[PATCH 1/2] dhcpcd: Add rtems_dhcpcd_start()
Wed May 2 09:01:52 UTC 2018
Hi,
This is duplicating this code:
https://git.rtems.org/rtems-libbsd/tree/rtemsbsd/rtems/rtems-bsd-rc-conf-net.c#n632
It is a documented way to run DHCP [1].
The change no documentation and seems rather custom. This approach was a flaw
with the legacy stack and I would prefer we do not follow. It allows
applications to be created that use it which means we need to maintain this forever.
-1 from me.
[1] https://www.freebsd.org/doc/handbook/network-dhcp.html
On 2/5/18 5:47 pm, Sebastian Huber wrote:
>  dhcpcd/dhcpcd.c                                    | 46 +++++++++++++++
>  dhcpcd/namespace.h                                 |  4 ++
>  rtemsbsd/include/rtems/dhcpcd.h                    | 66 ++++++++++++++++++++++
>  .../include/rtems/bsd/test/default-network-init.h  | 37 ++----------
>  4 files changed, 121 insertions(+), 32 deletions(-)
>  create mode 100644 rtemsbsd/include/rtems/dhcpcd.h
> diff --git a/dhcpcd/dhcpcd.c b/dhcpcd/dhcpcd.c
> index 8074f3fc3..7cdd3c066 100644
> --- a/dhcpcd/dhcpcd.c
> +++ b/dhcpcd/dhcpcd.c
> @@ -1110,8 +1110,54 @@ signal_init(void (*func)(int, siginfo_t *, void *), sigset_t *oldset)
>  #endif
>  #ifdef __rtems__
> +#include <rtems/dhcpcd.h>
>  #include <rtems/libio.h>
> +#include <assert.h>
> +rtems_recursive_mutex dhcpcd_mutex =
> +    RTEMS_RECURSIVE_MUTEX_INITIALIZER("dhcpcd");
> +static bool dhcpcd_initialized;
> +static void
> +dhcpcd_task(rtems_task_argument arg)
> +	char *dhcpcd[] = { "dhcpcd", NULL };
> +	(void)arg;
> +	rtems_bsd_command_dhcpcd(RTEMS_BSD_ARGC(dhcpcd), dhcpcd);
> +	assert(0);
> +rtems_status_code
> +rtems_dhcpcd_start(rtems_task_priority priority)
> +	rtems_status_code sc;
> +	rtems_recursive_mutex_lock(&dhcpcd_mutex);
> +	if (!dhcpcd_initialized) {
> +		rtems_id id;
> +		sc = rtems_task_create(rtems_build_name('D', 'H', 'C', 'P'), priority,
> +		    2 * RTEMS_MINIMUM_STACK_SIZE, RTEMS_DEFAULT_MODES,
> +		    RTEMS_FLOATING_POINT, &id);
> +		if (sc == RTEMS_SUCCESSFUL) {
> +			dhcpcd_initialized = true;
> +			sc = rtems_task_start(id, dhcpcd_task, 0);
> +			assert(sc == RTEMS_SUCCESSFUL);
> +	} else {
> +		sc = RTEMS_INCORRECT_STATE;
> +	rtems_recursive_mutex_unlock(&dhcpcd_mutex);
> +	return sc;
>  struct getopt_data dhcpcd_getopt_data;
>  static int
> diff --git a/dhcpcd/namespace.h b/dhcpcd/namespace.h
> index 7299c7d0b..efff909ad 100644
> --- a/dhcpcd/namespace.h
> +++ b/dhcpcd/namespace.h
> @@ -1,3 +1,7 @@
> +#include <rtems/thread.h>
> +extern rtems_recursive_mutex dhcpcd_mutex;
>  #define add_options dhcpcd_add_options
>  #define arp_announce dhcpcd_arp_announce
>  #define arp_probe dhcpcd_arp_probe
> diff --git a/rtemsbsd/include/rtems/dhcpcd.h b/rtemsbsd/include/rtems/dhcpcd.h
> new file mode 100644
> index 000000000..6bc5e023d
> --- /dev/null
> +++ b/rtemsbsd/include/rtems/dhcpcd.h
> @@ -0,0 +1,66 @@
> + * @file
> + * @ingroup rtems_bsd
> + * @brief TODO.
> + * Copyright (c) 2018 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> + * SUCH DAMAGE.
> +#ifndef _RTEMS_DHCPCD_H_
> +#define _RTEMS_DHCPCD_H_
> +#include <rtems.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> + * @brief Starts the DHCP client (dhcpcd).
> + * @retval RTEMS_SUCCESSFUL Successful operation.
> + * @retval RTEMS_INCORRECT_STATE The DHCP client runs already.
> + * @retval RTEMS_TOO_MANY No task control block available.
> + * @retval RTEMS_UNSATISFIED Not enough resources to create task.
> + * @retval RTEMS_INVALID_PRIORITY Invalid task priority.
> +rtems_status_code rtems_dhcpcd_start(rtems_task_priority priority);
> +#ifdef __cplusplus
> +#endif /* _RTEMS_DHCPCD_H_ */
> diff --git a/testsuite/include/rtems/bsd/test/default-network-init.h b/testsuite/include/rtems/bsd/test/default-network-init.h
> index d26df03cd..89274fce0 100644
> --- a/testsuite/include/rtems/bsd/test/default-network-init.h
> +++ b/testsuite/include/rtems/bsd/test/default-network-init.h
> @@ -47,6 +47,7 @@
>  #include <rtems/printer.h>
>  #include <rtems/stackchk.h>
>  #include <rtems/bsd/bsd.h>
>  #if defined(DEFAULT_NETWORK_DHCPCD_ENABLE) && \
>      !defined(DEFAULT_NETWORK_NO_STATIC_IFCONFIG)
> @@ -125,22 +126,16 @@ default_network_route_hwif0(char *ifname)
>  #endif
> -#ifdef DEFAULT_NETWORK_DHCPCD_ENABLE
>  static void
> -default_network_dhcpcd_task(rtems_task_argument arg)
> +default_network_dhcpcd(void)
> +#ifdef DEFAULT_NETWORK_DHCPCD_ENABLE
>  	static const char default_cfg[] = "clientid libbsd test client\n";
> -	int exit_code;
> -	char *dhcpcd[] = {
> -		"dhcpcd",
> -		NULL
>  	int fd;
>  	int rv;
>  	ssize_t n;
> -	(void)arg;
>  	fd = open("/etc/dhcpcd.conf", O_CREAT | O_WRONLY,
>  	    S_IRWXU | S_IRWXG | S_IRWXO);
>  	assert(fd >= 0);
> @@ -158,29 +153,7 @@ default_network_dhcpcd_task(rtems_task_argument arg)
>  	rv = close(fd);
>  	assert(rv == 0);
> -	exit_code = rtems_bsd_command_dhcpcd(RTEMS_BSD_ARGC(dhcpcd), dhcpcd);
> -	assert(exit_code == EXIT_SUCCESS);
> -#endif
> -static void
> -default_network_dhcpcd(void)
> -	rtems_status_code sc;
> -	rtems_id id;
> -	sc = rtems_task_create(
> -		rtems_build_name('D', 'H', 'C', 'P'),
> -		RTEMS_MAXIMUM_PRIORITY - 1,
> -		2 * RTEMS_MINIMUM_STACK_SIZE,
> -		RTEMS_DEFAULT_MODES,
> -		RTEMS_FLOATING_POINT,
> -		&id
> -	assert(sc == RTEMS_SUCCESSFUL);
> -	sc = rtems_task_start(id, default_network_dhcpcd_task, 0);
> +	sc = rtems_dhcpcd_start(RTEMS_MAXIMUM_PRIORITY - 1);
>  #endif
