V2 Add DWARF support to the rtemstoolkit and put it to use.
Sun May 13 04:36:22 UTC 2018
On 13/5/18 7:14 am, Vijay Kumar Banerjee wrote:
> On 11 May 2018 at 11:50, Cillian O'Donnell <cpodonnell8 at gmail.com
> <mailto:cpodonnell8 at gmail.com>> wrote:
>     At the moment when the tester runs covoar the error messages generated are a
>     clear indicator of what is wrong, so task list is dictated by what they're
>     saying at the moment. Fixing the mismatch between exe.cov and .cov is the
>     next thing. The name is given as an argument to the -exec option of the qemu
>     cmd and is picked up from leon3-qemu-cov. Have a look at that and see can
>     you fix it.
> The attached diff fixes the mismatch.
> shall we start a new thread for tester support ?
I did this in the restructure. I planned to fix the extension code so it was
consistent for the executable and coverage files.
Why not change the replace moving it past the '.' in the file name rather than
adding a '.' to the extension?
