[PATCH] covoar: fixing the extension mismatch in trace file
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun May 13 10:46:23 UTC 2018
On Sun, 13 May 2018, 16:15 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> On Sun, 13 May 2018, 16:09 Cillian O'Donnell, <cpodonnell8 at gmail.com>
> wrote:
>> It does seem to be having some knock on effect. Covoar made it past these
>> checks before.
>> Total: 13
>> Average test time: 0:00:03.178923
>> Testing time : 0:00:41.326000
>> Running covoar for score
>> covoar results directory:
>> /home/cpod/development/rtems/leon3/coverage/score
>> ERROR: executable build prefix does not match: sparc-rtems5
>> ***Cleaning tempfiles***
>> error: covoar failure exit code: 1
>> Not sure how thats related.
>> Its checking
>> if (buildPrefix.empty()) {
>> 76 buildPrefix =
>> *pri;
>> 77 } else
>> 78 if (buildPrefix != *pri)
>> 79 std::cout << "buildBSP: " + buildBSP << "\n*pri: " + *pri
>> << std::en
>> dl;
>> 80 fail = "executable build prefix does not match: " +
>> buildPrefix;
>> 81
>> break;
>> 82
>> 83 }
>> I added those checks, Its stepping back through the path and checking if
>> each directory makes sense. It seems to be out of line now
>> buildBSP: leon3
>> *pri: sparc-rtems5
> initially there were two problems
> +exe.cov and .cov mismatch
> +access library from outside the leon3 directory.
> The patch solves the first one, that's one step .
> The next step can be solved by adding the path to the build-target , i.e.
> sparc-rtems5 , from HOME directory, you can manually add it and see it
> running for now. That tells us that inclusion of the path in more standard
> way will solve it.
in score-symbol.ini file
>> Maybe its splitting the path on '.' and '/' Haven't checked it yet.
>> On 13 May 2018 at 07:05, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>> wrote:
>>> On 13 May 2018 at 10:50, Chris Johns <chrisj at rtems.org> wrote:
>>>> On 13/5/18 4:44 pm, Vijay Kumar Banerjee wrote:
>>>> > On Sun, 13 May 2018, 10:09 Chris Johns, <chrisj at rtems.org
>>>> > <mailto:chrisj at rtems.org>> wrote:
>>>> > > Coverage::CoverageFormats_t coverageFormat =
>>>> > > Coverage::COVERAGE_FORMAT_QEMU;
>>>> > > Coverage::CoverageReaderBase* coverageReader = NULL;
>>>> > > char* executable = NULL;
>>>> > > @@ -317,11 +317,12 @@ int main(
>>>> > > std::cerr << "warning: Unable to read executable:
>>>> " << argv[i] <<
>>>> > > std::endl;
>>>> > > } else {
>>>> > > coverageFileName = argv[i];
>>>> > > - coverageFileName.replace(
>>>> > > + coverageFileName.append(coverageExtension);
>>>> > > + /* coverageFileName.replace(
>>>> > > coverageFileName.length() -
>>>> executableExtension.size(),
>>>> > > coverageExtension
>>>> > > If you are replacing this call, then just delete it -- don't
>>>> comment it out.
>>>> > I suggest the replace be changed to move past the '.' in the file
>>>> name.
>>>> > I suspect the code here is still fragile because the extensions
>>>> need to be the
>>>> > same size.
>>>> > can't this be done by adding '.' in the append as in the v2 of this
>>>> patch to
>>>> > keep the extension size same ?
>>>> It fixes something but what is broken that is being fixed?
>>>> the trace files have .exe.cov extensions but the covoar was searching
>>> for .cov extension causing it to return error for not finding the trace
>>> file. Adding the .cov to the coverageFileName to make it .exe.cov seemed
>>> like a quick fix to this .
>>> Do we need the .exe extension there ?
>>> > are you suggesting to use replace instead ?
>>>> I think it would be better to fix the bug than work around it.
>>>> The replace is saying replace from length of the extension back from
>>>> the end of
>>>> the string for the size of the extension with the extension. In other
>>>> words it
>>>> should back up from the end the extension length and replace it. Which
>>>> length or
>>>> size is wrong.
>>>> No matter what the current code is fragile because it assumes a few
>>>> things. The
>>>> most robust approach would add code to the rtemstoolkit's rld::path
>>>> namespace to
>>>> return a path with the extension stripped. For example add
>>>> 'rld::path::strip_extension ()' and then use that to strip
>>>> coverageFileName and
>>>> then add the extension.
>>>> I would also review the 'exe' extension usage to make sure it is OK. I
>>>> have not
>>>> done this.
>>>> Are you interested in doing this?
>>> I can look into this. Any instructions ?
>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180513/e9ee9a7a/attachment-0001.html>
