Improve coverage analysis toolset
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Sun Mar 25 19:37:34 UTC 2018
It's the last day before the deadline!
Please provide a final review of the proposal before submitting.
Thanks
-- vijay
On 24 March 2018 at 21:37, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> hello mentors and other developers of the community , there are only three
> days remaining to the GSoC proposal submission deadline.
> I request the mentors and everyone in the community who has experience in
> RTEMS, to please go through my proposal for Coverage Analysis tool
> improvement project , if they have time , and suggest any kind of
> improvements and changes .
> here is the link to the proposal
> https://docs.google.com/document/d/1UjCWE1ojrpDQLQ2fQqxHU0SCrLETl
> erxD6t0SOcQNLQ/edit?usp=sharing
> Thank you
> -- vijay
> On 22 March 2018 at 04:30, Joel Sherrill <joel at rtems.org> wrote:
>> Glad you have tests running. Hopefully as Cillian suggested, you can fix
>> the
>> remaining issues to see coverage.
>> We certainly need to get this merged if Chris is OK with it and it doesn't
>> break anything else.
>> I am reviewing proposals now. Seems to be a queue. :)
>> --joel
>> On Wed, Mar 21, 2018 at 4:42 AM, Vijay Kumar Banerjee <
>> vijaykumar9597 at gmail.com> wrote:
>>> Sir ,
>>> I have done the changes in the proposal , based on the comments in the
>>> google doc , please review it and suggest any further changes if required
>>> Thank you ,
>>> -- vijay
>>> P.S : the previous version is in parentheses , I will remove them after
>>> you review the changes .
>>> On 18 March 2018 at 16:05, Vijay Kumar Banerjee <
>>>> Thanks Cillian :)
>>>> It's great to see it running ,  I'll do some background reading about
>>>> RSB, and RTEMS-Tools along with the covoar code . And also work on my
>>>> python skills.
>>>> to try rtems-test on a bsp that runs gdb , I tried it on erc32 and that
>>>> also worked.
>>>> I'm also waiting for Joel and other mentors' review on my draft
>>>> proposal, so that I can also work on it and make any changes if needed.
>>>> Thanks .
>>>> -- vijay
>>>> On 18 March 2018 at 14:17, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> On 18 March 2018 at 06:47, Vijay Kumar Banerjee <
>>>>>> It worked !
>>>>> That's great!  That's the good news then. I was using an old leon3
>>>>> build and maybe some older Qemu too and I think that's why I didn't see any
>>>>> issues initially. I was hoping you could see the coverage running and the
>>>>> reports generated from that but it looks like the full update to the
>>>>> current master will be necessary to have a look. So until the parsing for
>>>>> the INI files is added to the coverage.py we won't see the coverage
>>>>> running. Unfortunately, I'm in the middle of exams until the following
>>>>> Monday so I won't be able to sink any more time into it until then. You can
>>>>> still figure out the RSB problem you're having and do some background
>>>>> reading, brush up on your Python skills, have a read of the covoar code
>>>>> https://github.com/RTEMS/rtems-tools/blob/master/tester/covo
>>>>> ar/covoar.cc
>>>>> just skim through, read the comments, get a sense of the what it's
>>>>> doing and in what order.
>>>>>> It's great to see it running ! I have attached the result .
>>>>>> -- vijay
>>>>>> On 18 March 2018 at 02:31, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>> wrote:
>>>>>>> On 17 March 2018 at 20:08, Vijay Kumar Banerjee <
>>>>>>>> yes it prints hello world
>>>>>>> Alright I've added an .ini for leon3-qemu to the current
>>>>>>> rtems-tools. Pull this branch
>>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>>>> and try
>>>>>>> $HOME/development/rtems/test/rtems-tools/tester/rtems-test
>>>>>>> --rtems-tools=$HOME/development/rtems/5 --log=coverage-analysis.log
>>>>>>> --rtems-bsp=leon3_qemu $HOME/development/rtems/leon3/
>>>>>>> sparc-rtems5/c/leon3/testsuites/samples
>>>>>>>> -- vijay
>>>>>>>> On 18 March 2018 at 01:31, Cillian O'Donnell <cpodonnell8 at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> If you run just one test by itself without rtems-test
>>>>>>>>> qemu-system-sparc -no-reboot -monitor null -serial stdio
>>>>>>>>> -nographic -M leon3_generic -kernel $HOME/development/rtems/leon3/
>>>>>>>>> sparc-rtems5/c/leon3/testsuites/samples/hello/hello.exe
>>>>>>>>> Does the hello world print out?
>>>>>>>>> On 17 March 2018 at 14:46, Vijay Kumar Banerjee <
>>>>>>>>>> I built it manually
>>>>>>>>>> the environment variable PATH looks like this
>>>>>>>>>> /home/lunatic/qemu/install/bin:/home/lunatic/development/rte
>>>>>>>>>> ms/5/bin:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/
>>>>>>>>>> home/lunatic/.local/bin:/home/lunatic/bin
>>>>>>>>>> I tried to run rtems-test again without --coverage , it gives the
>>>>>>>>>> same result
>>>>>>>>>> I have attached the log.
>>>>>>>>>> -- vijay
>>>>>>>>>> On 17 March 2018 at 00:55, Cillian O'Donnell <
>>>>>>>>>> cpodonnell8 at gmail.com> wrote:
>>>>>>>>>>> Yes this is something more than my build, I'll need someone a
>>>>>>>>>>> bit more expert in the RSB to step in there. In the meantime, lets just
>>>>>>>>>>> build couverture-qemu manually so we can see is everything else working.
>>>>>>>>>>> git clone https://github.com/AdaCore/qemu
>>>>>>>>>>> cd qemu
>>>>>>>>>>> ./configure --target-list=sparc-softmmu
>>>>>>>>>>> --prefix=$HOME/qemu/install --disable-docs --disable-virtfs --disable-werror
>>>>>>>>>>> make
>>>>>>>>>>> make install
>>>>>>>>>>> then add the prefix to $PATH in .bashrc as well like before.
>>>>>>>>>>> export PATH=$HOME/qemu/install/bin:$PATH
>>>>>>>>>>> Then run rtem-test and see what happens
>>>>>>>>>>> On 16 March 2018 at 19:13, Vijay Kumar Banerjee <
>>>>>>>>>>>> the same error comes when I try to build qemu from the
>>>>>>>>>>>> RTEMS/rtems-source-builder as well
>>>>>>>>>>>> is the issue coming from my system ? I'm using fedora 27 64bit
>>>>>>>>>>>> On 17 Mar 2018 12:39 a.m., "Vijay Kumar Banerjee" <
>>>>>>>>>>>>> yes , the same thing happens
>>>>>>>>>>>>> On 17 Mar 2018 12:13 a.m., "Cillian O'Donnell" <
>>>>>>>>>>>>>> If you build regular qemu with the RSB, does the same thing
>>>>>>>>>>>>>> happen?
>>>>>>>>>>>>>> Try
>>>>>>>>>>>>>> ../source-builder/sb-set-builder --log=qemu_log.txt
>>>>>>>>>>>>>> --prefix=$HOME/development/5 devel/qemu
>>>>>>>>>>>>>> On 16 March 2018 at 16:48, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>> still the same error
>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>> On 16 March 2018 at 21:39, Cillian O'Donnell <
>>>>>>>>>>>>>>>> Just checked and the build was failing because one of the
>>>>>>>>>>>>>>>> patches needed its hash to be updated to sha256. Just pushed that change.
>>>>>>>>>>>>>>>> The build finishes successfully on my end. Pull that change into
>>>>>>>>>>>>>>>> couverture-build branch and try it again. I'm not seeing any automake stuff
>>>>>>>>>>>>>>>> here, so just check that and let me know.
>>>>>>>>>>>>>>>> On 16 March 2018 at 14:59, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>> building couverture-qemu from rtems-source-builder (
>>>>>>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-source-builder/tr
>>>>>>>>>>>>>>>>> ee/couverture-build )
>>>>>>>>>>>>>>>>> gives error building auromake-1.12.6-x86_64-linux-gnu-1 .
>>>>>>>>>>>>>>>>> I have attached the error report .
>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>> On 15 March 2018 at 19:17, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>> On 15 March 2018 at 12:26, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>> It runs with a bunch of errors . I have attached the log
>>>>>>>>>>>>>>>>>>> file
>>>>>>>>>>>>>>>>>> Ok, I'm guessing you didn't set up Couverture-Qemu
>>>>>>>>>>>>>>>>>> (special version of qemu designed for generating extra trace data for
>>>>>>>>>>>>>>>>>> coverage analysis). That's what those errors are about. I have an RSB build
>>>>>>>>>>>>>>>>>> for that.
>>>>>>>>>>>>>>>>>> nell/rtems-source-builder/tree/couverture-build
>>>>>>>>>>>>>>>>>> and the instructions for building it are
>>>>>>>>>>>>>>>>>> https://devel.rtems.org/wiki/G
>>>>>>>>>>>>>>>>>> SoC/2017/coveragetools#BuildingCouverture-QemuwiththeRSB
>>>>>>>>>>>>>>>>>> I know what the other problem is too. I have a specific
>>>>>>>>>>>>>>>>>> environment variable defined for the path, sorry I can't even remember
>>>>>>>>>>>>>>>>>> putting it there, I thought that was automatically generated (probably
>>>>>>>>>>>>>>>>>> should be, another thing to add to the list :)... ). So wherever you stuck
>>>>>>>>>>>>>>>>>> the export path for where the rsb built the tools, in .bashrc or whatever
>>>>>>>>>>>>>>>>>> you're using. Also put something like:
>>>>>>>>>>>>>>>>>> export PATH=$HOME/development/rtems/5
>>>>>>>>>>>>>>>>>> /bin:$PATH
>>>>>>>>>>>>>>>>>> export PATH=$HOME/development/rtems/t
>>>>>>>>>>>>>>>>>> est/rtems-tools/build/tester/covoar:$PATH
>>>>>>>>>>>>>>>>>> or you could just copy covoar into the /bin directory
>>>>>>>>>>>>>>>>>> with all the other rsb tools gcc and all that, it'll find it either way.
>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 16:58, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>> Looks good. If you run the samples without coverage is
>>>>>>>>>>>>>>>>>>>> everything ok?
>>>>>>>>>>>>>>>>>>>> So removing --coverage and tacking on /samples
>>>>>>>>>>>>>>>>>>>> $HOME/development/rtems-tools/tester/rtems-test
>>>>>>>>>>>>>>>>>>>> --rtems-bsp=leon3-qemu --log=log-leon3.log --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>>>>>>>>>>>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>>>>>>>>>>>>>>>>>> Do the tests run?
>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 10:53, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>> I have attached the output of the ls of that directory
>>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 15:52, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 03:58, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>>>> hello ,
>>>>>>>>>>>>>>>>>>>>>>> as told by Joel , I started this thread to further
>>>>>>>>>>>>>>>>>>>>>>> discuss the coverage analysis toolset .
>>>>>>>>>>>>>>>>>>>>>>> Current status is , I'm trying to builld and run
>>>>>>>>>>>>>>>>>>>>>>> rtems-test from the coverage-merge branch of the previous GSoC student
>>>>>>>>>>>>>>>>>>>>>>> Cillian .
>>>>>>>>>>>>>>>>>>>>>>> nell/rtems-tools/tree/coverage-merge
>>>>>>>>>>>>>>>>>>>>>>> I'm getting an error that says .
>>>>>>>>>>>>>>>>>>>>>>>  "Covoar not found !"
>>>>>>>>>>>>>>>>>>>>>> It's supposed to find it in
>>>>>>>>>>>>>>>>>>>>>> rtems-tools/build/tester/covoar/ If it's in there it
>>>>>>>>>>>>>>>>>>>>>> should be fine. Can you show me the contents of that directory?
>>>>>>>>>>>>>>>>>>>>>> cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar
>>>>>>>>>>>>>>>>>>>>>> $ ls
>>>>>>>>>>>>>>>>>>>>>>> the Covoar appeared in rtems-tools/tester/covoar .
>>>>>>>>>>>>>>>>>>>>>>> Vijay
>>>>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>>>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180326/88aa2502/attachment-0002.html>
