[PATCH v3 0/6] libbsd: Create some basic buildsets.
Wed May 2 23:55:13 UTC 2018
On 02/05/2018 23:15, Christian Mauderer wrote:
> I noted some problem with freebsd-to-rtems.py with the approach I used
> for testing for INET6 in the minimal config. So I changed that to
> include that into the general rtems-bsd-user-space.h. That has the
> advantage that it's not that easy to forget to look whether INET6 is
> used in some header.
To clarify, does this mean an application build system header check could be
used to detect what is configured in an install libbsd package?
If so this is a great idea and a welcome change.
> I'm confident that this is the final version of the patches.
Looks fine to me.
