Where can I find the existing source code of generating release notes?
Danxue Huang danxue.huang at gmail.com
Fri May 18 02:07:18 UTC 2018
Thank you for the information Chris! I have downloaded Trac following your
instructions. Currently I am trying to figure out how it works.
-Dannie
On Thu, May 17, 2018 at 6:33 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 17/5/18 5:28 pm, Danxue Huang wrote:
> > I am currently working on RTEMS release notes generator, can you give me
> some
> > pointers to the existing source code of generating release notes? I am
> trying to
> > generate the report from Trac like 4.11.3  release notes (​
> > https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.3/
> rtems-4.11.3-release-notes.pdf).
> The specific script is:
> https://git.rtems.org/rtems-release/tree/rtems-release-notes
> This script downloads the release notes page from Trac. The base wiki page
> is:
>  https://devel.rtems.org/wiki/Release
> The next milestone for the 4.11 branch is 4.11.3 and the release notes are:
>  https://devel.rtems.org/wiki/Release/4.11/4.11.3
> If you are logged into Trac you can edit the page to see the Trac ticket
> query
> that generates this page.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180517/69d63b93/attachment.html>
