ftp server upload filer error.
Tue May 8 06:09:17 UTC 2018
Hello James,
sorry for this bug, I fixed it like this:
https://git.rtems.org/rtems/commit/?id=eaa1709894668db739d09a6cea57f98ed4cee38b
On 08/05/18 07:54, jameszxj wrote:
> sorry, this problem is nothing to do with libbsd. The
> rtems/cpukit/ftpd/ftpd.c add a new function yield(),
> this function makes the problem.
> static void
> yield(void)
>  * If we build not for the legacy network stack, then we use the
> libbsd.  In
>  * the libbsd there is no global network stack semaphore which
> provides round
>  * robin fairness for threads of equal priority.
> #ifndef RTEMS_NETWORKING
>   yield();
> #endif
> recursive invocation yield() make the function do not return. I use
> rtems_task_wake_after(0) replace the yield,
> ftp server works correctly.
> ------------------ Original ------------------
> *From: * "jameszxj"<jameszxj at gmail.com>;
> *Date: * Fri, May 4, 2018 12:00 PM
> *To: * "devel"<devel at rtems.org>;
> *Subject: * ftp server upload filer error.
> hi,
>  I update libbsd to the github version, and when i upload a file, the
> upload process failed at the end, and the target shell stuck.
>  I disconnect from the ftp client, shell print the msg
>           debug: _bsd_sonewconn: pcb 0x15df2000: Listen queue
> overflow: 2 already in queue awaiting acceptance (1 occurrences)
>  The target still respond the ping command.
> devel mailing list
> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
