[PATCH 2/4] covoar: Use DWARF to map addresses to source files and lines.
Joel Sherrill
joel at rtems.org
Sat May 5 16:17:40 UTC 2018
On Sat, May 5, 2018, 10:57 AM Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> Hello,
> I'm getting this build failure after applying this patch
> Build failed
> -> task in 'ccovoar' failed with exit status 1:
> {task 140086064254560: cxx app_common.cc -> app_common.cc.1.o}
> ['/usr/bin/g++', '-std=c++11', '-O2', '-g', '-Itester/covoar',
> '-I../tester/covoar', '-Irtemstoolkit', '-I../rtemstoolkit',
> '-Irtemstoolkit/elftoolchain/libelf',
> '-I../rtemstoolkit/elftoolchain/libelf',
> '-Irtemstoolkit/elftoolchain/common',
> '-I../rtemstoolkit/elftoolchain/common', '-Irtemstoolkit/libiberty',
> '-I../rtemstoolkit/libiberty', '../tester/covoar/app_common.cc', '-c',
> '-o/home/lunatic/development/rtems/test/rtems-tools/build/tester/covoar/app_common.cc.1.o']
I don't see an error. Just the command. Does waf -v show more? Were there
error messages after the command?
> -- vijay
> On 5 May 2018 at 14:10, Chris Johns <chrisj at rtems.org> wrote:
>> tester/covoar/DesiredSymbols.cc | 122
>> tester/covoar/ExecutableInfo.cc | 80 +++++++++++++++++---------
>> tester/covoar/ExecutableInfo.h | 41 +++++++++++---
>> tester/covoar/covoar.cc | 2 +-
>> tester/covoar/wscript | 2 +-
>> 5 files changed, 94 insertions(+), 153 deletions(-)
>> diff --git a/tester/covoar/DesiredSymbols.cc
>> b/tester/covoar/DesiredSymbols.cc
>> index 9957b28..79ee78d 100644
>> --- a/tester/covoar/DesiredSymbols.cc
>> +++ b/tester/covoar/DesiredSymbols.cc
>> @@ -449,123 +449,13 @@ namespace Coverage {
>> - char* base;
>> - char* cStatus;
>> - char command[512];
>> - std::string fileName;
>> - CoverageRanges::ranges_t::iterator ritr;
>> - char rpath[PATH_MAX];
>> - FILE* tmpfile;
>> - // Open a temporary file for the uncovered ranges.
>> - tmpfile = fopen( "ranges1.tmp", "w" );
>> - if ( !tmpfile ) {
>> - fprintf(
>> - stderr,
>> - "ERROR: DesiredSymbols::determineSourceLines - "
>> - "unable to open %s\n",
>> - "ranges1.tmp"
>> - exit(-1);
>> - // Write the range addresses to the temporary file.
>> - for (ritr = theRanges->set.begin();
>> - ritr != theRanges->set.end();
>> - ritr++ ) {
>> - fprintf(
>> - tmpfile,
>> - "0x%08x\n0x%08x\n",
>> - ritr->lowAddress - theExecutable->getLoadAddress(),
>> - ritr->highAddress - theExecutable->getLoadAddress()
>> - fclose( tmpfile );
>> - // Invoke addr2line to generate the source lines for each address.
>> - if (theExecutable->hasDynamicLibrary())
>> - fileName = theExecutable->getLibraryName();
>> - else
>> - fileName = theExecutable->getFileName();
>> - sprintf(
>> - command,
>> - "%s -Ce %s <%s | dos2unix >%s",
>> - TargetInfo->getAddr2line(),
>> - fileName.c_str(),
>> - "ranges1.tmp",
>> - "ranges2.tmp"
>> - if (system( command )) {
>> - fprintf(
>> - stderr,
>> - "command (%s) failed\n",
>> - command
>> - exit( -1 );
>> - // Open the addr2line output file.
>> - tmpfile = fopen( "ranges2.tmp", "r" );
>> - if ( !tmpfile ) {
>> - fprintf(
>> - stderr,
>> - "ranges2.tmp"
>> - exit(-1);
>> + for (auto& r : theRanges->set) {
>> + std::string location;
>> + theExecutable->getSourceAndLine(r.lowAddress, location);
>> + r.lowSourceLine = rld::path::basename (location);
>> + theExecutable->getSourceAndLine(r.highAddress, location);
>> + r.highSourceLine = rld::path::basename (location);
>> - // Process the addr2line output.
>> - ritr++ ) {
>> - cStatus = fgets( inputBuffer, MAX_LINE_LENGTH, tmpfile );
>> - if ( cStatus == NULL ) {
>> - fprintf(
>> - stderr,
>> - "Out of sync in addr2line output\n"
>> - exit( -1 );
>> - inputBuffer[ strlen(inputBuffer) - 1] = '\0';
>> - // Use only the base filename without directory path.
>> -#ifdef _WIN32
>> - #define realpath(N,R) _fullpath((R),(N),_MAX_PATH)
>> -#endif
>> - realpath( inputBuffer, rpath );
>> - base = basename( rpath );
>> - ritr->lowSourceLine = std::string( base );
>> - fprintf(
>> - stderr,
>> - exit( -1 );
>> - ritr->highSourceLine = std::string( base );
>> - unlink( "ranges1.tmp" );
>> - unlink( "ranges2.tmp" );
>> SymbolInformation* DesiredSymbols::find(
>> diff --git a/tester/covoar/ExecutableInfo.cc
>> b/tester/covoar/ExecutableInfo.cc
>> index c41d931..1755e93 100644
>> --- a/tester/covoar/ExecutableInfo.cc
>> +++ b/tester/covoar/ExecutableInfo.cc
>> @@ -7,6 +7,8 @@
>> #include <stdio.h>
>> +#include <rld.h>
>> #include "ExecutableInfo.h"
>> #include "app_common.h"
>> #include "CoverageMap.h"
>> @@ -18,24 +20,36 @@ namespace Coverage {
>> ExecutableInfo::ExecutableInfo(
>> const char* const theExecutableName,
>> const char* const theLibraryName
>> + ) : executable(theExecutableName),
>> + loadAddress(0)
>> - executableName = theExecutableName;
>> - loadAddress = 0;
>> - libraryName = "";
>> if (theLibraryName)
>> libraryName = theLibraryName;
>> - theSymbolTable = new SymbolTable();
>> + try {
>> + executable.open();
>> + executable.begin();
>> + executable.load_symbols(symbols);
>> + debug.begin(executable.elf());
>> + debug.load_debug();
>> + } catch (rld::error re) {
>> + std::cerr << "error: "
>> + << re.where << ": " << re.what
>> + << std::endl;
>> + exit(2);
>> + } catch (...) {
>> + exit(2);
>> ExecutableInfo::~ExecutableInfo()
>> - if (theSymbolTable)
>> - delete theSymbolTable;
>> + debug.end();
>> + executable.end();
>> + executable.close();
>> void ExecutableInfo::dumpCoverageMaps( void ) {
>> - ExecutableInfo::coverageMaps_t::iterator itr;
>> + ExecutableInfo::CoverageMaps::iterator itr;
>> for (itr = coverageMaps.begin(); itr != coverageMaps.end(); itr++) {
>> fprintf( stderr, "Coverage Map for %s\n", ((*itr).first).c_str()
>> @@ -44,21 +58,22 @@ namespace Coverage {
>> void ExecutableInfo::dumpExecutableInfo( void ){
>> - fprintf( stdout, "\n== Executable info ==\n");
>> - fprintf( stdout, "executableName = %s\n", executableName.c_str());
>> - fprintf( stdout, "libraryName = %s\n", libraryName.c_str());
>> - fprintf( stdout, "loadAddress = %u\n", loadAddress);
>> - theSymbolTable->dumpSymbolTable();
>> + std::cout << std::endl
>> + << "== Executable info ==" << std::endl
>> + << "executable = " << getFileName () << std::endl
>> + << "library = " << libraryName << std::endl
>> + << "loadAddress = " << loadAddress << std::endl;
>> + theSymbolTable.dumpSymbolTable();
>> CoverageMapBase* ExecutableInfo::getCoverageMap ( uint32_t address )
>> - CoverageMapBase* aCoverageMap = NULL;
>> - coverageMaps_t::iterator it;
>> - std::string itsSymbol;
>> + CoverageMapBase* aCoverageMap = NULL;
>> + CoverageMaps::iterator it;
>> + std::string itsSymbol;
>> // Obtain the coverage map containing the specified address.
>> - itsSymbol = theSymbolTable->getSymbol( address );
>> + itsSymbol = theSymbolTable.getSymbol( address );
>> if (itsSymbol != "") {
>> it = coverageMaps.find( itsSymbol );
>> aCoverageMap = (*it).second;
>> @@ -67,12 +82,12 @@ namespace Coverage {
>> return aCoverageMap;
>> - const std::string& ExecutableInfo::getFileName ( void ) const
>> + const std::string ExecutableInfo::getFileName ( void ) const
>> - return executableName;
>> + return executable.name().full();
>> - const std::string& ExecutableInfo::getLibraryName( void ) const
>> + const std::string ExecutableInfo::getLibraryName( void ) const
>> return libraryName;
>> @@ -83,9 +98,9 @@ namespace Coverage {
>> - SymbolTable* ExecutableInfo::getSymbolTable ( void ) const
>> + SymbolTable* ExecutableInfo::getSymbolTable ( void )
>> - return theSymbolTable;
>> + return &theSymbolTable;
>> CoverageMapBase* ExecutableInfo::createCoverageMap (
>> @@ -95,8 +110,8 @@ namespace Coverage {
>> uint32_t highAddress
>> - CoverageMapBase *theMap;
>> + CoverageMapBase *theMap;
>> itr = coverageMaps.find( symbolName );
>> if ( itr == coverageMaps.end() ) {
>> @@ -109,13 +124,26 @@ namespace Coverage {
>> return theMap;
>> + void ExecutableInfo::getSourceAndLine(
>> + const unsigned int address,
>> + std::string& line
>> + std::string file;
>> + int lno;
>> + debug.get_source (address, file, lno);
>> + std::ostringstream ss;
>> + ss << file << ':' << lno;
>> + line = ss.str ();
>> bool ExecutableInfo::hasDynamicLibrary( void )
>> - return (libraryName != "");
>> + return !libraryName.empty();
>> void ExecutableInfo::mergeCoverage( void ) {
>> SymbolsToAnalyze->mergeCoverageMap( (*itr).first, (*itr).second );
>> diff --git a/tester/covoar/ExecutableInfo.h
>> b/tester/covoar/ExecutableInfo.h
>> index 20ea9bf..9106db3 100644
>> --- a/tester/covoar/ExecutableInfo.h
>> +++ b/tester/covoar/ExecutableInfo.h
>> @@ -11,6 +11,10 @@
>> #include <stdint.h>
>> #include <string>
>> +#include <rld-dwarf.h>
>> +#include <rld-files.h>
>> +#include <rld-symbols.h>
>> #include "CoverageMapBase.h"
>> #include "SymbolTable.h"
>> @@ -67,14 +71,14 @@ namespace Coverage {
>> * @return Returns the executable's file name
>> - const std::string& getFileName( void ) const;
>> + const std::string getFileName( void ) const;
>> * This method returns the library name associated with the
>> executable.
>> * @return Returns the executable's library name
>> - const std::string& getLibraryName( void ) const;
>> + const std::string getLibraryName( void ) const;
>> * This method returns the load address of the dynamic library
>> @@ -88,7 +92,7 @@ namespace Coverage {
>> * @return Returns a pointer to the symbol table.
>> - SymbolTable* getSymbolTable( void ) const;
>> + SymbolTable* getSymbolTable( void );
>> * This method creates a coverage map for the specified symbol.
>> @@ -107,6 +111,15 @@ namespace Coverage {
>> + * This method gets the source location, the file and line number
>> given an
>> + * address.
>> + void getSourceAndLine(
>> + std::string& location
>> * This method indicates whether a dynamic library has been
>> * associated with the executable.
>> @@ -132,15 +145,25 @@ namespace Coverage {
>> private:
>> - * This map associates a symbol with its coverage map.
>> + * The ELF executable.
>> - typedef std::map<std::string, CoverageMapBase *> coverageMaps_t;
>> - coverageMaps_t coverageMaps;
>> + rld::files::object executable;
>> - * This member variable contains the name of the executable.
>> + * The DWARF data to the ELF executable.
>> + rld::dwarf::file debug;
>> + * The executable's symbol table.
>> + rld::symbols::table symbols;
>> + * This map associates a symbol with its coverage map.
>> - std::string executableName;
>> + typedef std::map<std::string, CoverageMapBase *> CoverageMaps;
>> + CoverageMaps coverageMaps;
>> * This member variable contains the name of a dynamic library
>> @@ -158,7 +181,7 @@ namespace Coverage {
>> * This member variable contains a pointer to the symbol table
>> * of the executable or library.
>> - SymbolTable* theSymbolTable;
>> + SymbolTable theSymbolTable;
>> diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
>> index 5c87402..09c86c2 100644
>> --- a/tester/covoar/covoar.cc
>> +++ b/tester/covoar/covoar.cc
>> @@ -186,7 +186,7 @@ int main(
>> Coverage::ExecutableInfo* executableInfo = NULL;
>> std::string executableExtension = "exe";
>> std::string coverageExtension = "cov";
>> - Coverage::CoverageFormats_t coverageFormat;
>> + Coverage::CoverageFormats_t coverageFormat =
>> Coverage::COVERAGE_FORMAT_QEMU;
>> Coverage::CoverageReaderBase* coverageReader = NULL;
>> char* executable = NULL;
>> const char* explanations = NULL;
>> diff --git a/tester/covoar/wscript b/tester/covoar/wscript
>> index c0270d8..55d5ec9 100644
>> --- a/tester/covoar/wscript
>> +++ b/tester/covoar/wscript
>> @@ -70,7 +70,7 @@ def build(bld):
>> # The list of modules.
>> - modules = ['rld', 'elf', 'iberty']
>> + modules = ['rld', 'dwarf', 'elf', 'iberty']
>> bld.stlib(target = 'ccovoar',
>> source = ['app_common.cc',
>> 2.15.1
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180505/b121545e/attachment-0001.html>
