[PATCH 1/1] Fix and extend error message in posix timer test
Martin Erik Werner martinerikwerner.aac at gmail.com
Tue May 15 09:21:55 UTC 2018
_Timespec_Equal_to() does not set errno, hence avoid using perror(),
instead use fprintf() to stderr, and extend the error message to provide
information about what the error is (measured timer value after
re-arming is not equal to the configured interval), and how large of a
difference was measured.
Signed-off-by: Martin Erik Werner <martin.werner at aacmicrotec.com>
 testsuites/psxtests/psxtimer01/psxtimer.c | 14 ++++++++++++--
 1 file changed, 12 insertions(+), 2 deletions(-)
diff --git a/testsuites/psxtests/psxtimer01/psxtimer.c b/testsuites/psxtests/psxtimer01/psxtimer.c
index 032e9f8e6c..6ec049ac54 100644
--- a/testsuites/psxtests/psxtimer01/psxtimer.c
+++ b/testsuites/psxtests/psxtimer01/psxtimer.c
@@ -143,7 +143,12 @@ void * task_a (void *arg)
        rtems_test_exit(0);
      if (! _Timespec_Equal_to( &timerdata.it_value, &my_period )){
-       perror ("Error in Task A timer_gettime\n");
+       fprintf(
+           stderr, "Error in Task A timer_gettime:\n"
+           "  re-armed timer: %" PRIdtime_t ":%ld does not match interval: %" PRIdtime_t ":%ld\n",
+           timerdata.it_value.tv_sec, timerdata.it_value.tv_nsec,
+           my_period.tv_sec, my_period.tv_nsec
      clock = time(NULL);
      printf("Executing task A with count = %2i %s", params->count, ctime(&clock));
@@ -291,7 +296,12 @@ void * task_c (void *arg)
        rtems_test_exit(0);
      if (! _Timespec_Equal_to( &timerdata.it_value, &my_period) ){
-       perror ("Error in Task C timer_gettime\n");
+       fprintf(
      pthread_mutex_lock (&data.mutex);
      while (data.updated == FALSE) {
2.11.0
