[PATCH v3 1/2] dhcpcd: Add rtems_dhcpcd_start()
Tue May 8 04:51:46 UTC 2018
Use it throughout to start the DHCP client (dhcpcd).
 dhcpcd/dhcpcd.c                                    | 70 +++++++++++++++++-
 dhcpcd/namespace.h                                 |  4 ++
 rtemsbsd/include/machine/rtems-bsd-commands.h      |  2 -
 rtemsbsd/include/rtems/dhcpcd.h                    | 84 ++++++++++++++++++++++
 rtemsbsd/rtems/rtems-bsd-init-dhcp.c               | 35 +--------
 rtemsbsd/rtems/rtems-bsd-rc-conf-net.c             | 57 +++++++--------
 rtemsbsd/rtems/rtems-bsd-shell-dhcpcd.c            | 68 +++++++++++++++++-
 .../include/rtems/bsd/test/default-network-init.h  | 37 ++--------
 8 files changed, 254 insertions(+), 103 deletions(-)
 create mode 100644 rtemsbsd/include/rtems/dhcpcd.h
diff --git a/dhcpcd/dhcpcd.c b/dhcpcd/dhcpcd.c
index 8074f3fc3..59562d635 100644
--- a/dhcpcd/dhcpcd.c
+++ b/dhcpcd/dhcpcd.c
@@ -1110,22 +1110,86 @@ signal_init(void (*func)(int, siginfo_t *, void *), sigset_t *oldset)
 #endif
 #ifdef __rtems__
+#include <rtems/dhcpcd.h>
 #include <rtems/libio.h>
+#include <assert.h>
+rtems_recursive_mutex dhcpcd_mutex =
+    RTEMS_RECURSIVE_MUTEX_INITIALIZER("dhcpcd");
+static bool dhcpcd_initialized;
 struct getopt_data dhcpcd_getopt_data;
 static int
 main(int argc, char **argv);
-int rtems_bsd_command_dhcpcd(int argc, char **argv)
+static void
+dhcpcd_task(rtems_task_argument arg)
+	char *default_argv[] = { "dhcpcd", NULL };
+	const rtems_dhcpcd_config *config;
+	int argc;
+	char **argv;
 	int exit_code;
-	rtems_mkdir(DBDIR, S_IRWXU | S_IRWXG | S_IRWXO);
+	config = (const rtems_dhcpcd_config *)arg;
+	if (config != NULL) {
+		argc = config->argc;
+		argv = config->argv;
+	} else {
+		argc = RTEMS_BSD_ARGC(default_argv);
+		argv = default_argv;
+	if (config != NULL && config->prepare != NULL) {
+		(*config->prepare)(config, argc, argv);
+	rtems_mkdir(DBDIR, S_IRWXU | S_IRWXG | S_IRWXO);
 	exit_code = rtems_bsd_program_call_main("dhcpcd", main, argc, argv);
-	return exit_code;
+	if (config != NULL && config->destroy != NULL) {
+		(*config->destroy)(config, exit_code);
+	rtems_task_delete(RTEMS_SELF);
+rtems_status_code
+rtems_dhcpcd_start(const rtems_dhcpcd_config *config)
+	rtems_status_code sc;
+	rtems_recursive_mutex_lock(&dhcpcd_mutex);
+	if (!dhcpcd_initialized) {
+		rtems_task_priority priority;
+		rtems_id id;
+		if (config != NULL && config->priority != 0) {
+			priority = config->priority;
+		} else {
+			priority = RTEMS_MAXIMUM_PRIORITY - 1;
+		sc = rtems_task_create(rtems_build_name('D', 'H', 'C', 'P'), priority,
+		    2 * RTEMS_MINIMUM_STACK_SIZE, RTEMS_DEFAULT_MODES,
+		    RTEMS_FLOATING_POINT, &id);
+		if (sc == RTEMS_SUCCESSFUL) {
+			dhcpcd_initialized = true;
+			sc = rtems_task_start(id, dhcpcd_task, 0);
+			assert(sc == RTEMS_SUCCESSFUL);
+	} else {
+		sc = RTEMS_INCORRECT_STATE;
+	rtems_recursive_mutex_unlock(&dhcpcd_mutex);
+	return sc;
 #endif /* __rtems__ */
diff --git a/dhcpcd/namespace.h b/dhcpcd/namespace.h
index 7299c7d0b..efff909ad 100644
--- a/dhcpcd/namespace.h
+++ b/dhcpcd/namespace.h
@@ -1,3 +1,7 @@
+#include <rtems/thread.h>
+extern rtems_recursive_mutex dhcpcd_mutex;
 #define add_options dhcpcd_add_options
 #define arp_announce dhcpcd_arp_announce
 #define arp_probe dhcpcd_arp_probe
diff --git a/rtemsbsd/include/machine/rtems-bsd-commands.h b/rtemsbsd/include/machine/rtems-bsd-commands.h
index 32aba44c1..7e72627d1 100644
--- a/rtemsbsd/include/machine/rtems-bsd-commands.h
+++ b/rtemsbsd/include/machine/rtems-bsd-commands.h
@@ -60,8 +60,6 @@ int rtems_bsd_command_ping6(int argc, char **argv);
 int rtems_bsd_command_route(int argc, char **argv);
-int rtems_bsd_command_dhcpcd(int argc, char **argv);
 int rtems_bsd_command_wpa_supplicant(int argc, char **argv);
 int rtems_bsd_command_wpa_supplicant_fork(int argc, char **argv);
diff --git a/rtemsbsd/include/rtems/dhcpcd.h b/rtemsbsd/include/rtems/dhcpcd.h
new file mode 100644
index 000000000..324c8a90b
--- /dev/null
+++ b/rtemsbsd/include/rtems/dhcpcd.h
@@ -0,0 +1,84 @@
+ * @file
+ * @ingroup rtems_bsd
+ * @brief TODO.
+ * Copyright (c) 2018 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#ifndef _RTEMS_DHCPCD_H_
+#define _RTEMS_DHCPCD_H_
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @brief The DHCP client configuration (dhcpcd).
+ * Zero initialize the structure to allow future extensions.
+typedef struct rtems_dhcpcd_config {
+	int argc;
+	char **argv;
+	void (*prepare)(const struct rtems_dhcpcd_config *config,
+	    int argc, char **argv);
+	void (*destroy)(const struct rtems_dhcpcd_config *config,
+	    int exit_code);
+} rtems_dhcpcd_config;
+ * @brief Starts the DHCP client (dhcpcd).
+ * @param config The DHCP client configuration.  Use NULL for a default
+ * configuration.
+ * @retval RTEMS_SUCCESSFUL Successful operation.
+ * @retval RTEMS_INCORRECT_STATE The DHCP client runs already.
+ * @retval RTEMS_TOO_MANY No task control block available.
+ * @retval RTEMS_UNSATISFIED Not enough resources to create task.
+ * @retval RTEMS_INVALID_PRIORITY Invalid task priority.
+rtems_status_code rtems_dhcpcd_start(const rtems_dhcpcd_config *config);
+#ifdef __cplusplus
+#endif /* _RTEMS_DHCPCD_H_ */
diff --git a/rtemsbsd/rtems/rtems-bsd-init-dhcp.c b/rtemsbsd/rtems/rtems-bsd-init-dhcp.c
index 1115e40a8..e0a298f7e 100644
--- a/rtemsbsd/rtems/rtems-bsd-init-dhcp.c
+++ b/rtemsbsd/rtems/rtems-bsd-init-dhcp.c
@@ -7,7 +7,7 @@
- * Copyright (c) 2009-2015 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2009, 2018 embedded brains GmbH.  All rights reserved.
  *  Dornierstr. 4
@@ -38,36 +38,17 @@
 #include <rtems/bsd/bsd.h>
-#include <assert.h>
 #include <sysexits.h>
-#include <machine/rtems-bsd-commands.h>
 #include <bsp.h>
-static void
-dhcpcd_task(rtems_task_argument arg)
-	int exit_code;
-	char *dhcpcd[] = {
-	    "dhcpcd",
-	    NULL
-	(void)arg;
-	exit_code = rtems_bsd_command_dhcpcd(RTEMS_BSD_ARGC(dhcpcd), dhcpcd);
-	assert(exit_code == EX_OK);
-	(void)exit_code;
 rtems_status_code
 rtems_bsd_initialize_dhcp(void)
 	int exit_code;
-	rtems_id id;
 	sc = rtems_bsd_initialize();
 	if (sc != RTEMS_SUCCESSFUL) {
@@ -79,21 +60,11 @@ rtems_bsd_initialize_dhcp(void)
 		return (RTEMS_UNSATISFIED);
-	sc = rtems_task_create(
-		rtems_build_name('D', 'H', 'C', 'P'),
-		RTEMS_MAXIMUM_PRIORITY - 1,
-		2 * RTEMS_MINIMUM_STACK_SIZE,
-		RTEMS_DEFAULT_MODES,
-		RTEMS_FLOATING_POINT,
-		&id
+	sc = rtems_dhcpcd_start(NULL);
-	sc = rtems_task_start(id, dhcpcd_task, 0);
-	assert(sc == RTEMS_SUCCESSFUL);
 	return (RTEMS_SUCCESSFUL);
diff --git a/rtemsbsd/rtems/rtems-bsd-rc-conf-net.c b/rtemsbsd/rtems/rtems-bsd-rc-conf-net.c
index 0a5b3aaec..bedf3bc06 100644
--- a/rtemsbsd/rtems/rtems-bsd-rc-conf-net.c
+++ b/rtemsbsd/rtems/rtems-bsd-rc-conf-net.c
@@ -61,6 +61,7 @@
 #include <machine/rtems-bsd-rc-conf-services.h>
 #include <rtems/rtems-routes.h>
  * Default defaultroute_delay is 30seconds.
@@ -627,45 +628,38 @@ setup_vlans(rtems_bsd_rc_conf*           rc_conf,
  * memory if it exits.
 typedef struct dhcpcd_data {
+  rtems_dhcpcd_config          config;
   rtems_bsd_rc_conf_argc_argv* argc_argv;
   bool                         verbose;
   const char*                  name;
 } dhcpcd_data;
 static void
-dhcpcd_worker(rtems_task_argument arg)
+dhcpcd_prepare(const rtems_dhcpcd_config *config, int argc, char **argv)
-  dhcpcd_data*  dd = (dhcpcd_data*) arg;
-  int           argc;
-  const char**  argv;
-  const char*   dhcpcd_argv[] = { "dhcpcd", NULL };
-  int           r;
-  if (dd->argc_argv->argc > 0) {
-    argc = dd->argc_argv->argc;
-    argv = dd->argc_argv->argv;
-  else {
-    argc = 1;
-    argv = dhcpcd_argv;
+  const dhcpcd_data* dd = (const dhcpcd_data*) config;
   if (dd->verbose) {
+    int r;
     fprintf(stdout, "rc.conf: %s: dhcpcd ", dd->name);
     for (r = 1; r < argc; ++r)
       fprintf(stdout, "%s ", argv[r]);
     fprintf(stdout, "\n");
-  r = rtems_bsd_command_dhcpcd(argc, argv);
-  if (r != EX_OK)
+static void
+dhcpcd_destroy(const rtems_dhcpcd_config *config, int exit_code)
+  dhcpcd_data* dd = (dhcpcd_data*) config;
+  if (exit_code != EX_OK)
     fprintf(stderr, "error: dhcpcd: stopped\n");
   free(dd->name);
   rtems_bsd_rc_conf_argc_argv_destroy(dd->argc_argv);
   free(dd);
-  rtems_task_delete(RTEMS_SELF);
 static int
@@ -673,8 +667,7 @@ run_dhcp(rtems_bsd_rc_conf* rc_conf, rtems_bsd_rc_conf_argc_argv* aa)
   dhcpcd_data*        dd;
-  rtems_id            id;
-  rtems_task_priority priority = RTEMS_MAXIMUM_PRIORITY - 1;
+  rtems_task_priority priority = 0;
   char*               end = NULL;
   int                 r;
@@ -711,21 +704,23 @@ run_dhcp(rtems_bsd_rc_conf* rc_conf, rtems_bsd_rc_conf_argc_argv* aa)
   if (r == 0) {
     if (dd->argc_argv->argc == 2) {
       priority = strtoul(dd->argc_argv->argv[1], &end, 10);
-      if (priority == 0 || *end != '\0')
-        priority = RTEMS_MAXIMUM_PRIORITY - 1;
+      if (*end != '\0')
+        priority = 0;
+  dd->config.priority = priority;
   rtems_bsd_rc_conf_find(rc_conf, "dhcpcd_options", dd->argc_argv);
-  sc = rtems_task_create(rtems_build_name('D', 'H', 'C', 'P'),
-                         priority,
-                         &id);
-  if (sc == RTEMS_SUCCESSFUL)
-    sc = rtems_task_start(id, dhcpcd_worker, (rtems_task_argument) dd);
+  if (dd->argc_argv->argc > 0) {
+    dd->config.argc = dd->argc_argv->argc;
+    dd->config.argv = dd->argc_argv->argv;
+  dd->config.prepare = dhcpcd_prepare;
+  dd->config.destroy = dhcpcd_destroy;
+  sc = rtems_dhcpcd_start(&dd->config);
     fprintf(stderr,
             "error: dhcpcd: thread create/start: %s\n", rtems_status_text(sc));
diff --git a/rtemsbsd/rtems/rtems-bsd-shell-dhcpcd.c b/rtemsbsd/rtems/rtems-bsd-shell-dhcpcd.c
index 248937489..d02e2f44a 100644
--- a/rtemsbsd/rtems/rtems-bsd-shell-dhcpcd.c
+++ b/rtemsbsd/rtems/rtems-bsd-shell-dhcpcd.c
@@ -1,5 +1,5 @@
- * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2013, 2018 embedded brains GmbH.  All rights reserved.
  *  Dornierstr. 4
@@ -30,11 +30,73 @@
 #include <rtems/netcmds-config.h>
+#include <rtems.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+typedef struct {
+	char *argv[RTEMS_ZERO_LENGTH_ARRAY];
+} dhcpcd_command_config;
+static void
+dhcpcd_command_destroy_config(const rtems_dhcpcd_config *config, int exit_code)
+	char **argv;
+	(void)exit_code;
+	while (*argv != NULL) {
+		free(*argv);
+		++argv;
+	free(RTEMS_DECONST(rtems_dhcpcd_config *, config));
+static int
+dhcpcd_command(int argc, char **argv)
+	dhcpcd_command_config *config;
+	int i;
+	config = calloc(1, sizeof(*config) + (argc + 1) * sizeof(char *));
+	if (config == NULL) {
+		fprintf(stdout, "dhcpcd error: not enough memory\n");
+		return 1;
+	for (i = 0; i < argc; ++i) {
+		config->argv[i] = strdup(argv[i]);
+		if (config->argv[i] == NULL) {
+			dhcpcd_command_destroy_config(&config->config, 0);
+			return 1;
+	config->config.argc = argc;
+	config->config.argv = &config->argv[0];
+	config->config.destroy = dhcpcd_command_destroy_config;
+	sc = rtems_dhcpcd_start(&config->config);
+	if (sc != RTEMS_SUCCESSFUL) {
+		fprintf(stdout, "dhcpcd start failed: %s\n", rtems_status_text(sc));
+	return 0;
 rtems_shell_cmd_t rtems_shell_DHCPCD_Command = {
   .name = "dhcpcd",
   .usage = "dhcpcd [args]",
   .topic = "net",
-  .command = rtems_bsd_command_dhcpcd
+  .command = dhcpcd_command
diff --git a/testsuite/include/rtems/bsd/test/default-network-init.h b/testsuite/include/rtems/bsd/test/default-network-init.h
index ee95d26ef..304c7a966 100644
--- a/testsuite/include/rtems/bsd/test/default-network-init.h
+++ b/testsuite/include/rtems/bsd/test/default-network-init.h
@@ -48,6 +48,7 @@
 #include <rtems/stackchk.h>
 #include <rtems/bsd/modules.h>
 #if defined(DEFAULT_NETWORK_DHCPCD_ENABLE) && \
     !defined(DEFAULT_NETWORK_NO_STATIC_IFCONFIG)
@@ -126,22 +127,16 @@ default_network_route_hwif0(char *ifname)
 #endif
-#ifdef DEFAULT_NETWORK_DHCPCD_ENABLE
 static void
-default_network_dhcpcd_task(rtems_task_argument arg)
+default_network_dhcpcd(void)
+#ifdef DEFAULT_NETWORK_DHCPCD_ENABLE
 	static const char default_cfg[] = "clientid libbsd test client\n";
-	int exit_code;
-		"dhcpcd",
-		NULL
 	int fd;
 	int rv;
 	ssize_t n;
-	(void)arg;
 	fd = open("/etc/dhcpcd.conf", O_CREAT | O_WRONLY,
 	assert(fd >= 0);
@@ -159,29 +154,7 @@ default_network_dhcpcd_task(rtems_task_argument arg)
 	rv = close(fd);
 	assert(rv == 0);
-	assert(exit_code == EXIT_SUCCESS);
-#endif
-static void
-default_network_dhcpcd(void)
-	rtems_status_code sc;
-	rtems_id id;
-		&id
-	sc = rtems_task_start(id, default_network_dhcpcd_task, 0);
 #endif
2.12.3
