[GSOC] Weekly report
Tue May 15 13:01:43 UTC 2018
Minor nit: please put a short description of your project in the title
(e.g., "tracing") just to avoid overly plain and possibly confusing
titles if multiple students start to do this. Thanks for the update!
On Mon, May 14, 2018 at 9:12 PM, Vidushi Vashishth <reachvidu at gmail.com> wrote:
> Hi!
> As asked by my mentor, I am going to post my weekly project target on the
> mailing list every Monday. For this week I have the following planned:
> 1) Develop use cases (common development problems catered to, etc) for the
> rtems tracing support and identify what all needs to be implemented around
> with it. This would be documented first in my blog then the users manual.
> 2) Create a babeltrace conversion formula for CTF conversion. Document it
> with sufficient example test cases.
> 3) Fixing the buffering sample test cases which is currently failing a
> rtems-path check on execution.
> 4) Gain familiarity with barectf, identify methods of integrating it with
> rtems-tld output and working on array support for barectf.
> Best,
> Vidushi
