[PATCH] covoar: fixing the extension mismatch in trace file
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun May 13 04:44:41 UTC 2018
On Sun, 13 May 2018, 10:09 Chris Johns, <chrisj at rtems.org> wrote:
> Sorry for the post in the other thread. I did not see this one.
> On 13/5/18 9:28 am, Joel Sherrill wrote:
> > On Sat, May 12, 2018 at 2:42 PM, thelunatic <vijaykumar9597 at gmail.com
> > <mailto:vijaykumar9597 at gmail.com>> wrote:
> > Every patch needs an explanation/log message. Look back through
> > "git log" for examples.
> > tester/covoar/covoar.cc | 7 ++++---
> > 1 file changed, 4 insertions(+), 3 deletions(-)
> > diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
> > index 5bed98f..95dc990 100644
> > --- a/tester/covoar/covoar.cc
> > +++ b/tester/covoar/covoar.cc
> > @@ -185,7 +185,7 @@ int main(
> > Executables executablesToAnalyze;
> > Coverage::ExecutableInfo* executableInfo = NULL;
> > std::string executableExtension = "exe";
> > - std::string coverageExtension = "cov";
> > + std::string coverageExtension = ".cov";
> > Why did this need a "." but the "exe" one didn't?
> Yes I was wondering this and why I made the change to the coverage
> extension.
> > Coverage::CoverageFormats_t coverageFormat =
> > Coverage::COVERAGE_FORMAT_QEMU;
> > Coverage::CoverageReaderBase* coverageReader = NULL;
> > char* executable = NULL;
> > @@ -317,11 +317,12 @@ int main(
> > std::cerr << "warning: Unable to read executable: " <<
> argv[i] <<
> > std::endl;
> > } else {
> > coverageFileName = argv[i];
> > - coverageFileName.replace(
> > + coverageFileName.append(coverageExtension);
> > + /* coverageFileName.replace(
> > coverageFileName.length() - executableExtension.size(),
> > coverageExtension
> > If you are replacing this call, then just delete it -- don't comment it
> out.
> I suggest the replace be changed to move past the '.' in the file name.
> I suspect the code here is still fragile because the extensions need to be
> the
> same size.
can't this be done by adding '.' in the append as in the v2 of this patch
to keep the extension size same ?
are you suggesting to use replace instead ?
> Chris
> > if (!FileIsReadable( coverageFileName.c_str() )) {
> > std::cerr << "warning: Unable to read coverage file: " <<
> > coverageFileName
> > 2.14.3
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180513/f71d80d6/attachment-0001.html>
