[PATCH v2] x86_64/gcc: Add gcc patch for LIB_SPEC (rtems.h in gcc)
Mon May 7 23:13:49 UTC 2018
On 08/05/2018 03:58, Joel Sherrill wrote:
> On Mon, May 7, 2018 at 12:16 PM, Amaan Cheval <amaan.cheval at gmail.com
> <mailto:amaan.cheval at gmail.com>> wrote:
>     I'm not quite sure how GCC's releases work; it seems like GCC 8.1 has
>     already been released:
>     https://gcc.gnu.org/releases.html <https://gcc.gnu.org/releases.html>
>     https://ftp.gnu.org/gnu/gcc/gcc-8.1.0/ <https://ftp.gnu.org/gnu/gcc/gcc-8.1.0/>
>     However, the "gcc-7-branch" is still being pushed to:
>     https://gcc.gnu.org/git/?p=gcc.git;a=shortlog;h=refs/heads/gcc-7-branch
>     <https://gcc.gnu.org/git/?p=gcc.git;a=shortlog;h=refs/heads/gcc-7-branch>
>     What would pushing to that branch entail? Is it simply to make
>     applying the patch to a 7.3 release easier?
>     I only meant to make the patch to the RSB because:
>     - I'm not sure when the RSB will move to using GCC 8.1+ (we still use 7.3)
>     - It's better to have the RSB build the tooling the same for my dev
>     environment as the community will have, without needing manual patches
>     for building the tools
>     I'm okay to just make a note about the patch if we'd rather not have
>     it in the RSB in case by the end of the port, GCC has released a
>     version including the patches which we can simply switch to using.
>     Let me know if you prefer the latter!
> Unless gcc makes a release from the branch, we will have to continue
> to have a patch.
A patch is fine. The cleaner and closer the patch is to a possible release the
better. Once we have a release we can remove the patch.
> Chris is on holiday. Let's see what he wants done when he gets back.
I wish. I am here and working. I did go sailing on the weekend, but that was
just a day of racing on Sydney harbour and the weather was so lovely, almost too
good cause there was no wind and we all just sat about.
