[PATCH] covoar.cc: Correct build path checks for multiple executables.
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Mon May 14 08:50:20 UTC 2018
On 14 May 2018 at 12:10, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> On Sun, 13 May 2018, 22:15 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> On 14 May 2018 at 02:15, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>>> tester/covoar/covoar.cc | 10 +++-------
>>> 1 file changed, 3 insertions(+), 7 deletions(-)
>>> diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
>>> index 5c87402..c6b0589 100644
>>> --- a/tester/covoar/covoar.cc
>>> +++ b/tester/covoar/covoar.cc
>>> @@ -75,7 +75,7 @@ static void createBuildPath(Executables&
>>> executablesToAnalyze,
>>> if (buildPrefix.empty()) {
>>> buildPrefix = *pri;
>>> } else {
>>> - if (buildBSP != *pri) {
>>> + if (buildPrefix != *pri) {
>>> fail = "executable build prefix does not match: " +
>>> buildPrefix;
>>> break;
>>> @@ -97,7 +97,7 @@ static void createBuildPath(Executables&
>>> if (buildPath.empty()) {
>>> buildPath = thisBuildPath;
>>> } else {
>>> + if (buildPath != thisBuildPath) {
>>> fail = "executable build path does not match: " + buildPath;
>>> @@ -316,11 +316,7 @@ int main(
>>> std::cerr << "warning: Unable to read executable: " << argv[i]
>>> << std::endl;
>>> } else {
>>> coverageFileName = argv[i];
>>> - coverageFileName.replace(
>>> - coverageFileName.length() - executableExtension.size(),
>>> - coverageExtension
>>> + coverageFileName.append( "." + coverageExtension );
>>> if (!FileIsReadable( coverageFileName.c_str() )) {
>>> std::cerr << "warning: Unable to read coverage file: " <<
>>> coverageFileName
>>> 2.7.4
>>> This worked !
> Cool, looks like we're onto fixing the reports then. If you take a look at
> report.html only the headings are there. I think what might be wrong there
> is it's just searching in the wrong place for the results. The fix for that
> will lie in coverage.py. Warning about coverage.py, there could be whole
> sections in there that might just be deleted, it's still being reorganized.
> Are you working on it ?
Also the absolute path needs to be parsed form the score-symbol.ini for
running it from out of the build tree
> Or seeing as covoar is in good shape now and I think the txt report is ok
> (you should check and make sure of that). You could move onto gcov, lcov
> stuff. Figure out the state of the gcov support in covoar, generate gcov
> reports, compare the results.
I'll creat a new thread for gcov report then.
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180514/8beae503/attachment.html>
