[PATCH 2/2] sparc64 niagara, usiii: Remove -D options from cfg file and move to bspopts.h
Wed May 9 20:23:34 UTC 2018
Updates #3425.
 bsps/sparc64/include/arch/arch.h              |  4 ++++
 bsps/sparc64/include/arch/mm/frame.h          |  4 ++++
 bsps/sparc64/include/arch/mm/mmu.h            |  4 ++++
 bsps/sparc64/include/arch/mm/tlb.h            |  3 +++
 bsps/sparc64/include/arch/mm/tte.h            |  4 ++++
 bsps/sparc64/niagara/config/niagara.cfg       |  2 +-
 bsps/sparc64/usiii/config/usiii.cfg           |  2 +-
 c/src/lib/libbsp/sparc64/niagara/configure.ac |  4 ++++
 c/src/lib/libbsp/sparc64/usiii/configure.ac   | 10 +++++++++-
 9 files changed, 34 insertions(+), 3 deletions(-)
diff --git a/bsps/sparc64/include/arch/arch.h b/bsps/sparc64/include/arch/arch.h
index 5fdd4a2..36aa922 100644
--- a/bsps/sparc64/include/arch/arch.h
+++ b/bsps/sparc64/include/arch/arch.h
@@ -37,10 +37,14 @@
 #ifndef KERN_sparc64_ARCH_H_
 #define KERN_sparc64_ARCH_H_
+#include <bspopts.h>
 #if defined (SUN4U)
 #include <arch/sun4u/arch.h>
 #elif defined (SUN4V)
 #include <arch/sun4v/arch.h>
+#else
+#error "No SUN model defined"
 #endif
 #define ASI_AIUP		0x10	/** Access to primary context with user privileges. */
diff --git a/bsps/sparc64/include/arch/mm/frame.h b/bsps/sparc64/include/arch/mm/frame.h
index fb66e54..2fc17cc 100644
--- a/bsps/sparc64/include/arch/mm/frame.h
+++ b/bsps/sparc64/include/arch/mm/frame.h
@@ -35,10 +35,14 @@
 #ifndef KERN_sparc64_FRAME_H_
 #define KERN_sparc64_FRAME_H_
 #if defined (SUN4U)
 #include <arch/mm/sun4u/frame.h>
 #include <arch/mm/sun4v/frame.h>
+#else
 #endif
 #endif
diff --git a/bsps/sparc64/include/arch/mm/mmu.h b/bsps/sparc64/include/arch/mm/mmu.h
index 1d445f2..aab143f 100644
--- a/bsps/sparc64/include/arch/mm/mmu.h
+++ b/bsps/sparc64/include/arch/mm/mmu.h
@@ -35,10 +35,14 @@
 #ifndef KERN_sparc64_MMU_H_
 #define KERN_sparc64_MMU_H_
 #if defined (SUN4U)
 #include <arch/mm/sun4u/mmu.h>
 #include <arch/mm/sun4v/mmu.h>
+#else
 #endif
diff --git a/bsps/sparc64/include/arch/mm/tlb.h b/bsps/sparc64/include/arch/mm/tlb.h
index 4adf26c..7a6b85d 100644
--- a/bsps/sparc64/include/arch/mm/tlb.h
+++ b/bsps/sparc64/include/arch/mm/tlb.h
@@ -35,11 +35,14 @@
 #ifndef KERN_sparc64_TLB_H_
 #define KERN_sparc64_TLB_H_
 #if defined (SUN4U)
 #include <arch/mm/sun4u/tlb.h>
 #include <arch/mm/sun4v/tlb.h>
+#else
 #endif
 #endif
diff --git a/bsps/sparc64/include/arch/mm/tte.h b/bsps/sparc64/include/arch/mm/tte.h
index f0b746e..10a672b 100644
--- a/bsps/sparc64/include/arch/mm/tte.h
+++ b/bsps/sparc64/include/arch/mm/tte.h
@@ -35,10 +35,14 @@
 #ifndef KERN_sparc64_TTE_H_
 #define KERN_sparc64_TTE_H_
 #if defined (SUN4U)
 #include <arch/mm/sun4u/tte.h>
 #include <arch/mm/sun4v/tte.h>
+#else
 #endif
 #endif
diff --git a/bsps/sparc64/niagara/config/niagara.cfg b/bsps/sparc64/niagara/config/niagara.cfg
index 2fd8973..bfa73aa 100644
--- a/bsps/sparc64/niagara/config/niagara.cfg
+++ b/bsps/sparc64/niagara/config/niagara.cfg
@@ -7,7 +7,7 @@ RTEMS_CPU=sparc64
 #  This contains the compiler options necessary to select the CPU model
 #  and (hopefully) optimize for it.
-CPU_CFLAGS = -mcpu=niagara -DSUN4V
+CPU_CFLAGS = -mcpu=niagara
 # optimize flag: typically -g -O2
 CFLAGS_OPTIMIZE_V = -g -O2
diff --git a/bsps/sparc64/usiii/config/usiii.cfg b/bsps/sparc64/usiii/config/usiii.cfg
index b9fad21..ee1c508 100644
--- a/bsps/sparc64/usiii/config/usiii.cfg
+++ b/bsps/sparc64/usiii/config/usiii.cfg
-CPU_CFLAGS = -mcpu=ultrasparc3 -DUS3 -DSUN4U
+CPU_CFLAGS = -mcpu=ultrasparc3
diff --git a/c/src/lib/libbsp/sparc64/niagara/configure.ac b/c/src/lib/libbsp/sparc64/niagara/configure.ac
index ced7e12..f8e9687 100644
--- a/c/src/lib/libbsp/sparc64/niagara/configure.ac
+++ b/c/src/lib/libbsp/sparc64/niagara/configure.ac
@@ -10,6 +10,10 @@ RTEMS_CANONICAL_TARGET_CPU
 AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
 RTEMS_BSP_CONFIGURE
+RTEMS_BSPOPTS_SET([SUN4V],[niagara],[1])
+RTEMS_BSPOPTS_SET([SUN4V],[*],[])
+RTEMS_BSPOPTS_HELP([SUN4V],
+[If defined, enable SUN model optons for the Niagara model.])
 RTEMS_BSP_CLEANUP_OPTIONS
diff --git a/c/src/lib/libbsp/sparc64/usiii/configure.ac b/c/src/lib/libbsp/sparc64/usiii/configure.ac
index 4244055..c99d938 100644
--- a/c/src/lib/libbsp/sparc64/usiii/configure.ac
+++ b/c/src/lib/libbsp/sparc64/usiii/configure.ac
@@ -10,13 +10,21 @@ RTEMS_CANONICAL_TARGET_CPU
 RTEMS_BSP_CONFIGURE
 RTEMS_BSPOPTS_SET([SIMSPARC_FAST_IDLE],[*],[])
 RTEMS_BSPOPTS_HELP([SIMSPARC_FAST_IDLE],
 [If defined, speed up the clock ticks while the idle task is running so
 time spent in the idle task is minimized.  This significantly reduces
 the wall time required to execute the RTEMS test suites.])
+RTEMS_BSPOPTS_SET([US3],[usiii],[1])
+RTEMS_BSPOPTS_SET([US3],[*],[])
+RTEMS_BSPOPTS_HELP([US3],
+[If defined, enable UltraSPARC optons for the USIII BSP.])
+RTEMS_BSPOPTS_SET([SUN4U],[usiii],[1])
+RTEMS_BSPOPTS_SET([SUN4U],[*],[])
+RTEMS_BSPOPTS_HELP([SUN4U],
+[If defined, enable SUN model optons for the USIII BSP.])
1.8.3.1
