[PATCH] covoar.cc: Correct build path checks for multiple executables.
Cillian O'Donnell cpodonnell8 at gmail.com
Mon May 14 17:49:43 UTC 2018
On Mon, 14 May 2018, 16:46 Joel Sherrill, <joel at rtems.org> wrote:
> I'll commit this once there is a log message. :)
You want the word 'Fix' is it?... :)
> On Sun, May 13, 2018 at 3:45 PM, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>>  tester/covoar/covoar.cc | 10 +++-------
>>  1 file changed, 3 insertions(+), 7 deletions(-)
>> diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
>> index 5c87402..c6b0589 100644
>> --- a/tester/covoar/covoar.cc
>> +++ b/tester/covoar/covoar.cc
>> @@ -75,7 +75,7 @@ static void createBuildPath(Executables&
>> executablesToAnalyze,
>>          if (buildPrefix.empty()) {
>>            buildPrefix = *pri;
>>          } else {
>> -          if (buildBSP != *pri) {
>> +          if (buildPrefix != *pri) {
>>              fail = "executable build prefix does not match: " +
>> buildPrefix;
>>              break;
>> @@ -97,7 +97,7 @@ static void createBuildPath(Executables&
>>          if (buildPath.empty()) {
>>            buildPath = thisBuildPath;
>>          } else {
>> +          if (buildPath != thisBuildPath) {
>>              fail = "executable build path does not match: " + buildPath;
>> @@ -316,11 +316,7 @@ int main(
>>          std::cerr << "warning: Unable to read executable: " << argv[i]
>> << std::endl;
>>        } else {
>>          coverageFileName = argv[i];
>> -        coverageFileName.replace(
>> -          coverageFileName.length() - executableExtension.size(),
>> -          coverageExtension
>> +        coverageFileName.append( "." + coverageExtension );
>>          if (!FileIsReadable( coverageFileName.c_str() )) {
>>            std::cerr << "warning: Unable to read coverage file: " <<
>> coverageFileName
>> 2.7.4
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180514/922b489d/attachment-0001.html>
