[PATCH] covoar.cc: Correct build path checks for multiple executables.
Cillian O'Donnell
cpodonnell8 at gmail.com
Sun May 13 20:45:54 UTC 2018
tester/covoar/covoar.cc | 10 +++-------
1 file changed, 3 insertions(+), 7 deletions(-)
diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
index 5c87402..c6b0589 100644
--- a/tester/covoar/covoar.cc
+++ b/tester/covoar/covoar.cc
@@ -75,7 +75,7 @@ static void createBuildPath(Executables& executablesToAnalyze,
if (buildPrefix.empty()) {
buildPrefix = *pri;
} else {
- if (buildBSP != *pri) {
+ if (buildPrefix != *pri) {
fail = "executable build prefix does not match: " + buildPrefix;
break;
@@ -97,7 +97,7 @@ static void createBuildPath(Executables& executablesToAnalyze,
if (buildPath.empty()) {
buildPath = thisBuildPath;
} else {
+ if (buildPath != thisBuildPath) {
fail = "executable build path does not match: " + buildPath;
@@ -316,11 +316,7 @@ int main(
std::cerr << "warning: Unable to read executable: " << argv[i] << std::endl;
} else {
coverageFileName = argv[i];
- coverageFileName.replace(
- coverageFileName.length() - executableExtension.size(),
- coverageExtension
+ coverageFileName.append( "." + coverageExtension );
if (!FileIsReadable( coverageFileName.c_str() )) {
std::cerr << "warning: Unable to read coverage file: " << coverageFileName
2.7.4
