[PATCH 10/16] qoriq: Move -Dxxx to configure.ac
Wed May 16 15:09:43 UTC 2018
Updates #3425.
 bsps/powerpc/qoriq/config/qoriq.inc          | 3 +--
 bsps/powerpc/qoriq/config/qoriq_e6500_32.cfg | 3 +--
 bsps/powerpc/qoriq/config/qoriq_e6500_64.cfg | 3 +--
 c/src/lib/libbsp/powerpc/qoriq/configure.ac  | 2 +-
 4 files changed, 4 insertions(+), 7 deletions(-)
diff --git a/bsps/powerpc/qoriq/config/qoriq.inc b/bsps/powerpc/qoriq/config/qoriq.inc
index ff9586e..ad5c04b 100644
--- a/bsps/powerpc/qoriq/config/qoriq.inc
+++ b/bsps/powerpc/qoriq/config/qoriq.inc
@@ -7,8 +7,7 @@ include $(RTEMS_ROOT)/make/custom/default.cfg
 RTEMS_CPU = powerpc
 CPU_CFLAGS = -mcpu=8540 -meabi -msdata=sysv -fno-common -mstrict-align \
-	-mspe -mabi=spe -mfloat-gprs=double \
-	-D__ppc_generic
+	-mspe -mabi=spe -mfloat-gprs=double
 CFLAGS_OPTIMIZE_V = -O2 -g
 CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
diff --git a/bsps/powerpc/qoriq/config/qoriq_e6500_32.cfg b/bsps/powerpc/qoriq/config/qoriq_e6500_32.cfg
index d0f0391..0c24236 100644
--- a/bsps/powerpc/qoriq/config/qoriq_e6500_32.cfg
+++ b/bsps/powerpc/qoriq/config/qoriq_e6500_32.cfg
@@ -4,8 +4,7 @@ include $(RTEMS_ROOT)/make/custom/default.cfg
 RTEMS_CPU = powerpc
-CPU_CFLAGS = -mcpu=e6500 -m32 -msdata=sysv -fno-common \
-	-D__ppc_generic
+CPU_CFLAGS = -mcpu=e6500 -m32 -msdata=sysv -fno-common
diff --git a/bsps/powerpc/qoriq/config/qoriq_e6500_64.cfg b/bsps/powerpc/qoriq/config/qoriq_e6500_64.cfg
index b766fec..ebc26e4 100644
--- a/bsps/powerpc/qoriq/config/qoriq_e6500_64.cfg
+++ b/bsps/powerpc/qoriq/config/qoriq_e6500_64.cfg
@@ -5,8 +5,7 @@ include $(RTEMS_ROOT)/make/custom/default.cfg
 RTEMS_CPU = powerpc
-CPU_CFLAGS = -mcpu=e6500 -m64 -fno-common \
-	-D__ppc_generic
+CPU_CFLAGS = -mcpu=e6500 -m64 -fno-common
diff --git a/c/src/lib/libbsp/powerpc/qoriq/configure.ac b/c/src/lib/libbsp/powerpc/qoriq/configure.ac
index 7660cb3..9c35aa7 100644
--- a/c/src/lib/libbsp/powerpc/qoriq/configure.ac
+++ b/c/src/lib/libbsp/powerpc/qoriq/configure.ac
@@ -159,7 +159,7 @@ RTEMS_BSPOPTS_SET([QORIQ_BUS_CLOCK_DIVIDER],[qoriq_e6500*],[2])
 RTEMS_BSPOPTS_SET([QORIQ_BUS_CLOCK_DIVIDER],[*],[1])
 RTEMS_BSPOPTS_HELP([QORIQ_BUS_CLOCK_DIVIDER],[divider of the platform clock to get the clock most on-chip peripherals])
+AC_DEFINE(__ppc_generic, 1, [PowerPC model option])
 RTEMS_BSP_CLEANUP_OPTIONS
 RTEMS_PPC_EXCEPTIONS
1.8.3.1
