Fwd: [PATCH 2/4] covoar: Use DWARF to map addresses to source files and lines.
Sun May 6 07:59:46 UTC 2018
On 6/5/18 5:28 pm, Vijay Kumar Banerjee wrote:
> On 6 May 2018 at 08:54, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>         Would you please try `waf clean build` to see if rebuilding
>         everything fixes this?
> still getting the same error .
> I'm using g++ 7.3.1 on fedora 27.
OK
> If you have changed something in the code, can you please send a patch
> for the same ?
I have not changed anything. I do not have a Linux box to try.
