[PATCH] covoar: fixing the extension mismatch in trace file
Sun May 13 04:38:50 UTC 2018
Sorry for the post in the other thread. I did not see this one.
On 13/5/18 9:28 am, Joel Sherrill wrote:
> On Sat, May 12, 2018 at 2:42 PM, thelunatic <vijaykumar9597 at gmail.com
> <mailto:vijaykumar9597 at gmail.com>> wrote:
> Every patch needs an explanation/log message.  Look back through
> "git log" for examples.
>      tester/covoar/covoar.cc | 7 ++++---
>      1 file changed, 4 insertions(+), 3 deletions(-)
>     diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
>     index 5bed98f..95dc990 100644
>     --- a/tester/covoar/covoar.cc
>     +++ b/tester/covoar/covoar.cc
>     @@ -185,7 +185,7 @@ int main(
>        Executables                   executablesToAnalyze;
>        Coverage::ExecutableInfo*     executableInfo = NULL;
>        std::string                   executableExtension = "exe";
>     -  std::string                   coverageExtension = "cov";
>     +  std::string                   coverageExtension = ".cov";
> Why did this need a "." but the "exe" one didn't?
Yes I was wondering this and why I made the change to the coverage extension.
>        Coverage::CoverageFormats_t   coverageFormat =
>     Coverage::COVERAGE_FORMAT_QEMU;
>        Coverage::CoverageReaderBase* coverageReader = NULL;
>        char*                         executable = NULL;
>     @@ -317,11 +317,12 @@ int main(
>              std::cerr << "warning: Unable to read executable: " << argv[i] <<
>     std::endl;
>            } else {
>              coverageFileName = argv[i];
>     -        coverageFileName.replace(
>     +       coverageFileName.append(coverageExtension);
>     +     /* coverageFileName.replace(
>                coverageFileName.length() - executableExtension.size(),
>                coverageExtension
> If you are replacing this call, then just delete it -- don't comment it out.
I suggest the replace be changed to move past the '.' in the file name.
I suspect the code here is still fragile because the extensions need to be the
same size.
>              if (!FileIsReadable( coverageFileName.c_str() )) {
>                std::cerr << "warning: Unable to read coverage file: " <<
>     coverageFileName
>     2.14.3
