports ithreads... yes
checking for tex... no
checking for yacc... no
checking for byacc... no
checking for bison... bison -y
checking for lex... lex
checking whether autoconf is installed... yes
checking whether autoconf works... yes
checking whether autoconf is recent enough... yes
checking whether ln works... yes
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
configure: will now look for a sturdy POSIX shell, for our testsuite
checking for sh... /bin/sh
checking for sh5... no
checking for dash... no
checking for ash... no
checking for bash... /bin/bash
checking for zsh... no
checking for ksh... no
checking for pdksh... no
checking whether /bin/sh supports $(cmd)... yes
checking whether /bin/sh supports $((expr))... yes
checking whether /bin/sh supports ${#var}... yes
checking whether /bin/sh supports ${var#glob} and ${var%glob}... yes
checking whether /bin/sh preserves exit traps with "set -e"... yes
checking whether /bin/sh can define exit traps in a shell function... yes
checking whether /bin/sh corrupts stderr with "set -x"... no
checking whether /bin/sh can return early from "dot-sourced" files... yes
checking whether /bin/sh supports alias named like shell builtins... yes
checking whether /bin/sh supports "test -e"... yes
configure: shell /bin/sh is good enough, stop looking
configure: will use /bin/sh as the testsuite shell
configure: will now look for generic compilers
checking for x86_64-linux-gnu-cc... no
checking for x86_64-linux-gnu-gcc... no
checking for cc... cc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking for x86_64-linux-gnu-aCC... no
checking for x86_64-linux-gnu-CC... no
checking for x86_64-linux-gnu-FCC... no
checking for x86_64-linux-gnu-KCC... no
checking for x86_64-linux-gnu-RCC... no
checking for x86_64-linux-gnu-xlC_r... no
checking for x86_64-linux-gnu-xlC... no
checking for x86_64-linux-gnu-c++... no
checking for x86_64-linux-gnu-cxx... no
checking for x86_64-linux-gnu-cc++... no
checking for x86_64-linux-gnu-gpp... no
checking for x86_64-linux-gnu-g++... no
checking for aCC... no
checking for CC... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking for c++... c++
checking whether the C++ compiler works... yes
checking for C++ compiler default output file name... a.out
checking whether we are using the GNU C++ compiler... yes
checking whether c++ accepts -g... yes
checking for x86_64-linux-gnu-xlf95... no
checking for x86_64-linux-gnu-f95... no
checking for x86_64-linux-gnu-fort... no
checking for x86_64-linux-gnu-ifort... no
checking for x86_64-linux-gnu-ifc... no
checking for x86_64-linux-gnu-efc... no
checking for x86_64-linux-gnu-pgfortran... no
checking for x86_64-linux-gnu-pgf95... no
checking for x86_64-linux-gnu-lf95... no
checking for x86_64-linux-gnu-ftn... no
checking for x86_64-linux-gnu-nagfor... no
checking for x86_64-linux-gnu-xlf90... no
checking for x86_64-linux-gnu-f90... no
checking for x86_64-linux-gnu-pgf90... no
checking for x86_64-linux-gnu-pghpf... no
checking for x86_64-linux-gnu-epcf90... no
checking for x86_64-linux-gnu-g95... no
checking for x86_64-linux-gnu-gfortran... no
checking for xlf95... no
checking for f95... f95
checking whether the Fortran compiler works... yes
checking for Fortran compiler default output file name... a.out
checking whether we are using the GNU Fortran compiler... yes
checking whether f95 accepts -g... yes
checking for x86_64-linux-gnu-xlf... no
checking for x86_64-linux-gnu-f77... no
checking for x86_64-linux-gnu-frt... no
checking for x86_64-linux-gnu-pgf77... no
checking for x86_64-linux-gnu-cf77... no
checking for x86_64-linux-gnu-fort77... no
checking for x86_64-linux-gnu-fl32... no
checking for x86_64-linux-gnu-af77... no
checking for x86_64-linux-gnu-g77... no
checking for xlf... no
checking for f77... f77
checking whether the Fortran 77 compiler works... yes
checking for Fortran 77 compiler default output file name... a.out
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether f77 accepts -g... yes
configure: will now look for GNU compilers
configure: cc is already a GNU C compiler
configure: c++ is already a GNU C++ compiler
configure: f95 is already a GNU Fortran compiler
configure: f77 is already a GNU Fortran 77 compiler
checking for x86_64-linux-gnu-gcj... no
checking for gcj... no
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating t/wrap/aclocal-1.12
config.status: creating t/wrap/automake-1.12
+ make -j 4 all
  GEN      automake
  GEN      aclocal
  GEN      t/ax/shell-no-trail-bslash
  GEN      runtest
  GEN      doc/aclocal.1
  GEN      doc/automake.1
  GEN      lib/Automake/Config.pm
  GEN      t/ax/test-defs.sh
  GEN      doc/aclocal-1.12.1
  GEN      doc/automake-1.12.1
help2man: can't get `--help' info from automake-1.12
Try `--no-discard-stderr' if option outputs to stderr
make: *** [Makefile:4114: doc/automake-1.12.1] Error 255
make: *** Waiting for unfinished jobs....
shell cmd failed: /bin/sh -ex  /home/lunatic/development/rtems/rsb/rtems/build/automake-1.12.6-x86_64-linux-gnu-1/doit
