How to download the required tar file?
Danxue Huang
danxue.huang at gmail.com
Fri May 11 18:29:52 UTC 2018
Hey Vijay,
Thank you so much for answering my question! Please don't feel sorry about
that, it's great that I also got you to help me so I can figure out my
problem faster :D
I double checked the files in my machine, there are no such files like
"kernel", "erc32" and "testsuites", do you know why do I miss these files?
Or how can I get these files? Thank you!
Best,
Dannie
On Fri, May 11, 2018 at 12:57 PM, Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> Hello Dannie,
> I guess you're looking for the testsuites direcotry under the build
> directory.
> It can be found somewhere like this
> $HOME/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/testsuites
> If you're looking for the c code then you can find it under the RTEMS_ROOT
> directory.
> In my set up the root directory is here:
> $HOME/development/rtems/kernel/rtems/testsuites
> You can refer to this link to understand the directory structure properly .
> https://docs.rtems.org/branches/master/develenv/directory.html
> Hopefully it was helpful.
> regards,
> Vijay
> PS: Apologies to Chris, if it was disrespectful to respond to a question
> that was addressed to him. I certainly didn't mean any disrespect.
> On 11 May 2018 at 22:33, Danxue Huang <danxue.huang at gmail.com> wrote:
>> Chris,
>> I have managed to build the tools, but I got another question about
>> testing. I am supposed to have a "testsuites" folder in my machine from the
>> instruction but I did not find it. So I make a "test.exe" file by myself,
>> the output of running "test.exe" is as below.
>> dannie at dannie-VirtualBox:~/development/rtems/4.11/sparc-rtems4.11$
>> sparc-rtems4.11-gdb test.exe
>> GNU gdb (GDB) 7.9
>> Copyright (C) 2015 Free Software Foundation, Inc.
>> License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.h
>> tml>
>> This is free software: you are free to change and redistribute it.
>> There is NO WARRANTY, to the extent permitted by law. Type "show copying"
>> and "show warranty" for details.
>> This GDB was configured as "--host=x86_64-linux-gnu
>> --target=sparc-rtems4.11".
>> Type "show configuration" for configuration details.
>> For bug reporting instructions, please see:
>> <http://www.gnu.org/software/gdb/bugs/>.
>> Find the GDB manual and other documentation resources online at:
>> <http://www.gnu.org/software/gdb/documentation/>.
>> For help, type "help".
>> Type "apropos word" to search for commands related to "word"...
>> "/home/dannie/development/rtems/4.11/sparc-rtems4.11/test.exe": not in
>> executable format: File format not recognized
>> (gdb) tar sim
>> Connected to the simulator.
>> (gdb) load
>> No executable file specified.
>> Use the "file" or "exec-file" command.
>> (gdb) r
>> Starting program:
>> warning: No executable file specified.
>> warning: No program loaded.
>> [Inferior 1 (process 42000) exited normally]
>> (gdb) quit
>> Now I think the gdb session is working, but the "test.exe" is not
>> executable since it is coded by myself (there are bugs in it). Is there any
>> way I can get the testing files?
>> Thank you so much!
>> -Dannie
>> On Fri, May 11, 2018 at 12:07 AM, Chris Johns <chrisj at rtems.org> wrote:
>>> On 11/5/18 4:01 pm, Danxue Huang wrote:
>>> > Hi there,
>>> > I got stuck on 2.5 installing a tar file ( I have attached the website
>>> below).
>>> You can skip that section. It does not really belong in the Quick Start
>>> chapter.
>>> > https://docs.rtems.org/branches/master/rsb/quick-start.html#building
>>> > <https://docs.rtems.org/branches/master/rsb/quick-start.html#building>
>>> > The tar file is supposed that I have downloaded in my machine, but
>>> there is not
>>> > a required .bz2 file "rtems-4.11-sparc-rtems4.11-1.tar.bz2", all my
>>> files ends
>>> > at .bz2 are as below.
>>> > ./development/rtems/src/rtems-source-builder/rtems/sources/g
>>> mp-5.0.5.tar.bz2
>>> > ./development/rtems/src/rtems-source-builder/rtems/sources/b
>>> inutils-2.26.tar.bz2
>>> > ./development/rtems/src/rtems-source-builder/rtems/sources/r
>>> tems-tools-25863503edb513e7501481ff2074c02bf219f519.tar.bz2
>>> inutils-2.30.tar.bz2
>>> mp-6.1.0.tar.bz2
>>> cc-4.9.3.tar.bz2
>>> > ./development/rtems/src/rtems-source-builder/rtems/sources/m
>>> pfr-3.0.1.tar.bz2
>>> pfr-3.1.4.tar.bz2
>>> > Is there any other way I can download the required tar file? Thank you!
>>> You should not needed it.
>>> Have you managed to build the tools?
>>> Chris
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180511/a7f716bd/attachment.html>
