Fwd: [PATCH 2/4] covoar: Use DWARF to map addresses to source files and lines.
Cillian O'Donnell cpodonnell8 at gmail.com
Mon May 7 18:59:58 UTC 2018
On 7 May 2018 at 18:56, Joel Sherrill <joel at rtems.org> wrote:
> Hi
> I have attached a workaround. It seems that libgen.h has this:
> /* Return final component of PATH.
>    This is the weird XPG version of this function.  It sometimes will
>    modify its argument.  Therefore we normally use the GNU version (in
>    <string.h>) and only if this header is included make the XPG
>    version available under the real name.  */
> extern char *__xpg_basename (char *__path) __THROW;
> #define basename        __xpg_basename
> Chris has used basename as a method name and even though that should
> be perfectly acceptable, the macro above gets expanded, the name
> gets changed (in some places) to rld::path::__xpg_basename()
>       r.lowSourceLine = rld::path::basename (location);
> IMO the fix is to add dirname to rld-files, use rld basename and dirname
> exclusively, and avoid libgen.h at all costs.
> I didn't do that much work. I got lucky in a couple of files by removing
> the
> include of libgen.h since it wasn't needed but I had to leave it in one
> place.
> $ grep dirname *.cc
> GcovData.cc:    dirname( path );
> Hopefully this lets you all proceed with Chris' patches and my slight hack
> in place.
Thanks Joel! The good news is that's building now with only a couple of
warnings.
The bad news is..
cpod at cpod ~/development/rtems/leon3 $ covoar -S
/home/cpod/development/rtems/test/rtems-tools/tester/rtems/testing/coverage/score-symbols.ini
-O /home/cpod/coverage_test/test/score
-E/home/cpod/development/rtems/test/rtems-tools/tester/rtems/testing/coverage/Explanations.txt
-p RTEMS-5 -v sparc-rtems5/c/leon3/testsuites/samples/hello/hello.exe
*** Error in `covoar': free(): invalid next size (fast): 0x0000000001000360
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x777e5)[0x7fcd0b3477e5]
/lib/x86_64-linux-gnu/libc.so.6(+0x8037a)[0x7fcd0b35037a]
/lib/x86_64-linux-gnu/libc.so.6(cfree+0x4c)[0x7fcd0b35453c]
covoar[0x43fcee]
covoar[0x42bc4a]
covoar[0x42d205]
covoar[0x40dec5]
covoar[0x4054b6]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fcd0b2f0830]
covoar[0x4073e9]
======= Memory map: ========
00400000-004a8000 r-xp 00000000 08:07 3276534
/home/cpod/development/rtems/test/rtems-tools/build/tester/covoar/covoar
006a7000-006a8000 r--p 000a7000 08:07 3276534
006a8000-006a9000 rw-p 000a8000 08:07 3276534
006a9000-006aa000 rw-p 00000000 00:00 0
00c6a000-01022000 rw-p 00000000 00:00 0
[heap]
7fcd04000000-7fcd04021000 rw-p 00000000 00:00 0
7fcd04021000-7fcd08000000 ---p 00000000 00:00 0
7fcd0a9ae000-7fcd0ac36000 rw-p 00000000 00:00 0
7fcd0ac36000-7fcd0afc7000 r--p 00000000 08:07 2759194
/home/cpod/development/rtems/leon3/sparc-rtems5/c/leon3/testsuites/samples/hello/hello.exe
7fcd0afc7000-7fcd0b0cf000 r-xp 00000000 08:07 1838070
/lib/x86_64-linux-gnu/libm-2.23.so
7fcd0b0cf000-7fcd0b2ce000 ---p 00108000 08:07 1838070
7fcd0b2ce000-7fcd0b2cf000 r--p 00107000 08:07 1838070
7fcd0b2cf000-7fcd0b2d0000 rw-p 00108000 08:07 1838070
7fcd0b2d0000-7fcd0b490000 r-xp 00000000 08:07 1842682
/lib/x86_64-linux-gnu/libc-2.23.so
7fcd0b490000-7fcd0b690000 ---p 001c0000 08:07 1842682
7fcd0b690000-7fcd0b694000 r--p 001c0000 08:07 1842682
7fcd0b694000-7fcd0b696000 rw-p 001c4000 08:07 1842682
7fcd0b696000-7fcd0b69a000 rw-p 00000000 00:00 0
7fcd0b69a000-7fcd0b6b0000 r-xp 00000000 08:07 1836727
/lib/x86_64-linux-gnu/libgcc_s.so.1
7fcd0b6b0000-7fcd0b8af000 ---p 00016000 08:07 1836727
7fcd0b8af000-7fcd0b8b0000 rw-p 00015000 08:07 1836727
7fcd0b8b0000-7fcd0ba22000 r-xp 00000000 08:07 1049309
/usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.21
7fcd0ba22000-7fcd0bc22000 ---p 00172000 08:07 1049309
7fcd0bc22000-7fcd0bc2c000 r--p 00172000 08:07 1049309
7fcd0bc2c000-7fcd0bc2e000 rw-p 0017c000 08:07 1049309
7fcd0bc2e000-7fcd0bc32000 rw-p 00000000 00:00 0
7fcd0bc32000-7fcd0bc58000 r-xp 00000000 08:07 1838072
/lib/x86_64-linux-gnu/ld-2.23.so
7fcd0bd72000-7fcd0be30000 rw-p 00000000 00:00 0
7fcd0be56000-7fcd0be57000 rw-p 00000000 00:00 0
7fcd0be57000-7fcd0be58000 r--p 00025000 08:07 1838072
7fcd0be58000-7fcd0be59000 rw-p 00026000 08:07 1838072
7fcd0be59000-7fcd0be5a000 rw-p 00000000 00:00 0
7ffc5053b000-7ffc5055d000 rw-p 00000000 00:00 0
[stack]
7ffc505d5000-7ffc505d7000 r--p 00000000 00:00 0
[vvar]
7ffc505d7000-7ffc505d9000 r-xp 00000000 00:00 0
[vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0
[vsyscall]
Aborted
> Ultimate solution is probably simple. We just need to hear from Chris.
> --joel
> On Mon, May 7, 2018 at 12:42 PM, Joel Sherrill <joel at rtems.org> wrote:
>> On Mon, May 7, 2018 at 12:36 PM, Vijay Kumar Banerjee <
>> vijaykumar9597 at gmail.com> wrote:
>>> On Mon, 7 May 2018, 22:57 Cillian O'Donnell, <cpodonnell8 at gmail.com>
>>> wrote:
>>>> Yeah I'm seeing the same as Joel, at least were further then we were :).
>>>> I've been mostly working on the rtems-tester support, so just to give
>>>> an update. I spent all day Saturday and today on it. It's taking longer
>>>> than expected, re-orienting myself and deciding what is needed and not
>>>> needed now with the changes in covoar. The problems are not difficult, it's
>>>> just taking some time re-organizing everything. My time is limited during
>>>> the week, so it'll probably be next weekend before I can finish it off.
>>>> Vijay if you have time during the week I could push what I have and you
>>>> could take a stab at some of them and then I could it finish off next
>>>> weekend if you haven't already.
>>> please send them, I can look into them for sure.
>> Keep plugging away.
>> I think there is something wrong in rld related to basename. My first
>> thought was that the undefined symbol was because we didn't include the
>> library. Now I think it is because something got misconfigured on
>> Centos/Fedora/etc. Looking into this.
>>>> On 7 May 2018 at 15:40, Joel Sherrill <joel at rtems.org> wrote:
>>>>> On Mon, May 7, 2018 at 6:01 AM, Vijay Kumar Banerjee <
>>>>>> I have added the path to libdwarf here
>>>>> That worked for me to build but not to link.
>>>>> I'm not sure why this rld symbol turned up missing on Centos 7.
>>>>> $ ./waf -v
>>>>> Waf: Entering directory `/home/joel/rtems-work/rtems-tools/build'
>>>>> [228/229] Linking build/tester/covoar/trace-converter
>>>>> 09:38:25 runner ['/usr/bin/g++', 'tester/covoar/TraceConverter.cc.2.o',
>>>>> 'tester/covoar/TraceList.cc.2.o', 'tester/covoar/TraceReaderBase.cc.2.o',
>>>>> 'tester/covoar/TraceReaderLogQEMU.cc.2.o',
>>>>> 'tester/covoar/TraceWriterBase.cc.2.o', 'tester/covoar/TraceWriterQEMU.cc.2.o',
>>>>> '-o/home/joel/rtems-work/rtems-tools/build/tester/covoar/trace-converter',
>>>>> '-Wl,-Bstatic', '-Ltester/covoar', '-Lrtemstoolkit', '-lccovoar', '-lrld',
>>>>> '-ldwarf', '-lelf', '-liberty', '-Wl,-Bdynamic']
>>>>> [229/229] Linking build/tester/covoar/covoar
>>>>> 09:38:25 runner ['/usr/bin/g++', 'tester/covoar/covoar.cc.3.o',
>>>>> '-o/home/joel/rtems-work/rtems-tools/build/tester/covoar/covoar',
>>>>> tester/covoar/libccovoar.a(DesiredSymbols.cc.1.o): In function
>>>>> `Coverage::DesiredSymbols::determineSourceLines(Coverage::CoverageRanges*,
>>>>> Coverage::ExecutableInfo*)':
>>>>> /home/joel/rtems-work/rtems-tools/build/../tester/covoar/DesiredSymbols.cc:413:
>>>>> undefined reference to `rld::path::__xpg_basename(std::string const&)'
>>>>> /home/joel/rtems-work/rtems-tools/build/../tester/covoar/DesiredSymbols.cc:415:
>>>>> collect2: error: ld returned 1 exit status
>>>>> Waf: Leaving directory `/home/joel/rtems-work/rtems-tools/build'
>>>>> Build failed
>>>>>  -> task in 'trace-converter' failed with exit status 1:
>>>>>         {task 34721616: cxxprogram TraceConverter.cc.2.o,TraceLis
>>>>> t.cc.2.o,TraceReaderBase.cc.2.o,TraceReaderLogQEMU.cc.2.o,Tr
>>>>> aceWriterBase.cc.2.o,TraceWriterQEMU.cc.2.o -> trace-converter}
>>>>>  -> task in 'covoar' failed with exit status 1:
>>>>>         {task 34820256: cxxprogram covoar.cc.3.o -> covoar}
>>>>>> diff --git a/tester/covoar/wscript b/tester/covoar/wscript
>>>>>> index 55d5ec9..dd4ad83 100644
>>>>>> --- a/tester/covoar/wscript
>>>>>> +++ b/tester/covoar/wscript
>>>>>> @@ -63,6 +63,7 @@ def build(bld):
>>>>>>      rtl_includes = [rtemstoolkit,
>>>>>>  		    rtemstoolkit + '/elftoolchain/libelf',
>>>>>>  		    rtemstoolkit + '/elftoolchain/common',
>>>>>> +		    rtemstoolkit + '/elftoolchain/libdwarf',
>>>>>>  		    rtemstoolkit + '/libiberty']
>>>>>>      if bld.env.DEST_OS == 'win32':
>>>>>>          rtl_includes += [rtemstoolkit + '/win32']
>>>>>> -- vijay
>>>>>> On 7 May 2018 at 13:30, Vijay Kumar Banerjee <
>>>>>>> On 6 May 2018 at 13:29, Chris Johns <chrisj at rtems.org> wrote:
>>>>>>>> On 6/5/18 5:28 pm, Vijay Kumar Banerjee wrote:
>>>>>>>>> On 6 May 2018 at 08:54, Chris Johns <chrisj at rtems.org <mailto:
>>>>>>>>> chrisj at rtems.org>> wrote:
>>>>>>>>>         Would you please try `waf clean build` to see if rebuilding
>>>>>>>>>         everything fixes this?
>>>>>>>>> still getting the same error .
>>>>>>>>> I'm using g++ 7.3.1 on fedora 27.
>>>>>>>> OK
>>>>>>>> If you have changed something in the code, can you please send a
>>>>>>>>> patch for the same ?
>>>>>>>> I have not changed anything. I do not have a Linux box to try.
>>>>>>>> I tried to do it afresh as well, it's still failing to build.
>>>>>>> Can someone please try to build it in a linux system ?
>>>>>>>> Chris
>>>>>> _______________________________________________
>>>>>> devel mailing list
>>>>>> devel at rtems.org
>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>> devel mailing list
>>>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180507/9b5d5257/attachment-0001.html>
