[PATCH 2/4] covoar: Use DWARF to map addresses to source files and lines.
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sat May 5 16:20:12 UTC 2018
In file included from ../rtemstoolkit/rld-dwarf.h:29:0,
from ../tester/covoar/ExecutableInfo.h:14,
from ../tester/covoar/DesiredSymbols.h:17,
from ../tester/covoar/app_common.h:11,
from ../tester/covoar/app_common.cc:40:
../rtemstoolkit/rld-dwarf-types.h:28:10: fatal error: dwarf.h: No such file
or directory
#include <dwarf.h>
compilation terminated.
from ../tester/covoar/CoverageReaderBase.h:10,
from ../tester/covoar/CoverageFactory.h:12,
from ../tester/covoar/CoverageFactory.cc:13:
or directory
#include <dwarf.h>
from ../tester/covoar/CoverageReaderBase.cc:8:
or directory
#include <dwarf.h>
from ../tester/covoar/CoverageReaderQEMU.cc:14:
or directory
#include <dwarf.h>
Waf: Leaving directory
`/home/lunatic/development/rtems/test/rtems-tools/build'
Build failed
-> task in 'ccovoar' failed with exit status 1:
{task 140568634826336: cxx app_common.cc -> app_common.cc.1.o}
['/usr/bin/g++', '-std=c++11', '-O2', '-g', '-Itester/covoar',
'-I../tester/covoar', '-Irtemstoolkit', '-I../rtemstoolkit',
'-Irtemstoolkit/elftoolchain/libelf',
'-I../rtemstoolkit/elftoolchain/libelf',
'-Irtemstoolkit/elftoolchain/common',
'-I../rtemstoolkit/elftoolchain/common', '-Irtemstoolkit/libiberty',
'-I../rtemstoolkit/libiberty', '../tester/covoar/app_common.cc', '-c',
'-o/home/lunatic/development/rtems/test/rtems-tools/build/tester/covoar/app_common.cc.1.o']
{task 140568634826416: cxx CoverageFactory.cc -> CoverageFactory.cc.1.o}
'-I../rtemstoolkit/libiberty', '../tester/covoar/CoverageFactory.cc', '-c',
'-o/home/lunatic/development/rtems/test/rtems-tools/build/tester/covoar/CoverageFactory.cc.1.o']
{task 140568634392656: cxx CoverageReaderBase.cc ->
CoverageReaderBase.cc.1.o}
'-I../rtemstoolkit/libiberty', '../tester/covoar/CoverageReaderBase.cc',
'-c',
'-o/home/lunatic/development/rtems/test/rtems-tools/build/tester/covoar/CoverageReaderBase.cc.1.o']
{task 140568634392736: cxx CoverageReaderQEMU.cc ->
CoverageReaderQEMU.cc.1.o}
'-I../rtemstoolkit/libiberty', '../tester/covoar/CoverageReaderQEMU.cc',
'-c',
'-o/home/lunatic/development/rtems/test/rtems-tools/build/tester/covoar/CoverageReaderQEMU.cc.1.o']
On 5 May 2018 at 21:47, Joel Sherrill <joel at rtems.org> wrote:
> On Sat, May 5, 2018, 10:57 AM Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> Hello,
>> I'm getting this build failure after applying this patch
>> Build failed
>> {task 140086064254560: cxx app_common.cc -> app_common.cc.1.o}
>> '-Irtemstoolkit/elftoolchain/libelf', '-I../rtemstoolkit/elftoolchain/libelf',
>> '-Irtemstoolkit/elftoolchain/common', '-I../rtemstoolkit/elftoolchain/common',
>> '-Irtemstoolkit/libiberty', '-I../rtemstoolkit/libiberty',
>> '../tester/covoar/app_common.cc', '-c', '-o/home/lunatic/development/
> I don't see an error. Just the command. Does waf -v show more? Were there
> error messages after the command?
>> -- vijay
>> On 5 May 2018 at 14:10, Chris Johns <chrisj at rtems.org> wrote:
>>> tester/covoar/DesiredSymbols.cc | 122 ++----------------------------
>>> tester/covoar/ExecutableInfo.cc | 80 +++++++++++++++++---------
>>> tester/covoar/ExecutableInfo.h | 41 +++++++++++---
>>> tester/covoar/covoar.cc | 2 +-
>>> tester/covoar/wscript | 2 +-
>>> 5 files changed, 94 insertions(+), 153 deletions(-)
>>> diff --git a/tester/covoar/DesiredSymbols.cc b/tester/covoar/
>>> DesiredSymbols.cc
>>> index 9957b28..79ee78d 100644
>>> --- a/tester/covoar/DesiredSymbols.cc
>>> +++ b/tester/covoar/DesiredSymbols.cc
>>> @@ -449,123 +449,13 @@ namespace Coverage {
>>> - char* base;
>>> - char* cStatus;
>>> - char command[512];
>>> - std::string fileName;
>>> - CoverageRanges::ranges_t::iterator ritr;
>>> - char rpath[PATH_MAX];
>>> - FILE* tmpfile;
>>> - // Open a temporary file for the uncovered ranges.
>>> - tmpfile = fopen( "ranges1.tmp", "w" );
>>> - if ( !tmpfile ) {
>>> - fprintf(
>>> - stderr,
>>> - "ERROR: DesiredSymbols::determineSourceLines - "
>>> - "unable to open %s\n",
>>> - "ranges1.tmp"
>>> - exit(-1);
>>> - // Write the range addresses to the temporary file.
>>> - for (ritr = theRanges->set.begin();
>>> - ritr != theRanges->set.end();
>>> - ritr++ ) {
>>> - fprintf(
>>> - tmpfile,
>>> - "0x%08x\n0x%08x\n",
>>> - ritr->lowAddress - theExecutable->getLoadAddress(),
>>> - ritr->highAddress - theExecutable->getLoadAddress()
>>> - fclose( tmpfile );
>>> - // Invoke addr2line to generate the source lines for each address.
>>> - if (theExecutable->hasDynamicLibrary())
>>> - fileName = theExecutable->getLibraryName();
>>> - else
>>> - fileName = theExecutable->getFileName();
>>> - sprintf(
>>> - command,
>>> - "%s -Ce %s <%s | dos2unix >%s",
>>> - TargetInfo->getAddr2line(),
>>> - fileName.c_str(),
>>> - "ranges1.tmp",
>>> - "ranges2.tmp"
>>> - if (system( command )) {
>>> - fprintf(
>>> - stderr,
>>> - "command (%s) failed\n",
>>> - command
>>> - exit( -1 );
>>> - // Open the addr2line output file.
>>> - tmpfile = fopen( "ranges2.tmp", "r" );
>>> - if ( !tmpfile ) {
>>> - fprintf(
>>> - stderr,
>>> - "ranges2.tmp"
>>> - exit(-1);
>>> + for (auto& r : theRanges->set) {
>>> + std::string location;
>>> + theExecutable->getSourceAndLine(r.lowAddress, location);
>>> + r.lowSourceLine = rld::path::basename (location);
>>> + theExecutable->getSourceAndLine(r.highAddress, location);
>>> + r.highSourceLine = rld::path::basename (location);
>>> - // Process the addr2line output.
>>> - ritr++ ) {
>>> - cStatus = fgets( inputBuffer, MAX_LINE_LENGTH, tmpfile );
>>> - if ( cStatus == NULL ) {
>>> - fprintf(
>>> - stderr,
>>> - "Out of sync in addr2line output\n"
>>> - exit( -1 );
>>> - inputBuffer[ strlen(inputBuffer) - 1] = '\0';
>>> - // Use only the base filename without directory path.
>>> -#ifdef _WIN32
>>> - #define realpath(N,R) _fullpath((R),(N),_MAX_PATH)
>>> -#endif
>>> - realpath( inputBuffer, rpath );
>>> - base = basename( rpath );
>>> - ritr->lowSourceLine = std::string( base );
>>> - fprintf(
>>> - stderr,
>>> - exit( -1 );
>>> - ritr->highSourceLine = std::string( base );
>>> - unlink( "ranges1.tmp" );
>>> - unlink( "ranges2.tmp" );
>>> SymbolInformation* DesiredSymbols::find(
>>> diff --git a/tester/covoar/ExecutableInfo.cc b/tester/covoar/
>>> ExecutableInfo.cc
>>> index c41d931..1755e93 100644
>>> --- a/tester/covoar/ExecutableInfo.cc
>>> +++ b/tester/covoar/ExecutableInfo.cc
>>> @@ -7,6 +7,8 @@
>>> #include <stdio.h>
>>> +#include <rld.h>
>>> #include "ExecutableInfo.h"
>>> #include "app_common.h"
>>> #include "CoverageMap.h"
>>> @@ -18,24 +20,36 @@ namespace Coverage {
>>> ExecutableInfo::ExecutableInfo(
>>> const char* const theExecutableName,
>>> const char* const theLibraryName
>>> + ) : executable(theExecutableName),
>>> + loadAddress(0)
>>> - executableName = theExecutableName;
>>> - loadAddress = 0;
>>> - libraryName = "";
>>> if (theLibraryName)
>>> libraryName = theLibraryName;
>>> - theSymbolTable = new SymbolTable();
>>> + try {
>>> + executable.open();
>>> + executable.begin();
>>> + executable.load_symbols(symbols);
>>> + debug.begin(executable.elf());
>>> + debug.load_debug();
>>> + } catch (rld::error re) {
>>> + std::cerr << "error: "
>>> + << re.where << ": " << re.what
>>> + << std::endl;
>>> + exit(2);
>>> + } catch (...) {
>>> + exit(2);
>>> ExecutableInfo::~ExecutableInfo()
>>> - if (theSymbolTable)
>>> - delete theSymbolTable;
>>> + debug.end();
>>> + executable.end();
>>> + executable.close();
>>> void ExecutableInfo::dumpCoverageMaps( void ) {
>>> - ExecutableInfo::coverageMaps_t::iterator itr;
>>> + ExecutableInfo::CoverageMaps::iterator itr;
>>> for (itr = coverageMaps.begin(); itr != coverageMaps.end(); itr++) {
>>> fprintf( stderr, "Coverage Map for %s\n", ((*itr).first).c_str()
>>> @@ -44,21 +58,22 @@ namespace Coverage {
>>> void ExecutableInfo::dumpExecutableInfo( void ){
>>> - fprintf( stdout, "\n== Executable info ==\n");
>>> - fprintf( stdout, "executableName = %s\n", executableName.c_str());
>>> - fprintf( stdout, "libraryName = %s\n", libraryName.c_str());
>>> - fprintf( stdout, "loadAddress = %u\n", loadAddress);
>>> - theSymbolTable->dumpSymbolTable();
>>> + std::cout << std::endl
>>> + << "== Executable info ==" << std::endl
>>> + << "executable = " << getFileName () << std::endl
>>> + << "library = " << libraryName << std::endl
>>> + << "loadAddress = " << loadAddress << std::endl;
>>> + theSymbolTable.dumpSymbolTable();
>>> CoverageMapBase* ExecutableInfo::getCoverageMap ( uint32_t address )
>>> - CoverageMapBase* aCoverageMap = NULL;
>>> - coverageMaps_t::iterator it;
>>> - std::string itsSymbol;
>>> + CoverageMapBase* aCoverageMap = NULL;
>>> + CoverageMaps::iterator it;
>>> + std::string itsSymbol;
>>> // Obtain the coverage map containing the specified address.
>>> - itsSymbol = theSymbolTable->getSymbol( address );
>>> + itsSymbol = theSymbolTable.getSymbol( address );
>>> if (itsSymbol != "") {
>>> it = coverageMaps.find( itsSymbol );
>>> aCoverageMap = (*it).second;
>>> @@ -67,12 +82,12 @@ namespace Coverage {
>>> return aCoverageMap;
>>> - const std::string& ExecutableInfo::getFileName ( void ) const
>>> + const std::string ExecutableInfo::getFileName ( void ) const
>>> - return executableName;
>>> + return executable.name().full();
>>> - const std::string& ExecutableInfo::getLibraryName( void ) const
>>> + const std::string ExecutableInfo::getLibraryName( void ) const
>>> return libraryName;
>>> @@ -83,9 +98,9 @@ namespace Coverage {
>>> - SymbolTable* ExecutableInfo::getSymbolTable ( void ) const
>>> + SymbolTable* ExecutableInfo::getSymbolTable ( void )
>>> - return theSymbolTable;
>>> + return &theSymbolTable;
>>> CoverageMapBase* ExecutableInfo::createCoverageMap (
>>> @@ -95,8 +110,8 @@ namespace Coverage {
>>> uint32_t highAddress
>>> - CoverageMapBase *theMap;
>>> + CoverageMapBase *theMap;
>>> itr = coverageMaps.find( symbolName );
>>> if ( itr == coverageMaps.end() ) {
>>> @@ -109,13 +124,26 @@ namespace Coverage {
>>> return theMap;
>>> + void ExecutableInfo::getSourceAndLine(
>>> + const unsigned int address,
>>> + std::string& line
>>> + std::string file;
>>> + int lno;
>>> + debug.get_source (address, file, lno);
>>> + std::ostringstream ss;
>>> + ss << file << ':' << lno;
>>> + line = ss.str ();
>>> bool ExecutableInfo::hasDynamicLibrary( void )
>>> - return (libraryName != "");
>>> + return !libraryName.empty();
>>> void ExecutableInfo::mergeCoverage( void ) {
>>> SymbolsToAnalyze->mergeCoverageMap( (*itr).first, (*itr).second
>>> diff --git a/tester/covoar/ExecutableInfo.h b/tester/covoar/
>>> ExecutableInfo.h
>>> index 20ea9bf..9106db3 100644
>>> --- a/tester/covoar/ExecutableInfo.h
>>> +++ b/tester/covoar/ExecutableInfo.h
>>> @@ -11,6 +11,10 @@
>>> #include <stdint.h>
>>> #include <string>
>>> +#include <rld-dwarf.h>
>>> +#include <rld-files.h>
>>> +#include <rld-symbols.h>
>>> #include "CoverageMapBase.h"
>>> #include "SymbolTable.h"
>>> @@ -67,14 +71,14 @@ namespace Coverage {
>>> * @return Returns the executable's file name
>>> - const std::string& getFileName( void ) const;
>>> + const std::string getFileName( void ) const;
>>> * This method returns the library name associated with the
>>> executable.
>>> * @return Returns the executable's library name
>>> - const std::string& getLibraryName( void ) const;
>>> + const std::string getLibraryName( void ) const;
>>> * This method returns the load address of the dynamic library
>>> @@ -88,7 +92,7 @@ namespace Coverage {
>>> * @return Returns a pointer to the symbol table.
>>> - SymbolTable* getSymbolTable( void ) const;
>>> + SymbolTable* getSymbolTable( void );
>>> * This method creates a coverage map for the specified symbol.
>>> @@ -107,6 +111,15 @@ namespace Coverage {
>>> + * This method gets the source location, the file and line number
>>> given an
>>> + * address.
>>> + void getSourceAndLine(
>>> + std::string& location
>>> * This method indicates whether a dynamic library has been
>>> * associated with the executable.
>>> @@ -132,15 +145,25 @@ namespace Coverage {
>>> private:
>>> - * This map associates a symbol with its coverage map.
>>> + * The ELF executable.
>>> - typedef std::map<std::string, CoverageMapBase *> coverageMaps_t;
>>> - coverageMaps_t coverageMaps;
>>> + rld::files::object executable;
>>> - * This member variable contains the name of the executable.
>>> + * The DWARF data to the ELF executable.
>>> + rld::dwarf::file debug;
>>> + * The executable's symbol table.
>>> + rld::symbols::table symbols;
>>> + * This map associates a symbol with its coverage map.
>>> - std::string executableName;
>>> + typedef std::map<std::string, CoverageMapBase *> CoverageMaps;
>>> + CoverageMaps coverageMaps;
>>> * This member variable contains the name of a dynamic library
>>> @@ -158,7 +181,7 @@ namespace Coverage {
>>> * This member variable contains a pointer to the symbol table
>>> * of the executable or library.
>>> - SymbolTable* theSymbolTable;
>>> + SymbolTable theSymbolTable;
>>> diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
>>> index 5c87402..09c86c2 100644
>>> --- a/tester/covoar/covoar.cc
>>> +++ b/tester/covoar/covoar.cc
>>> @@ -186,7 +186,7 @@ int main(
>>> Coverage::ExecutableInfo* executableInfo = NULL;
>>> std::string executableExtension = "exe";
>>> std::string coverageExtension = "cov";
>>> - Coverage::CoverageFormats_t coverageFormat;
>>> + Coverage::CoverageFormats_t coverageFormat =
>>> Coverage::COVERAGE_FORMAT_QEMU;
>>> Coverage::CoverageReaderBase* coverageReader = NULL;
>>> char* executable = NULL;
>>> const char* explanations = NULL;
>>> diff --git a/tester/covoar/wscript b/tester/covoar/wscript
>>> index c0270d8..55d5ec9 100644
>>> --- a/tester/covoar/wscript
>>> +++ b/tester/covoar/wscript
>>> @@ -70,7 +70,7 @@ def build(bld):
>>> # The list of modules.
>>> - modules = ['rld', 'elf', 'iberty']
>>> + modules = ['rld', 'dwarf', 'elf', 'iberty']
>>> bld.stlib(target = 'ccovoar',
>>> source = ['app_common.cc',
>>> 2.15.1
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180505/fe5b8de6/attachment-0001.html>
