[PATCH 9/9] telnetd: Use syslog() instead of printk()
Sebastian Huber
Tue May 1 09:03:17 UTC 2018
----- Am 1. Mai 2018 um 0:12 schrieb joel joel at rtems.org:
> Sorry to ask this but is there a syslog service that needs to be started
> before
> telnetd? Is there some dependency?
The syslog() function uses printf() for output without extra initialization.
> What's the rationale for this change?
printk() should not be used for normal output. The syslog9) is already used in other places of the telnetd and ftpd.
> On Mon, Apr 30, 2018 at 4:48 AM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> Update #3419.
>> cpukit/telnetd/pty.c | 10 ++++++++--
>> cpukit/telnetd/telnetd-init.c | 2 +-
>> 2 files changed, 9 insertions(+), 3 deletions(-)
>> diff --git a/cpukit/telnetd/pty.c b/cpukit/telnetd/pty.c
>> index d41de97d85..14d688018f 100644
>> --- a/cpukit/telnetd/pty.c
>> +++ b/cpukit/telnetd/pty.c
>> @@ -42,6 +42,7 @@
>> #include <stdio.h>
>> #include <stdlib.h>
>> #include <string.h>
>> +#include <syslog.h>
>> #include <unistd.h>
>> #define IAC_ESC 255
>> @@ -453,8 +454,13 @@ rtems_device_driver my_pty_initialize(
>> chmod(telnet_ptys[ndx].devname,0660);
>> chown(telnet_ptys[ndx].devname,2,0); /* tty,root*/
>> - printk("Device: /dev/pty%X../dev/pty%X (%d)pseudo-terminals
>> registered.\n",
>> - 0,rtems_telnetd_maximum_ptys-1,rtems_telnetd_maximum_ptys);
>> + syslog(
>> + LOG_KERN | LOG_INFO,
>> + "/dev/pty%X../dev/pty%X (%d) pseudo-terminals registered.\n",
>> + 0,
>> + rtems_telnetd_maximum_ptys - 1,
>> return RTEMS_SUCCESSFUL;
>> diff --git a/cpukit/telnetd/telnetd-init.c b/cpukit/telnetd/telnetd-init.c
>> index 760db41fcc..7762ad70ba 100644
>> --- a/cpukit/telnetd/telnetd-init.c
>> +++ b/cpukit/telnetd/telnetd-init.c
>> @@ -12,7 +12,7 @@
>> #include <rtems/telnetd.h>
>> -int rtems_initialize_telnetd( void )
>> +rtems_status_code rtems_telnetd_initialize( void )
>> return rtems_telnetd_start( &rtems_telnetd_config );
>> 2.12.3
>> devel mailing list
>> devel at rtems.org
