Fwd: [PATCH 2/4] covoar: Use DWARF to map addresses to source files and lines.
Mon May 7 20:58:05 UTC 2018
On 08/05/2018 05:16, Cillian O'Donnell wrote:
> Heres the gdb backtrace. rld-dwarf.cpp rld-path showing up near the bottom. I
> don't have valgrind, I'll get it now and see what I find there.
Thank you for the backtrace.
I have fixed this. The rld::path::path_abs() call does not like the relative
path have more '..' than the current working directory. It tries to step up path
the root directory.
