V2 Add DWARF support to the rtemstoolkit and put it to use.
Fri May 11 04:44:44 UTC 2018
On 11/5/18 8:32 am, Cillian O'Donnell wrote:
>     Thank for you the offer. The change to main is in response to my changes to add
>     DWARF support and those changes are not yet working so I feel I have to make the
>     change as part of this work or Vijay ends up on my broken version of rtems-tools
>     and that is not productive.
>     I also think the other listed work is better value for us and more fun for
>     Vijay. :)
> Fair enough :) I thought you might want to lighten your load. You're doing all
> the heavy lifting.
Thanks, I am fine. I have pushed a patch to my repo that removes all exit()
calls from covoar.
I am looking into the reason for the error which is proving difficult to find.
