[PATCH 06/16] mvme3100: Move -Dxxx to configure.ac
Wed May 16 15:09:39 UTC 2018
Updates #3425.
 bsps/powerpc/mvme3100/config/mvme3100.cfg      | 2 +-
 c/src/lib/libbsp/powerpc/mvme3100/configure.ac | 2 ++
 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/bsps/powerpc/mvme3100/config/mvme3100.cfg b/bsps/powerpc/mvme3100/config/mvme3100.cfg
index 6e7c695..50a291a 100644
--- a/bsps/powerpc/mvme3100/config/mvme3100.cfg
+++ b/bsps/powerpc/mvme3100/config/mvme3100.cfg
@@ -9,7 +9,7 @@ RTEMS_CPU=powerpc
 #  This contains the compiler options necessary to select the CPU model
 #  and (hopefully) optimize for it.
-CPU_CFLAGS = -mcpu=powerpc -msoft-float -D__ppc_generic
+CPU_CFLAGS = -mcpu=powerpc -msoft-float
 # optimize flag: typically -O2
 CFLAGS_OPTIMIZE_V = -O2 -g
diff --git a/c/src/lib/libbsp/powerpc/mvme3100/configure.ac b/c/src/lib/libbsp/powerpc/mvme3100/configure.ac
index 88d8447..2bf0e40 100644
--- a/c/src/lib/libbsp/powerpc/mvme3100/configure.ac
+++ b/c/src/lib/libbsp/powerpc/mvme3100/configure.ac
@@ -37,6 +37,8 @@ Note that the policy can still be defined by the application
 CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK this feature is removed
 and a little memory is saved.])
+AC_DEFINE(__ppc_generic, 1, [PowerPC model option])
 RTEMS_BSP_CLEANUP_OPTIONS
 # Explicitly list all Makefiles here
1.8.3.1
