V2 Add DWARF support to the rtemstoolkit and put it to use.
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Thu May 10 21:23:39 UTC 2018
On Fri, 11 May 2018, 02:19 Cillian O'Donnell, <cpodonnell8 at gmail.com> wrote:
> On 10 May 2018 at 20:15, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> Frankly, I'm totally confused at the moment. I'm not able to come up with
>> a proper task list to serially go through.
>> according to my understanding (and proposal), the major goals are:
>> 1. Get the coverage analysis running again and get it merged with the
>> current master repo.
> Yep, this is definitely the most immediate goal.
>> 2. Generating line coverage reports using the gcov/lcov .
>> 3. get covoar generate reports on a data-centric format (as Joel
>> suggested in the proposal earlier, this needs a discussion on the choice of
>> format. Chris probably has some thoughts about it.)
>> looking at the above and the current status I need to break down it into
>> subtasks. Here are some of the questions that'll help me understand
>> properly.
>> 1. before the current updates to covoar, the coverage analysis was
>> generating the html and txt reports (which I posted) in the previous set
>> up. Is that what we're targeting to achive with the current setup?
> Exactly we need to see it doing what it was before and then this will be a
> good jumping off point for the other goals.
got it , It's Clear now.
>> 2. The covoar is under update as Chris is working on it, there are still
>> some issues there, updating the main() module is, I guess, one of them.
>> This needs to be done as the first step before the tester can generate
>> reports.
> What Chris is doing now, we can keep an eye on what's happening and help
> with testing but we won't need to wait for it to move forward. So getting
> the tester to run covoar is separate and we can crack on with that.
Understood.
have you set any 'plan' for how to approach this ?
>> On 10 May 2018 at 23:40, Joel Sherrill <joel at rtems.org> wrote:
>>> On Thu, May 10, 2018 at 12:37 PM, Cillian O'Donnell <
>>>> Ahhh I see, more c++ conversion for the rest of covoar, or at least the
>>>> parts called in main. That's something Vijay could do, the blueprint for
>>>> the conversion is in one of Chris last patches updating covoar.cc Any
>>>> objections to him doing it Joel, Chris?
>>> None from me. This particular issue would be higher than many of the
>>> other things Chris wants changed since it manifests as a bad exit().
>> I can surely try looking into it (any instructions ?). Also, Isn't Chris
>> already on it ?
>>> But overall Vijay needs to get output from covar with covoar running
>>> cleanly (no faults) so he can focus on gcov output and reporting
>>> improvements.
>>> NOTE: I am still open to the idea that gcov, lcov, etc. may be able to
>>> produce reports that we are completely happy with. They need to
>>> at least be a working alternate. lcov output looks promising from
>>> the samples I have seen:
>>> http://ltp.sourceforge.net/coverage/lcov/output/index.html
>> the report looks good
>>> https://swarminglogic.com/jotting/2014_05_lcov has more complicated
>>> reports
>>> and instructions. It even includes a shell script to make Chris happy.
>>> LOL
>> thanks for the link, the inscructions are really helpful to get started.
>>> Vijay.. my thought is that you need to get gcov files output from covoar.
>>> Then automating running gcov or lcov (lcov looks nicer I think). That
>>> should
>>> be a nice place to be completely committed. Hopefully at this point, you
>>> will be analyzing all of cpukit/ and we can find some discrepancies
>>> between
>>> covoar reports and lcov/gcov output. Then fix those. That's just my
>>> thoughts
>>> though.
>> +So after the covoar runs with no issues and the coverage report shows
>> some data, the next work is to generate gcov output .
>> + Then automating running lcov .
>>>>> I also need to figure out why the address has lost it's reference to
>>>>> the source
>>>>> table.
>>>>> Chris
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> devel mailing list
>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180510/b8d46cba/attachment-0001.html>
