[PATCH v3 5/6] buildset: Add minimal and everything config.
Christian Mauderer christian.mauderer at embedded-brains.de
Wed May 2 13:15:06 UTC 2018
This adds two new buildset configurations: One that leaves out as much
features as possible and one that enables all features. For the default
configuration WiFi support is now disabled.
To disable IPv6 for the minimal configuration, all -DINET6 are
eliminated in libbsd.py. They are now replaced by a #ifdef that checks
for RTEMS_BSD_MODULE_NETINET6 instead.
Close #3351.
 builder.py                                         |  1 +
 buildset/default.ini                               | 16 ++++++++++------
 buildset/everything.ini                            | 15 +++++++++++++++
 buildset/minimal.ini                               | 22 ++++++++++++++++++++++
 buildset/sample.ini                                | 10 ----------
 dhcpcd/config.h                                    |  1 +
 dhcpcd/dhcp6.c                                     |  5 +++++
 dhcpcd/ipv6.c                                      |  5 +++++
 dhcpcd/ipv6.h                                      |  3 +++
 dhcpcd/ipv6nd.c                                    |  5 +++++
 dhcpcd/platform.h                                  |  3 +++
 freebsd/lib/libc/rpc/rpcb_clnt.c                   |  1 -
 freebsd/sbin/ifconfig/ifconfig.c                   |  5 +++++
 freebsd/sbin/ping6/ping6.c                         |  2 ++
 libbsd.py                                          | 10 ++++------
 libbsd.txt                                         | 17 ++++++++++++++---
 rtemsbsd/include/machine/rtems-bsd-user-space.h    |  1 +
 rtemsbsd/include/rtems/bsd/local/opt_inet6.h       |  5 ++++-
 testsuite/commands01/test_main.c                   | 15 +++++++++++++++
 .../include/rtems/bsd/test/default-network-init.h  | 19 ++++++++++++++++---
 testsuite/media01/test_main.c                      | 13 ++++++++++---
 21 files changed, 141 insertions(+), 33 deletions(-)
 create mode 100644 buildset/everything.ini
 create mode 100644 buildset/minimal.ini
 delete mode 100644 buildset/sample.ini
diff --git a/builder.py b/builder.py
index c183f7d6..b0d6374e 100755
--- a/builder.py
+++ b/builder.py
@@ -186,6 +186,7 @@ def revertFixIncludes(data):
     data = re.sub('#include <util.h>',     '#include <rtems/bsd/util.h>', data)
     data = re.sub('#include <bsd.h>',      '#include <rtems/bsd/bsd.h>', data)
     data = re.sub('#include <zerocopy.h>', '#include <rtems/bsd/zerocopy.h>', data)
+    data = re.sub('#include <modules.h>',  '#include <rtems/bsd/modules.h>', data)
     return data
 # fix include paths inside a C or .h file
diff --git a/buildset/default.ini b/buildset/default.ini
index e58ea99f..a5cbdf9c 100644
--- a/buildset/default.ini
+++ b/buildset/default.ini
@@ -1,5 +1,9 @@
-# Default configuration.
+# Default configuration. Contains most features except for some big or slow ones
+# like WiFi or IPSec.
+# At all developers: Please allways add all modules to this file and mark them
+# as explicitly "off" if they are not used.
 [general]
@@ -30,8 +34,8 @@ dev_usb_net = on
 dev_usb_quirk = on
 dev_usb_serial = on
 dev_usb_storage = on
-dev_usb_wlan = on
-dev_wlan_rtwn = on
+dev_usb_wlan = off
+dev_wlan_rtwn = off
 dhcpcd = on
 dpaa = on
 evdev = on
@@ -43,7 +47,7 @@ mghttpd = on
 mmc = on
 mmc_ti = on
 net = on
-net80211 = on
+net80211 = off
 netinet = on
 netinet6 = on
 opencrypto = on
@@ -53,6 +57,6 @@ rtems = on
 tests = on
 tty = on
 user_space = on
-user_space_wlanstats = on
+user_space_wlanstats = off
 usr_sbin_tcpdump = on
-usr_sbin_wpa_supplicant = on
+usr_sbin_wpa_supplicant = off
diff --git a/buildset/everything.ini b/buildset/everything.ini
new file mode 100644
index 00000000..0d9cc5fb
--- /dev/null
+++ b/buildset/everything.ini
@@ -0,0 +1,15 @@
+# This configuration has the target to provide all features of libbsd even the
+# big and slow ones.
+[general]
+name = everything
+extends = default.ini
+[modules]
+dev_usb_wlan = on
+dev_wlan_rtwn = on
+net80211 = on
+user_space_wlanstats = on
+usr_sbin_wpa_supplicant = on
diff --git a/buildset/minimal.ini b/buildset/minimal.ini
index 00000000..c5ad8214
--- /dev/null
+++ b/buildset/minimal.ini
@@ -0,0 +1,22 @@
+# This configuration has the target to provide the smallest possible libbsd
+# during link time. It should disable everything that can be disabled without
+# loosing basic functionality. As a target, it should once only provide the
+# following functions:
+# - basic IPv4 only networking
+# - basic USB support
+# - all device drivers that don't increase the application size without being
+#   explicitly linked in
+# ATTENTION: This configuration will loose functionality in the future as soon
+# as it is possible to disable the functionality.
+[general]
+name = minimal
+[modules]
+crypto_openssl = off
+netinet6 = off
diff --git a/buildset/sample.ini b/buildset/sample.ini
deleted file mode 100644
index 5d73e2a5..00000000
--- a/buildset/sample.ini
+++ /dev/null
@@ -1,10 +0,0 @@
-# Currently this is mostly a sample configuration.
-[general]
-name = sample
-extends = default.ini
-[modules]
-dev_nic_broadcomm = off
diff --git a/dhcpcd/config.h b/dhcpcd/config.h
index 27174eb8..cf6c5fb1 100644
--- a/dhcpcd/config.h
+++ b/dhcpcd/config.h
@@ -14,6 +14,7 @@
 #include <spawn.h>
 #include <stdint.h>
 #include "compat/pollts.h"
+#include <rtems/bsd/local/opt_inet6.h>
 uint32_t arc4random(void);
 static inline int dhcpcd_flock(int a, int b) { return -1; }
 #define flock(a, b) dhcpcd_flock(a, b)
diff --git a/dhcpcd/dhcp6.c b/dhcpcd/dhcp6.c
index ec585883..d775e312 100644
--- a/dhcpcd/dhcp6.c
+++ b/dhcpcd/dhcp6.c
@@ -27,6 +27,10 @@
 /* TODO: We should decline dupliate addresses detected */
+#ifdef __rtems__
+#endif /* __rtems__ */
+#if defined(__rtems__) && defined(INET6)
 #include <sys/stat.h>
 #include <sys/utsname.h>
@@ -2809,3 +2813,4 @@ dhcp6_env(char **env, const char *prefix, const struct interface *ifp,
 	return n;
+#endif /* defined(__rtems__) && defined(INET6) */
diff --git a/dhcpcd/ipv6.c b/dhcpcd/ipv6.c
index 3f3a1033..c6d69d27 100644
--- a/dhcpcd/ipv6.c
+++ b/dhcpcd/ipv6.c
@@ -25,6 +25,10 @@
  * SUCH DAMAGE.
+#ifdef __rtems__
 #include <sys/param.h>
 #include <sys/types.h>
 #include <sys/socket.h>
@@ -1045,3 +1049,4 @@ ipv6_buildroutes(void)
 	free(routes);
 	routes = nrs;
diff --git a/dhcpcd/ipv6.h b/dhcpcd/ipv6.h
index 6b5dc1df..7ba9425d 100644
--- a/dhcpcd/ipv6.h
+++ b/dhcpcd/ipv6.h
@@ -31,6 +31,9 @@
 #include <sys/queue.h>
 #include <netinet/in.h>
+#ifdef __rtems__
 #define ALLROUTERS "ff02::2"
 #define HOPLIMIT 255
diff --git a/dhcpcd/ipv6nd.c b/dhcpcd/ipv6nd.c
index 2fd20842..5709ed19 100644
--- a/dhcpcd/ipv6nd.c
+++ b/dhcpcd/ipv6nd.c
@@ -25,6 +25,10 @@
  * SUCH DAMAGE.
+#ifdef __rtems__
 #include <sys/ioctl.h>
@@ -1833,3 +1837,4 @@ ipv6nd_startrs(struct interface *ifp)
 	ipv6nd_sendrsprobe(ifp);
 	return 0;
diff --git a/dhcpcd/platform.h b/dhcpcd/platform.h
index 46797c16..d5066311 100644
--- a/dhcpcd/platform.h
+++ b/dhcpcd/platform.h
@@ -27,6 +27,9 @@
 #ifndef PLATFORM_H
 #define PLATFORM_H
+#ifdef __rtems__
 char *hardware_platform(void);
 #ifdef INET6
diff --git a/freebsd/lib/libc/rpc/rpcb_clnt.c b/freebsd/lib/libc/rpc/rpcb_clnt.c
index b8f1dd0c..669c9bec 100644
--- a/freebsd/lib/libc/rpc/rpcb_clnt.c
+++ b/freebsd/lib/libc/rpc/rpcb_clnt.c
@@ -32,7 +32,6 @@
 /* #ident	"@(#)rpcb_clnt.c	1.27	94/04/24 SMI" */
 #if defined(LIBC_SCCS) && !defined(lint)
 static char sccsid[] = "@(#)rpcb_clnt.c 1.30 89/06/21 Copyr 1988 Sun Micro";
 #endif
diff --git a/freebsd/sbin/ifconfig/ifconfig.c b/freebsd/sbin/ifconfig/ifconfig.c
index 956a9dfe..b9ba236a 100644
--- a/freebsd/sbin/ifconfig/ifconfig.c
+++ b/freebsd/sbin/ifconfig/ifconfig.c
@@ -54,6 +54,7 @@ static const char rcsid[] =
 #undef option
 #include <machine/rtems-bsd-program.h>
 #include <machine/rtems-bsd-commands.h>
+#include <rtems/bsd/modules.h>
@@ -382,8 +383,12 @@ mainwrapper(int argc, char *argv[])
 	gre_ctor();
 	group_ctor();
 	ifmedia_ctor();
+#ifdef RTEMS_BSD_MODULE_IEEE80211
 	ieee80211_ctor();
+#endif
+#ifdef RTEMS_BSD_MODULE_NETINET6
 	inet6_ctor();
+#endif
 	inet_ctor();
 	lagg_ctor();
 	link_ctor();
diff --git a/freebsd/sbin/ping6/ping6.c b/freebsd/sbin/ping6/ping6.c
index 9faf09e2..972ef38e 100644
--- a/freebsd/sbin/ping6/ping6.c
+++ b/freebsd/sbin/ping6/ping6.c
@@ -69,6 +69,7 @@
  * SUCH DAMAGE.
 #ifndef lint
 static const char copyright[] =
 "@(#) Copyright (c) 1989, 1993\n\
@@ -2835,3 +2836,4 @@ usage(void)
 	    "             [-X timeout] [hops ...] host\n");
 	exit(1);
diff --git a/libbsd.py b/libbsd.py
index 48bc034a..dac1ece1 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -2561,7 +2561,7 @@ class user_space(builder.Module):
                 'lib/libc/db/recno/rec_seq.c',
                 'lib/libc/db/recno/rec_utils.c',
-            mm.generator['source']('-D__DBINTERFACE_PRIVATE -DINET6')
+            mm.generator['source']('-D__DBINTERFACE_PRIVATE')
         self.addRTEMSHeaderFiles(
@@ -2804,7 +2804,7 @@ class user_space(builder.Module):
                 'usr.bin/vmstat/vmstat.c',
                 'usr.sbin/arp/arp.c',
-            mm.generator['source'](['-DINET6', '-DINET'])
+            mm.generator['source'](['-DINET'])
@@ -2829,7 +2829,7 @@ class user_space_wlanstats(builder.Module):
                 'tools/tools/net80211/wlanstats/wlanstats.c',
                 'lib/libbsdstat/bsdstat.c',
+            mm.generator['source']([])
@@ -3840,7 +3840,6 @@ class contrib_libpcap(builder.Module):
         mm = self.manager
         cflags = ['-D__FreeBSD__=1',
                   '-DBSD=1',
-                  '-DINET6',
                   '-D_U_=__attribute__((unused))',
                   '-DHAVE_LIMITS_H=1',
                   '-DHAVE_INTTYPES=1',
@@ -4151,7 +4150,6 @@ class usr_sbin_tcpdump(builder.Module):
                 'contrib/tcpdump/util-print.c',
             mm.generator['source'](['-D__FreeBSD__=1',
-                                    '-DINET6',
                                     '-DHAVE_CONFIG_H=1',
                                     '-DHAVE_NET_PFVAR_H=1'],
@@ -4558,7 +4556,7 @@ class dhcpcd(builder.Module):
                 'dhcpcd/compat/pselect.c',
                 'dhcpcd/crypt/hmac_md5.c',
-            mm.generator['source']('-D__FreeBSD__ -DTHERE_IS_NO_FORK -DMASTER_ONLY -DINET -DINET6')
+            mm.generator['source']('-D__FreeBSD__ -DTHERE_IS_NO_FORK -DMASTER_ONLY -DINET')
         self.addRTEMSSourceFiles(
diff --git a/libbsd.txt b/libbsd.txt
index 3cbb642d..c7a90f64 100644
--- a/libbsd.txt
+++ b/libbsd.txt
@@ -120,6 +120,14 @@ devices (you can run multiple test instances on one virtual network).
 The build system based on the Waf build system. To build with Waf please refer
 to the README.waf file.
+Note that the libbsd supports different buildsets. These can be selected with
+the `--buildset=xxx.ini` option during the configure phase. Take a look at the
+comments in `buildset/*.ini` to see which build sets are officially supported.
+You can also create and provide your own buildset configuration. But remember
+that it's quite easy to break something by disabling the wrong modules. Only the
+configurations in the `buildset` directory are officially maintained.
 ===== Example Configuration for Network Tests =====
 If you need some other IP configuration for the network tests that use a fixed
@@ -1173,9 +1181,12 @@ The following is necessary to use PF on RTEMS:
 == Wireless Network (WLAN) ==
 The libbsd provides a basic support for WLAN. Note that currently this support
-is still in an early state. The following gives a rough overview over the
-necessary steps to connect to an encrypted network with an RTL8188EU based WiFi
-dongle:
+is still in an early state. The WLAN support is _not_ enabled in the default
+buildset. You have to configure libbsd with the
+`--buildset=buildset/everything.ini` to enable that feature.
+The following gives a rough overview over the necessary steps to connect to an
+encrypted network with an RTL8188EU based WiFi dongle:
 - Reference all necessary module for your BSP. For some BSPs this is already
   done in the nexus-devices.h:
diff --git a/rtemsbsd/include/machine/rtems-bsd-user-space.h b/rtemsbsd/include/machine/rtems-bsd-user-space.h
index 0b6a3a99..ac78b723 100644
--- a/rtemsbsd/include/machine/rtems-bsd-user-space.h
+++ b/rtemsbsd/include/machine/rtems-bsd-user-space.h
@@ -42,6 +42,7 @@
 #define __FreeBSD__ 1
 #include <machine/rtems-bsd-version.h>
 #include <sys/cdefs.h>
diff --git a/rtemsbsd/include/rtems/bsd/local/opt_inet6.h b/rtemsbsd/include/rtems/bsd/local/opt_inet6.h
index 1aaf3a65..8a124cfd 100644
--- a/rtemsbsd/include/rtems/bsd/local/opt_inet6.h
+++ b/rtemsbsd/include/rtems/bsd/local/opt_inet6.h
@@ -1 +1,4 @@
-#define INET6 1
+  #define INET6 1
+#endif
diff --git a/testsuite/commands01/test_main.c b/testsuite/commands01/test_main.c
index f0ddab50..2e61a933 100644
--- a/testsuite/commands01/test_main.c
+++ b/testsuite/commands01/test_main.c
@@ -40,6 +40,7 @@
 #include <rtems/libcsupport.h>
 #define TEST_NAME "LIBBSD COMMANDS 1"
@@ -108,6 +109,7 @@ test_ifconfig_lo0(void)
 		"255.255.255.0",
 		NULL
 	char *lo0_inet6[] = {
 		"ifconfig",
 		"lo0",
@@ -117,37 +119,46 @@ test_ifconfig_lo0(void)
 		"128",
 		NULL
+#endif /* RTEMS_BSD_MODULE_NETINET6 */
 	char *status[] = {
 		"ifconfig",
 		"lo0",
 		"inet",
 		NULL
 	char *status_inet6[] = {
 		"ifconfig",
 		"lo0",
 		"inet6",
 		NULL
 	exit_code = rtems_bsd_command_ifconfig(ARGC(lo0), lo0);
 	assert(exit_code == EX_OK);
 	exit_code = rtems_bsd_command_ifconfig(ARGC(lo0_inet6), lo0_inet6);
 	rtems_resource_snapshot_take(&snapshot);
 	exit_code = rtems_bsd_command_ifconfig(ARGC(status), status);
 	exit_code = rtems_bsd_command_ifconfig(ARGC(status_inet6), status_inet6);
 	assert(rtems_resource_snapshot_check(&snapshot));
@@ -195,6 +206,7 @@ test_ping(void)
 static void
 test_ping6(void)
 	rtems_resource_snapshot snapshot;
 	int exit_code;
 	char *ping6[] = {
@@ -214,6 +226,7 @@ test_ping6(void)
 	assert(exit_code == EXIT_SUCCESS);
+#endif
 static void
@@ -260,6 +273,7 @@ test_netstat(void)
 static void
 test_wlanstats(void)
+#ifdef RTEMS_BSD_MODULE_USER_SPACE_WLANSTATS
 	char *wlanstats[] = {
 		"wlanstats",
@@ -271,6 +285,7 @@ test_wlanstats(void)
 	rtems_bsd_command_wlanstats(ARGC(wlanstats), wlanstats);
+#endif /* RTEMS_BSD_MODULE_USER_SPACE_WLANSTATS */
 static void
diff --git a/testsuite/include/rtems/bsd/test/default-network-init.h b/testsuite/include/rtems/bsd/test/default-network-init.h
index d26df03c..ee95d26e 100644
--- a/testsuite/include/rtems/bsd/test/default-network-init.h
+++ b/testsuite/include/rtems/bsd/test/default-network-init.h
@@ -47,6 +47,7 @@
 #include <rtems/printer.h>
 #include <rtems/stackchk.h>
 #if defined(DEFAULT_NETWORK_DHCPCD_ENABLE) && \
     !defined(DEFAULT_NETWORK_NO_STATIC_IFCONFIG)
@@ -327,7 +328,21 @@ Init(rtems_task_argument arg)
 #include <rtems/netcmds-config.h>
+  #define SHELL_WLANSTATS_COMMAND &rtems_shell_WLANSTATS_Command,
+#else
+#endif
+#ifdef RTEMS_BSD_MODULE_USR_SBIN_WPA_SUPPLICANT
+  #define SHELL_WPA_SUPPLICANT_COMMAND &rtems_shell_WPA_SUPPLICANT_Command,
+#else
+#endif
 #define CONFIGURE_SHELL_USER_COMMANDS \
+  SHELL_WLANSTATS_COMMAND \
+  SHELL_WPA_SUPPLICANT_COMMAND \
   &bsp_interrupt_shell_command, \
   &rtems_shell_ARP_Command, \
   &rtems_shell_HOSTNAME_Command, \
@@ -337,9 +352,7 @@ Init(rtems_task_argument arg)
   &rtems_shell_IFCONFIG_Command, \
   &rtems_shell_TCPDUMP_Command, \
   &rtems_shell_SYSCTL_Command, \
-  &rtems_shell_VMSTAT_Command, \
-  &rtems_shell_WLANSTATS_Command, \
-  &rtems_shell_WPA_SUPPLICANT_Command
+  &rtems_shell_VMSTAT_Command
 #define CONFIGURE_SHELL_COMMAND_CPUINFO
 #define CONFIGURE_SHELL_COMMAND_CPUUSE
diff --git a/testsuite/media01/test_main.c b/testsuite/media01/test_main.c
index f929cba1..c9d902dc 100644
--- a/testsuite/media01/test_main.c
+++ b/testsuite/media01/test_main.c
@@ -200,7 +200,16 @@ early_initialization(void)
+  #define SHELL_WPA_SUPPLICANT_COMMANDS \
+    &rtems_shell_WPA_SUPPLICANT_Command, \
+    &rtems_shell_WPA_SUPPLICANT_FORK_Command,
+#else
+#endif
+  SHELL_WPA_SUPPLICANT_COMMANDS \
@@ -209,9 +218,7 @@ early_initialization(void)
   &rtems_shell_NETSTAT_Command, \
-  &rtems_shell_WPA_SUPPLICANT_Command, \
-  &rtems_shell_WPA_SUPPLICANT_FORK_Command
2.13.6
