[PATCH] waf: Allow to add libs per test.
Christian Mauderer
christian.mauderer at embedded-brains.de
Wed May 2 09:45:59 UTC 2018
Update #3419.
builder.py | 11 +++++++----
libbsd.py | 33 +++++++++++++++++++++++----------
waf_libbsd.py | 4 +++-
3 files changed, 33 insertions(+), 15 deletions(-)
diff --git a/builder.py b/builder.py
index 93363590..c183f7d6 100755
--- a/builder.py
+++ b/builder.py
@@ -495,25 +495,28 @@ class SourceFileIfHeaderComposer(SourceFileFragmentComposer):
class TestFragementComposer(BuildSystemFragmentComposer):
- def __init__(self, testName, fileFragments, runTest = True, netTest = False):
+ def __init__(self, testName, fileFragments, runTest = True, netTest = False, extraLibs = []):
self.testName = testName
self.fileFragments = fileFragments
self.runTest = runTest
self.netTest = netTest
+ self.extraLibs = extraLibs
def compose(self, path):
return ['tests', self.testName, ('default', None)], { 'files': self.fileFragments,
'run': self.runTest,
- 'net': self.netTest }
+ 'net': self.netTest,
+ 'libs': self.extraLibs}
class TestIfHeaderComposer(TestFragementComposer):
- def __init__(self, testName, headers, fileFragments, runTest = True, netTest = False):
+ def __init__(self, testName, headers, fileFragments, runTest = True, netTest = False, extraLibs = []):
if headers is not list:
headers = [headers]
self.headers = headers
super(TestIfHeaderComposer, self).__init__(testName, fileFragments,
- runTest = runTest, netTest = netTest)
+ runTest = runTest, netTest = netTest,
+ extraLibs = extraLibs)
r = TestFragementComposer.compose(self, path)
diff --git a/libbsd.py b/libbsd.py
index 586703fd..48bc034a 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -4705,10 +4705,14 @@ class tests(builder.Module):
self.addTest(mm.generator['test']('arphole', ['test_main'],
runTest = False, netTest = True))
self.addTest(mm.generator['test']('telnetd01', ['test_main'],
- runTest = False, netTest = True))
+ runTest = False, netTest = True,
+ extraLibs = ['telnetd']))
self.addTest(mm.generator['test']('unix01', ['test_main']))
- self.addTest(mm.generator['test']('ftpd01', ['test_main'], netTest = True))
- self.addTest(mm.generator['test']('ftpd02', ['test_main']))
+ self.addTest(mm.generator['test']('ftpd01', ['test_main'],
+ netTest = True,
+ extraLibs = ['ftpd']))
+ self.addTest(mm.generator['test']('ftpd02', ['test_main'],
+ extraLibs = ['ftpfs', 'ftpd']))
self.addTest(mm.generator['test']('ping01', ['test_main'], netTest = True))
self.addTest(mm.generator['test']('selectpollkqueue01', ['test_main']))
self.addTest(mm.generator['test']('rwlock01', ['test_main']))
@@ -4729,19 +4733,27 @@ class tests(builder.Module):
self.addTest(mm.generator['test']('thread01', ['test_main']))
self.addTest(mm.generator['test']('mutex01', ['test_main']))
self.addTest(mm.generator['test']('condvar01', ['test_main']))
- self.addTest(mm.generator['test']('ppp01', ['test_main'], runTest = False))
+ self.addTest(mm.generator['test']('ppp01', ['test_main'], runTest = False,
+ extraLibs = ['ftpd', 'telnetd']))
self.addTest(mm.generator['test']('zerocopy01', ['test_main'],
self.addTest(mm.generator['test']('smp01', ['test_main']))
- self.addTest(mm.generator['test']('media01', ['test_main'], runTest = False))
+ self.addTest(mm.generator['test']('media01', ['test_main'],
+ runTest = False,
self.addTest(mm.generator['test']('vlan01', ['test_main'], netTest = True))
self.addTest(mm.generator['test']('lagg01', ['test_main'], netTest = True))
self.addTest(mm.generator['test']('log01', ['test_main']))
self.addTest(mm.generator['test']('rcconf01', ['test_main']))
- self.addTest(mm.generator['test']('rcconf02', ['test_main']))
+ self.addTest(mm.generator['test']('rcconf02', ['test_main'],
self.addTest(mm.generator['test']('cdev01', ['test_main', 'test_cdev']))
- self.addTest(mm.generator['test']('pf01', ['test_main']))
- self.addTest(mm.generator['test']('pf02', ['test_main'], runTest = False))
+ self.addTest(mm.generator['test']('pf01', ['test_main'],
+ self.addTest(mm.generator['test']('pf02', ['test_main'],
+ runTest = False,
self.addTest(mm.generator['test']('termios', ['test_main',
'test_termios_driver',
'test_termios_utilities']))
@@ -4764,7 +4776,8 @@ class tests(builder.Module):
'../termios/test_termios_driver',
'../termios/test_termios_utilities']))
self.addTest(mm.generator['test-if-header']('debugger01', 'rtems/rtems-debugger.h',
- ['test_main'], runTest = False, netTest = True))
+ ['test_main'], runTest = False, netTest = True,
+ extraLibs = ['debugger']))
self.addTest(mm.generator['test']('crypto01', ['test_main']))
def load(mm):
diff --git a/waf_libbsd.py b/waf_libbsd.py
index fd89c394..a1d8ad2b 100644
--- a/waf_libbsd.py
+++ b/waf_libbsd.py
@@ -460,6 +460,7 @@ class Builder(builder.ModuleManager):
for testName in sorted(tests):
test = self.data['tests'][testName]['all']
test_source = []
+ libs = ['bsd', 'm', 'z']
for cfg in test:
build_test = True
if cfg != 'default':
@@ -470,6 +471,7 @@ class Builder(builder.ModuleManager):
if build_test:
test_sources = ['testsuite/%s/%s.c' % (testName, f) \
for f in test[cfg]['files']]
+ libs = test[cfg]['libs'] + libs
if build_test:
bld.program(target = '%s.exe' % (testName),
features = 'cprogram',
@@ -477,5 +479,5 @@ class Builder(builder.ModuleManager):
includes = includes,
source = test_sources,
use = ['bsd'],
- lib = ['ftpfs', 'ftpd', 'telnetd', 'bsd', 'm', 'z'],
+ lib = libs,
install_path = None)
2.13.6
