Misplaced Directories?
Thu May 3 05:21:51 UTC 2018
On 03/05/18 03:55, Chris Johns wrote:
> On 02/05/2018 21:25, Sebastian Huber wrote:
>> On 02/05/18 13:18, Joel Sherrill wrote:
>>> On Wed, May 2, 2018, 12:13 AM Sebastian Huber
>>> <sebastian.huber at embedded-brains.de
>>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>>      > I think that's it from my notes. Any comments or thoughts?
>>>      I would leave the source files in cpukit where they are. A proper
>>>      file
>>>      history is more important than a fancy directory layout from my
>>>      point of
>>>      view
>>> Doesn't got keep history with moves and renames?
>> It works to some extent. You usually need a --follow command line option. It is
>> not completely transparent.
> I think not allowing code movement in the cpukit as a rule is too restrictive. I
> do not support such a restriction. I think code can be moved in the cpukit tree.
> I would have questioned the 'dev' tree being added if I knew this restriction
> existed. I think adding 'dev' is a good change and we should look to move parts
> that existed before it was created into it. I think a sensible layout is worth
> more than the linear history for _those_ pieces of code.
> The RTEMS code base is old and if we had not moved files we would be in a tragic
> place. The moving of the headers and BSP code is a good example of why we need
> to move source and the threshold for those files to move was higher than the
> need for a clean history. We need to be smart about what we move, why we want to
> move things and when. The threshold to move files in rtems, sapi and score is
> very high. This does not rule out moving files in those directories, it just
> means we need to balance the cost/benefit ratio when deciding. A clean history
> for those directories and files is important and highly rated.
> Give the extent of code moved for RTEMS 5 I am OK with the directories Joel has
> listed moving. I welcome the cpukit being cleaned up.
> Chris
> ps Please reconsider using terms like "fancy directory layout", it is not
> helpful in a discussion about moving files after you have moved most of the
> c/src (which is a fantastic thing to have happened).
The header file movements were driven by the need to get rid of the
preinstall step. This is a clear benefit. The movements of the BSP
source files are a consequence of this.
If you really want to clean up the cpukit source files, then please
create a ticket and make a plan. I am strongly opposed to move files in
rtems, sapi and score. It should be carried out before the 5.1 release.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
