How to download the required tar file?
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri May 11 19:02:37 UTC 2018
On 12 May 2018 at 00:13, Danxue Huang <danxue.huang at gmail.com> wrote:
> Yes! I am trying to run hello world at Ubuntu in a VM.
> This link will help you set up things properly .
https://ftp.rtems.org/pub/rtems/people/chrisj/doc-online/4.11/user/start/index.html
> On Fri, May 11, 2018 at 1:37 PM, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> On Fri, 11 May 2018, 23:59 Danxue Huang, <danxue.huang at gmail.com> wrote:
>>> Hey Vijay,
>>> Thank you so much for answering my question! Please don't feel sorry
>>> about that, it's great that I also got you to help me so I can figure out
>>> my problem faster :D
>>> I double checked the files in my machine, there are no such files like
>>> "kernel", "erc32" and "testsuites", do you know why do I miss these files?
>>> Or how can I get these files? Thank you!
>> maybe I didn't understand the current status of set up.
>> are you trying to run hello world ?
>>> Best,
>>> Dannie
>>> On Fri, May 11, 2018 at 12:57 PM, Vijay Kumar Banerjee <
>>>> Hello Dannie,
>>>> I guess you're looking for the testsuites direcotry under the build
>>>> directory.
>>>> It can be found somewhere like this
>>>> $HOME/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/testsuites
>>>> If you're looking for the c code then you can find it under the
>>>> RTEMS_ROOT directory.
>>>> In my set up the root directory is here:
>>>> $HOME/development/rtems/kernel/rtems/testsuites
>>>> You can refer to this link to understand the directory structure
>>>> properly .
>>>> https://docs.rtems.org/branches/master/develenv/directory.html
>>>> Hopefully it was helpful.
>>>> regards,
>>>> Vijay
>>>> PS: Apologies to Chris, if it was disrespectful to respond to a
>>>> question that was addressed to him. I certainly didn't mean any
>>>> disrespect.
>>>> On 11 May 2018 at 22:33, Danxue Huang <danxue.huang at gmail.com> wrote:
>>>>> Chris,
>>>>> I have managed to build the tools, but I got another question about
>>>>> testing. I am supposed to have a "testsuites" folder in my machine from the
>>>>> instruction but I did not find it. So I make a "test.exe" file by myself,
>>>>> the output of running "test.exe" is as below.
>>>>> dannie at dannie-VirtualBox:~/development/rtems/4.11/sparc-rtems4.11$
>>>>> sparc-rtems4.11-gdb test.exe
>>>>> GNU gdb (GDB) 7.9
>>>>> Copyright (C) 2015 Free Software Foundation, Inc.
>>>>> License GPLv3+: GNU GPL version 3 or later <
>>>>> http://gnu.org/licenses/gpl.html>
>>>>> This is free software: you are free to change and redistribute it.
>>>>> There is NO WARRANTY, to the extent permitted by law. Type "show
>>>>> copying"
>>>>> and "show warranty" for details.
>>>>> This GDB was configured as "--host=x86_64-linux-gnu
>>>>> --target=sparc-rtems4.11".
>>>>> Type "show configuration" for configuration details.
>>>>> For bug reporting instructions, please see:
>>>>> <http://www.gnu.org/software/gdb/bugs/>.
>>>>> Find the GDB manual and other documentation resources online at:
>>>>> <http://www.gnu.org/software/gdb/documentation/>.
>>>>> For help, type "help".
>>>>> Type "apropos word" to search for commands related to "word"...
>>>>> "/home/dannie/development/rtems/4.11/sparc-rtems4.11/test.exe": not
>>>>> in executable format: File format not recognized
>>>>> (gdb) tar sim
>>>>> Connected to the simulator.
>>>>> (gdb) load
>>>>> No executable file specified.
>>>>> Use the "file" or "exec-file" command.
>>>>> (gdb) r
>>>>> Starting program:
>>>>> warning: No executable file specified.
>>>>> warning: No program loaded.
>>>>> [Inferior 1 (process 42000) exited normally]
>>>>> (gdb) quit
>>>>> Now I think the gdb session is working, but the "test.exe" is not
>>>>> executable since it is coded by myself (there are bugs in it). Is there any
>>>>> way I can get the testing files?
>>>>> Thank you so much!
>>>>> -Dannie
>>>>> On Fri, May 11, 2018 at 12:07 AM, Chris Johns <chrisj at rtems.org>
>>>>> wrote:
>>>>>> On 11/5/18 4:01 pm, Danxue Huang wrote:
>>>>>> > Hi there,
>>>>>> > I got stuck on 2.5 installing a tar file ( I have attached the
>>>>>> website below).
>>>>>> You can skip that section. It does not really belong in the Quick
>>>>>> Start chapter.
>>>>>> > https://docs.rtems.org/branches/master/rsb/quick-start.html#
>>>>>> building
>>>>>> > <https://docs.rtems.org/branches/master/rsb/quick-start.
>>>>>> html#building>
>>>>>> > The tar file is supposed that I have downloaded in my machine, but
>>>>>> there is not
>>>>>> > a required .bz2 file "rtems-4.11-sparc-rtems4.11-1.tar.bz2", all
>>>>>> my files ends
>>>>>> > at .bz2 are as below.
>>>>>> > ./development/rtems/src/rtems-source-builder/rtems/sources/g
>>>>>> mp-5.0.5.tar.bz2
>>>>>> > ./development/rtems/src/rtems-source-builder/rtems/sources/b
>>>>>> inutils-2.26.tar.bz2
>>>>>> > ./development/rtems/src/rtems-source-builder/rtems/sources/r
>>>>>> tems-tools-25863503edb513e7501481ff2074c02bf219f519.tar.bz2
>>>>>> inutils-2.30.tar.bz2
>>>>>> mp-6.1.0.tar.bz2
>>>>>> cc-4.9.3.tar.bz2
>>>>>> > ./development/rtems/src/rtems-source-builder/rtems/sources/m
>>>>>> pfr-3.0.1.tar.bz2
>>>>>> pfr-3.1.4.tar.bz2
>>>>>> > Is there any other way I can download the required tar file? Thank
>>>>>> you!
>>>>>> You should not needed it.
>>>>>> Have you managed to build the tools?
>>>>>> Chris
>>>>> _______________________________________________
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180512/37fd0b39/attachment-0001.html>
