[PATCH 3/3] libtests/block05: Use rtems_blkdev_create()
Mon May 14 13:54:28 UTC 2018
Update #3358.
 testsuites/libtests/block05/init.c | 47 ++++++++++++++++++++------------------
 1 file changed, 25 insertions(+), 22 deletions(-)
diff --git a/testsuites/libtests/block05/init.c b/testsuites/libtests/block05/init.c
index c20ccbf20d..79616276de 100644
--- a/testsuites/libtests/block05/init.c
+++ b/testsuites/libtests/block05/init.c
@@ -7,10 +7,10 @@
- * Copyright (c) 2009-2012 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2009, 2018 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
- *  Obere Lagerstr. 30
+ *  Dornierstr. 4
  *  82178 Puchheim
  *  Germany
  *  <rtems at embedded-brains.de>
@@ -24,14 +24,17 @@
 #include "config.h"
 #endif
-#include "tmacros.h"
-#include <stdarg.h>
+#include <sys/stat.h>
+#include <fcntl.h>
+#include <stdarg.h>
 #include <rtems/bspIo.h>
 #include <rtems/bdbuf.h>
-#include <rtems/diskdevs.h>
+#include <rtems/blkdev.h>
+#include <tmacros.h>
 const char rtems_test_name[] = "BLOCK 5";
@@ -394,32 +397,33 @@ static int disk_ioctl(rtems_disk_device *dd, uint32_t req, void *argp)
 static void disk_register(
+  const char *dev,
   uint32_t block_size,
   rtems_blkdev_bnum block_count,
   rtems_disk_device **dd_ptr
-  rtems_status_code sc = RTEMS_SUCCESSFUL;
-  rtems_device_major_number major = 0;
-  dev_t dev = 0;
-  sc = rtems_io_register_driver(0, &disk_ops, &major);
-  ASSERT_SC(sc);
+  rtems_status_code sc;
+  int rv;
+  int fd;
-  dev = rtems_filesystem_make_dev_t(major, 0);
-  sc = rtems_disk_create_phys(
+  sc = rtems_blkdev_create(
     dev,
     block_size,
     block_count,
     disk_ioctl,
-    NULL,
     NULL
   ASSERT_SC(sc);
-  *dd_ptr = rtems_disk_obtain(dev);
-  rtems_test_assert(*dd_ptr!= NULL);
+  fd = open(dev, O_RDWR);
+  rtems_test_assert(rv >= 0);
+  rv = rtems_disk_fd_get_disk_device(fd, dd_ptr);
+  rtems_test_assert(rv == 0);
+  rv = close(fd);
 static rtems_task Init(rtems_task_argument argument)
@@ -431,12 +435,9 @@ static rtems_task Init(rtems_task_argument argument)
   task_id_init = rtems_task_self();
-  sc = rtems_disk_io_initialize();
-  ASSERT_SC(sc);
-  disk_register(BLOCK_SIZE_A, BLOCK_COUNT_A, &dd_a);
+  disk_register("dd_b", BLOCK_SIZE_A, BLOCK_COUNT_A, &dd_a);
-  disk_register(BLOCK_SIZE_B, BLOCK_COUNT_B, &dd_b);
+  disk_register("dd_a", BLOCK_SIZE_B, BLOCK_COUNT_B, &dd_b);
   sc = rtems_task_create(
     rtems_build_name(' ', 'L', 'O', 'W'),
@@ -517,6 +518,8 @@ static rtems_task Init(rtems_task_argument argument)
 #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 5
 #define CONFIGURE_MAXIMUM_TASKS 4
 #define CONFIGURE_MAXIMUM_DRIVERS 4
2.12.3
