need for bsp_specs on x86_64
Amaan Cheval amaan.cheval at gmail.com
Wed May 9 07:49:33 UTC 2018
Hi!
The WIP bsp_specs I've been using is here:
https://github.com/AmaanC/rtems/blob/ac/stub-x86-link-tests-pre-bspreorg-bak/c/src/lib/libbsp/x86_64/no_bsp/startup/bsp_specs
I think minimizing it and having the linker script take care of things
should be possible - I'll have to look into it as I port my branch to
the new BSPs layout and clean other WIP hacks up. I'm not familiar
enough with linker scripts and the way RTEMS builds yet, so this may
take a few days. I'll keep you guys updated as I make progress!
Thanks for bringing it up!
On Wed, May 9, 2018 at 2:16 AM, Joel Sherrill <joel at rtems.org> wrote:
> Hi
> I have a working branch that I managed to shrink bsp_specs to
> being empty on some targets. It would be nice if we could
> do this from the beginning on x86_64.
> Are the options triggered by -qrtems really needed or implied
> already?
> For the BSPs I worked through, it was easy to move the start
> file specification to the linkcmds and eliminate the specification
> of libraries since they were mostly already correct inside gcc.
> Thanks.
> --joel
