V2 Add DWARF support to the rtemstoolkit and put it to use.
Thu May 10 07:30:32 UTC 2018
On 10/5/18 6:14 pm, Cillian O'Donnell wrote:
> On Thu, 10 May 2018, 03:43 Chris Johns, <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 10/5/18 8:47 am, Cillian O'Donnell wrote:
>     > Just running covoar there, we seem to be running into some problems at the
>     > source line lookup stage
>     Thank you for testing this. I assume it builds OK and we can run it?
> Builds with a couple of warnings, other than that it's fine. Hopefully no issues
> on freebsd.
Great, that is a one step. Could you please post the warnings?
Thanks
