BSPs with Same Name, Different Architecture
Mon May 14 15:15:59 UTC 2018
This is an excellent rule. BSP names should be unique.
On Mon, May 14, 2018 at 8:36 AM, Joel Sherrill <joel at rtems.org> wrote:
> Hi
> Just a note that I had used the BSP name deos for three architectures. This
> worked until Chris added the BSP/architecture check.
> I am ok with the rule thank a bsp name is unique across all architectures
> but wanted to make sure this was a conscious rule now.
> --joel
> devel mailing list
> devel at rtems.org
