[PATCH v2] x86_64/gcc: Add gcc patch for LIB_SPEC (rtems.h in gcc)
Amaan Cheval amaan.cheval at gmail.com
Mon May 7 17:16:02 UTC 2018
I'm not quite sure how GCC's releases work; it seems like GCC 8.1 has
already been released:
https://gcc.gnu.org/releases.html
https://ftp.gnu.org/gnu/gcc/gcc-8.1.0/
However, the "gcc-7-branch" is still being pushed to:
https://gcc.gnu.org/git/?p=gcc.git;a=shortlog;h=refs/heads/gcc-7-branch
What would pushing to that branch entail? Is it simply to make
applying the patch to a 7.3 release easier?
I only meant to make the patch to the RSB because:
- I'm not sure when the RSB will move to using GCC 8.1+ (we still use 7.3)
- It's better to have the RSB build the tooling the same for my dev
environment as the community will have, without needing manual patches
for building the tools
I'm okay to just make a note about the patch if we'd rather not have
it in the RSB in case by the end of the port, GCC has released a
version including the patches which we can simply switch to using.
Let me know if you prefer the latter!
On Mon, May 7, 2018 at 10:28 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Mon, May 7, 2018 at 11:56 AM, Amaan Cheval <amaan.cheval at gmail.com>
> wrote:
>> Thanks a ton! I'll likely make the corresponding RSB patch to backport
>> this to GCC 7.3 tomorrow for Chris to review :)
> If need be, we can address pushing it to open gcc branches. I didn't see it
> as critical as this was a new port but am happy to do it.
> If it goes on the 7 branch, it needs to go on the 8 branch though.
>> On Mon, May 7, 2018 at 10:03 PM, Joel Sherrill <joel at rtems.org> wrote:
>> > On Fri, May 4, 2018 at 4:25 PM, Joel Sherrill <joel at rtems.org> wrote:
>> >> On Fri, May 4, 2018 at 4:58 AM, Amaan Cheval <amaan.cheval at gmail.com>
>> >> wrote:
>> >>> On Fri, May 4, 2018 at 7:54 AM Joel Sherrill <joel at rtems.org> wrote:
>> >>> > I am now confused. Do I need to get a patch into GCC?
>> >>> Hey!
>> >>> Sorry about the confusion. Technically the answer is yes, but it's
>> >>> unrelated to _this_ patch.
>> >>> To clear things up:
>> >>> - [DONE] You already committed a previous patch for GCC for -qrtems,
>> >>> -qnolinkcmds, etc.
>> >>> https://gcc.gnu.org/git/?p=gcc.git;a=commitdiff;h=602fa1e9d3ea5e87d4d6e17e3e91fc2647e42da3
>> >>> - [DONE] This email thread backports the above patch to
>> >>> rtems-source-builder so that we can use it in GCC 7.3. Chris accepted
>> >>> this
>> >>> patch into rtems-source-builder here
>> >>> https://git.rtems.org/rtems-source-builder/commit/?id=defa958301215995b0fa41d8e65cb23c9a28a847
>> >>> - [PENDING - Joel] I recently made a GCC patch to have GCC build
>> >>> crti.o
>> >>> and
>> >>> crtn.o for the x86-64 RTEMS tools, so we can have symbols like "_fini"
>> >>> added automatically through our bsp_specs file, the way we do for
>> >>> other
>> >>> architectures. As Sebastian mentioned in an email to you and me, I
>> >>> believe
>> >>> he'd prefer if you reviewed the patch here:
>> >>>    https://gcc.gnu.org/ml/gcc-patches/2018-05/msg00126.html
>> >>> - [PENDING - Amaan, and later Chris] Once the crti.o patch above is
>> >>> merged
>> >>> into GCC, I'll make a corresponding backport patch to
>> >>> to make that available to GCC 7.3 as well, and then Chris can review +
>> >>> merge that in after.
>> >> I meant to deal with this today.
>> >> I am leaving myself a note to get this merged next week. Ping me in the
>> >> middle
>> >> of next week if you haven't heard action.
>> > This is now committed on the gcc master.
>> > https://gcc.gnu.org/ml/gcc-cvs/2018-05/msg00226.html
>> > Hopefully that helps clean up the RSB.
>> >>> Hope that clears things up!
>> >> It does.
>> >>> > On Thu, May 3, 2018, 8:38 PM Chris Johns <chrisj at rtems.org> wrote:
>> >>> >> On 07/04/2018 08:35, Amaan Cheval wrote:
>> >>> >> > Adds -qnolinkcmds, -qrtems, and defaults to pass to linker, for
>> >>> >> > gcc targeting x86_64.
>> >>> >> Pushed, thank you.
>> >>> >> Chris
>> >>> >> _______________________________________________
>> >>> >> devel mailing list
>> >>> >> devel at rtems.org
>> >>> >> http://lists.rtems.org/mailman/listinfo/devel
>> >>> > devel mailing list
>> >>> > devel at rtems.org
