How to download the required tar file?
Fri May 11 05:07:27 UTC 2018
On 11/5/18 4:01 pm, Danxue Huang wrote:
> Hi there,
> I got stuck on 2.5 installing a tar file ( I have attached the website below).
You can skip that section. It does not really belong in the Quick Start chapter.
> https://docs.rtems.org/branches/master/rsb/quick-start.html#building
> <https://docs.rtems.org/branches/master/rsb/quick-start.html#building>
> The tar file is supposed that I have downloaded in my machine, but there is not
> a required .bz2 file "rtems-4.11-sparc-rtems4.11-1.tar.bz2", all my files ends
> at .bz2 are as below.
> ./development/rtems/src/rtems-source-builder/rtems/sources/gmp-5.0.5.tar.bz2
> ./development/rtems/src/rtems-source-builder/rtems/sources/binutils-2.26.tar.bz2
> ./development/rtems/src/rtems-source-builder/rtems/sources/rtems-tools-25863503edb513e7501481ff2074c02bf219f519.tar.bz2
> ./development/rtems/src/rtems-source-builder/rtems/sources/binutils-2.30.tar.bz2
> ./development/rtems/src/rtems-source-builder/rtems/sources/gmp-6.1.0.tar.bz2
> ./development/rtems/src/rtems-source-builder/rtems/sources/gcc-4.9.3.tar.bz2
> ./development/rtems/src/rtems-source-builder/rtems/sources/mpfr-3.0.1.tar.bz2
> ./development/rtems/src/rtems-source-builder/rtems/sources/mpfr-3.1.4.tar.bz2
> Is there any other way I can download the required tar file? Thank you!
You should not needed it.
Have you managed to build the tools?
